Question about Dell Dimension E521 (D10E16) PC Desktop
Which color is the input jack for recording - Dell Dimension E521 (D10E16) PC Desktop
    President:
  • 2,600 Answers
On the front panel, the audio jack on the left side when looking at the front of the computer is the mic jack. On the back, look for the pink jack in the audio panel area. This is the mic. I included a picture of it below.
Posted on Aug 01, 2010
Need to know step by step instructions 0n how to record from my tv to my vcr including plug ins
I am assuming you wish to record what is playing on your TV to the VCR and not just asking how to record on a VCR, which is much easier, just put your cable from your antenna/cable box on the vcr and pick a channel from antenna or use channel 3 or 4 for cable box and press record. To watch TV with or without recording connect VCR output (Either coax or Composite) to same type input on the TV. If this is your question, then comment if you have trouble and I will get more detailed. This is a good video on doing this: https://www.youtube.com/watch?v=zgb7uoLIaQE
So if you want to record what is playing on your TV to the VCR, you must have a TV OUT on the TV. The only types of TV OUT that I have seen that would match to a VCR are either coax or RCA.
If the TV OUT is coax just connect one end of coax cable to the TV OUT on the TV and connect the other end to the Antenna/Cable IN on the VCR. Play the program on the TV and record on the VCR usually on either channel 3 or 4. Unless you have the VCR set up to play on another TV you will just have to use trial and error (record on one channel and playback on TV to see if you recorded anything, is so that is right channel, if not, then try the other one.) to find out which.
So, on to recording the signal from a TV on a VCR. If the TV OUT is Composite (RCA jacks, yellow, red, and white or black) you will need some RCA (Composite) cables. They may be labeled patch cords or dubbing cables at the store. That is if you can find them. I don't know if they are still being sold as a video accessory. If not just use RCA audio cords.
There will be two plugs on each end for mono sound recording and three for stereo sound recording. You will have to have audio or L & R audio, and video OUT on your TV and audio or L & R audio, and video IN on your VCR. Plug the yellow cable end into the video OUT on your TV and the yellow on the other end into the video IN on your VCR. Do the same for audio. I have always seen yellow as the color for video, but audio is sometimes white and sometimes black, and in stereo audio right is usually red, but left can be either white or black. With a little luck the cable plugs and TV and VCR IN & OUT jacks will match in color. If sound is mono the is nothing to get wrong. If audio is stereo the worst that can happen is the sound for right side will play on the left and sound for the left side will play on the right. As long as red is used for right it should be correct.
If there is only one set of input jacks on the VCR, the VCR input will probably need to be set to 'Line In'. If there are multiple sets of input jacks they should be labeled 'Input 1', 'Input 2', etc.. The VCR input setting will need to be set to the input you plugged the RCA cables into. The jacks you plugged cable ends into should be labeled. The setting for input on the VCR and TV should match the label on that device.
Now turn on the TV and put it on what you want to record. Do this before it comes on if you want to record all of it. Having set the VCR on 'Line In' or on the correct input, just press record on the VCR. Leave the TV on while recording.
As long as the TV is on and going to play something you want to record, you can set the timer on the VCR to record it, but instead of setting a channel you will choose either 'Line In' or the input number you are using.
This should always work to record a show on the TV when the signal is coming in through a coax cable from an antenna or cable box. But there are some TVs that only send that signal to the TV Out jacks. So if you are watching something from another source, like another VCR, a DVD player, or a video camera on TV on the TV and try to record that you will only record the incoming signal from the antenna or cable box.
In that case just connect the other VCR, the DVD or the camera to the recording VCR and play it on the one using the OUT jacks and record on the VCR using the Input jacks. This should make a better recording too. You can see what is happening by using the OUT jacks on the VCR and connecting the cable from them to the IN jacks on the TV and selecting the 'Line In' or 'Input 1, 2 etc.' matching where you plugged the cable from the VCR in on the TV.
Summary:
Device playing what you want to record is the: SOURCE
1. Using RCA dubbing cables plug them into the OUT jacks on the source and the IN jacks on the VCR.
2. Set the VCR input to the setting that matches the label on the jacks in which the RCA cables are plugged.
3. Play the program on the source and press record on the VCR to begin to record it.
Note: Leave the TV on if that is the source.
If you have any questions I assume I will get a notification if you leave a comment and I will be happy to answer.
Hope this helps. Good Luck!,
Ron
Jan 24, 2015 | Samsung Televison & Video
My dell inspiron 15, win 8.1 won't record from player via mike input jack
you need to plug recorder into headphone jack, not the microphone jack
Mar 15, 2014 | Dell Inspiron 1501 Notebook
The dr-mv100b only plays in black and white?
