The builder of my house preset my honeywell thermostat such that it could not be adjusted below 72 for cooling. This was to prevent subcontractors from setting it lower while doing interior work on the house. I never learned how to de-program it so that I can set it lower than 72 degrees. What do I do?
  • elcinco Apr 25, 2008
    I'm uncertain of the exact model number.  The owner's manual is for an "Eletronic Heat-Pump Thermostat" for T8501, T8511, T8524.  I don't have a heat pump, though.  The thermostat has both up and down arrow keys and an "i" key.  When you flip the panel open it has a "system" button and a "fan" button.  The "i" key is what you press to learn the temperature setting.  If I hold both arrow keys down at the same time, it gives me a screen, but I don't know how to make any adjustments from that point forward.
  • 3,037 Answers
Try reseting the circuit breaker first and see if that fixes it
I can get you a manual but I need the model number of the unit
Please let me know if the simple reset of the circuit breaker fixes it.
Notify me by posting here if it doesn't
Thank you for using Fixya and Good Luck
please don't forget to rate my solution as soon as you solve your problem, thanks
Posted on Apr 25, 2008
  • Benjamin Patri
    Benjamin Patri Apr 25, 2008
    don't rate a solution until the problem is solved and only rate "Fixya" if the poster was the one to tell you how to fix it.
  • Benjamin Patri
    you should be able to press the i button and then just arrow up or down to change the temp
    Master:
  • 555 Answers
What is the model # of this Honeywell thermostat?
  • Matt Jurach
    Matt Jurach Apr 25, 2008
    That sounds a lot my my thermostat. Does it have a "Run" button?
  • Matt Jurach
    For me, the arrow buttons will adjust the set temperature, but not permanently if a prior program is engaged. Pressing the "Run" button will cancel the program and allow the buttons to set the temperature for real.
I have a honeywell focus pro 6000 temp in house doesnt change unit runs constatly. thermostat says 78 thermomiter on other end of house says 72. changed batteries
It's possible you have a lot of dust build up inside the stat. If it has batteries remove face from wall and blow out. Take outside to see if temp will change. Plug the hole in the wall where the wire comes through. If all fails, replace. Turn power off, take wiring picture, replace, turn power on. Good Luck!!
Apr 30, 2017 | Honeywell Heating & Cooling
Thermostat does not reach programmed temperature
Have you checked with a thermometer to see if the area is reaching the temp you have it set at? A thermostat has nothing to do with the temp in your house. If you have it set at a temp for Example ( 72 ) and it is not reaching that temp to shut off then you have a problem with your unit or insulation in house. If you set stat on cool at 72 and the house gets down lower than 72 then there is a problem with stat.
Dec 19, 2014 | Honeywell CT500 Digital Heat / Cool Manual...
Why can't I lower my honeywell 8500 below 67 on cool?
With a two story house you have to be aware that cold air flows downwards so any cold air coming from an ac unit will flow downstairs( normally down the stairway) so unless you can close off the down stairs then the up stairs unit will be cooling downstairs as well. Ac units have a thermostat located in the air intake and it cools until the cold air has risen to that point. In effect the space above the ac unit will be hotter than the floor. Knowing how they work ,you can see that the upstairs unit will never reach the set temperature because the cold air is continually heating from the house and will never get to the top thermostat.
So your solutions are
1-- fit controls that restrict the cold air from leaving the upper floor (Doors)
2--don't run the upper ac unit unless you are living up there (waste of money
)3 place an ac in each upper room and keep the room door closed
Aug 12, 2014 | Heating & Cooling
Honeywell RTH230B a/c problem
if you set the thermostat on 70 and your house won't get ant cooler than 72, there is a problem with your system,not your stat. I'm thinking you are low on refrigerant if it is somewhat working. when the unit is running, if you can get your hand on the larger refrigerant line under the black insulation, it should be cold, about 55 degrees.
Jun 19, 2009 | Honeywell Programmable Thermostat Heater
CYCLING TO OFTEN
You need to adjust the heat anticiptor on the thermostat. Not knowing your furnace control amp draw ..... I would set the anticiptor somewhere between .3 & .7. The slight adjustment should make the cycling run better. If not adjust it the other way. If this does not solve the problem the heat anticipator might be bad (change the thermostat). If you have a digital stat read the manual most are preset at the factory. Sometimes you can reset it by following the directions.
Mar 25, 2009 | Honeywell Electronic Programmable...
Thermostat temperatures not reaching preset Energy Star settings
Well with a boiler system like you have it will cost you more money to heat your house that way than if you leave it like it is. With a boiler system it takes a lot longer to heat an area than with a furnace. The best thing you can do is find a happy medium and leave it there at all times. If you read the paper work on your new thermostats they have a set procedure which tells the thermostat if you have forced air or boiler system. Do you have baseboard or in-floor heat how many zones do you have.
Jan 07, 2009 | Honeywell Electronic Programmable...
Cooling limit on th320u
the cooling setting will not go below the heating setting. lower the heating setting so you can lower the cooling
Jan 16, 2018 | Honeywell Electronic Programmable...
Heating & Cooling Logo
147 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
