PIONEER PDP6010FD STUCK ON STAND BY MODE
BRAND NEW TV BOUGHT IT 7 MONTHS BACK. NOW CAN'T EVEN TURN ON. RED AND BLUE LED BOTH ARE ON. PRESS POWER ON FROM THE REAR KEY PANEL OR FROM REMOTE, NOTHING HAPPENDS. JUST STUCK THERE. CALLED PIONEER SUPPORT, THEY TOLD ME TO UNPLUG THE AC POWER CORD FOR 20 MINUTES, THEN PLUG IT BACK. STILL THE SAME ISSUE, THEN THEY GAVE ME 2 LOCAL AUTHORIZED REPAIR SHOP...AFTER A WEEK ...PROBLEM STILL UNSOLVE. THEY BOTH GAVE UP. WHEN I ASKED WHAT IS WRONG WITH IT, THEY SAID ! WE DON'T EVEN KNOW WHAT CAUSED THE PROBLEM. THIS IS VERY VERY FRUSTRATING ME. IS THERE ANY EXPERTS THAT CAN GIVE ME SOME INPUT. I'M TIRE OF BORROW A TRUCK FROM MY FRIEND BACK AND FORTH AND CARRY IT AROUND AND AROUND.
THANKS
    Sergeant:
  • 259 Answers
This model has to see the tv guide data to start. This has been discontinued by our friendly fcc as part of the digital transition..this is from a pioneer authorized repair center.......have fun........Meder's Tv
Posted on Dec 30, 2009
  • 2,322 Answers
If you spent that much for a TV that only lasted 7 months, they should know or have qualified technicians to fix them.
You should ask them for a replacement if they do not know what to do.
This type of TVs have a common failure on the YSUS assembly or the power supply but I would not recommend to try to fix yourself since the TV still under warranty.
Posted on Apr 25, 2008
LLoyd. Why doesn't it turn on?
If the led is red that means its stuck in stand by mode which is an indication that you have a problem in the power board
Mar 05, 2016 | Televison & Video
Just stand by led blue and red. it wont power on
Sounds like main board fault. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Apr 03, 2014 | Pioneer PDP-5070HD 50 in. Plasma...
Grundig Xephia 42 in.stuck on stand by
Probably the internal power supply has failed.
Nov 22, 2013 | Grundig Xephia 42 in. EDTV-Ready Plasma TV
Panasonic TX-L42S10B has power but won't turn on
ok, this may be a silly question but when you turn it on and it starts flashing red, have you tried pressing the stand-by button on the remote. if a tv has been put on stand-by by the remote, and is then switched off by the set, when the set is turned back on it is still in stand-by mode and you need to press the stand-by button on the remote.
other than that I don't know.
Nov 08, 2013 | Panasonic TXL42S10B 42 in HDTVReady TV
Pioneer plasma tv
Hi, you see when a TV set is left without power going through it, it actually does it harm, things in storage should be powered up at least a few times a month, otherwise the capacitors will loose their "Form" and will not work correctly, and if left too long the unit simply becomes unservicable, also the moisture in the atmosphere, gets absorbed by osmosis, into "Other" compnentry, and this too causes failures, not to mention, any other sort of corrosion, or perhaps flat cells in a unit, inductors etc. So as said, this makes a unit more or less unrepairable.
Below is a service manual, http://www.elwinelectronics.com/roadscum/Field_Service_Guide_07_rev1.2.pdf
http://www.avsforum.com/avs-vb/showthread.php?t=763359
May 04, 2010 | Pioneer PDP5016HD 50 in. Plasma Television
PIONEER PDP-R06U / PRO-R06U MEDIA RECEIVER SERVICE
Hey,
This may be too late...
I got it from the field manual.
Trap Switch Reset Procedure
G-4, G-5, G-6, G-7, G-8
• Replace media receiver, plasma panel cover, or tape down HDCP trap switch.
If the model in question has the TV Guide option, the TV Guide
option must be turned off before proceeding.
• Using the customer’s remote control enter “service mode” by pressing the
following key sequence:
1. Press the “display” button then release the “display” button.
2. Wait between 3 and 7 seconds
3. Press and release the “<”, “^”, “<”, “>”, and “power” buttons in sequence.
• Panel will now turn on in “service mode”.
4. Press “muting” button 3, 4 or 5 times depending on model you are working on.
Until the display shows the “initialize” page.
5. Press and hold the “display” button until the error indicator (red LED) on
either the panel or the media receiver goes out.
6. Exit service mode by pressing the “power” button on the remote.
I had to try it a couple of times before I got it to work. I.m not too sure how to turn off the tv guide mode. I just held it in for a couple of sec,s.
Good luck
Dec 05, 2009 | Pioneer Audio Players & Recorders
I bought my son a 19" philips tv model # 19pfl340d/27.in order to turn tv on it must be unplugged for 10-15 minutes.The first one I bought did the same thing and I returned it.this one is exactly the...
The remote control will not operate the TV when the TV is in the OFF mode (No LED lit on front bezel). To change the mode from OFF to STANDBY or ON, press the POWER button on the side of the TV. Once the POWER button is pressed, the LED will change to either red to indicate STANDBY or green to indicate ON, whichever mode the TV was in prior to being turned off with the TV POWER button.
By pressing the POWER button on the side of the TV, the mode will toggle from OFF to either STANDBY or ON. If the POWER button is pressed and then the LED on the bezel is red, the TV is in STANDBY mode and will need to be turned on using the remote control. If the POWER button is pressed and then the LED on the bezel is green, the TV is ON.
Nov 11, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
Red LED lights
power supply shot ... sometimes x board or y board
Oct 02, 2009 | Pioneer PureVision PDP-5030HD 50 in....
Televison & Video Logo
191 people viewed this question
Top Televison & Video Experts
Electro Med Services...