You may want to make sure your connections are correct. You will typically see this when you hook up composite connections into component inputs or vice versa.
Make sure if using composite (Red,White, Yellow) cables that they are hooked up to the composite out put jack on rear panel of the unit.*Note: composite out put jack is located directly below the composite 'Input 1' jack with a black 'background' on this recorder.So don't confuse this 'output' with an 'input' simply because it is below the 'input' jack.
Also make sure you are hooking up into composite inputs and not component (Green,Blue,Red) jacks.
Oct 31, 2009 | JVC DR-MV100B DVD Recorder/VCR
How do you make the dvd player work
This is the Apex SUPPORT website have a look around in here and see if it helps>
http://www.apexdigitalinc.com/support.asp
Aug 31, 2009 | Apex Digital AD-1600 DVD Player
Trying to hook vcr up to an emerson telivision
Are you trying to connect with coaxial, or RCA jacks, If you have the Yellow, white, and red jacks on both you Emerson TV, and your whatever brand VCR, all you have to do is connect using the color to color ports. Sometimes the ports on tv or vcr are only mono, so instead of having 3 jacks there will only be 2. Yellow for video, and red and/or white for Audio. If you are using coaxial cables, which aren't hardly on the newer models. This also depends if you want to just playback or record as well. If you want to record with your vcr, you need to put the source coaxial,(From wall), and put that to the input of your VCR, it may be in the input of your tv, so you would take that out and put it in the vcr, and you will need a separate coaxial cable to put from your VCRs output jacks into the input of your tv. That would also put your input channel on 3 or 4. If you could tell me the way you wanted to connect, I could tell you better. Hope this helps.
Aug 02, 2009 | Emerson Televison & Video
How do I hook up my vcr to my dvd recorder so I
You will need one RCA video cable it will have a yellow, red and white plugs. On the back of your VCR locate where the color inputs are find where it says VIDEO OUT hook it up there. On the back of the DVD Recorder look for the same color input jacks NOW find where it says VIDEO IN hook it up there. You may have to turn on your TV,DVD recorder and VCR to get the right channel. your Recorder may have one or more video inputs if it does turn on all three. Use the channel on your TV you use to watch DVDs make sure you see your DVD screen. Now to record to a DVD. Change the channel on the DVD Recorder. Look for the input channels It may be Video 1 Video 2 etc... depends on the inputs you have. ( A great way to tune your DVD Recorder is to play a prerorded VCR tape. Turn the channel on your DVD Recorder unil you see the prereorded tape playing. )
Jul 21, 2009 | Toshiba Audio Players & Recorders
I have a Sony ICD-SX35 recorder which my iMac will not recognize. Any clues out there???? I need to convert the dvf files into MP3 or WMA format but that can't happen before my Mac recognizes the...
I took the advice of one of your correspondents by connecting my Sony ICD-SX365 recorder to my iMac with a simple audio cable by inserting the output jack in the recorder's slot for headphones and the input jack in the iMac's slot for microphones. I used the freeware program Audacity to import the track onto the computer and Switch to convert the file to mp3.
Apr 15, 2009 | Sony ICD-P28 Digital Voice Recorder
Sanyo VCR
get a 2 A/V cords (yellow, white, and red plugs). Plug between the Satellites "video out" jacks and the VCR's "input" jacks. Connect the second cords between the VCR's "video out" jacks and the TV's "video in" jacks. Make sure the VCR is set to the input that you plugged the satellite cords into and make sure the TV is set to the input that you plugged the VCR's cords into.
And then you're done. To record, set satellite to channel desired, set VCR to record on the video input (instead of a channel number) and you're good to go.
Sep 08, 2008 | Sanyo VWM-800 VHS VCR
Dubbing home videos to pioneer dvdr-rw
Should be just as simple as plugging in the RCA jacks from the output of the VCR to the input of the DVD recorder. Make sure you pass the first grade color scheme and match the colors up! Yellow to yellow....red to red.....white to white...you get the idea.
Mar 13, 2008 | Televison & Video
Recording to DVD on samsung recorder from dish network dvr
Connect the "yellow, white , red) jacks from the Satellite to the same colored inputs on the DVD. If you use "Input 1", for instance, set the dvd to record on Input 1. Set Satellite to desired channel. Good to go.
Sep 08, 2007 | Samsung DVDR120 DVD Recorder
Dell Dimension E521 (D10E16) PC Desktop Logo
1,002 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
