Question about Jenn-Air JLG7130A
Jenn Air Built in Four Burner Grill
The first two burners light initially but when the other two burners are lit the grill shuts itself off. There is then either no flame or very little flame. Please help?
  • 140 Answers
Replace the regulator that should do it
Posted on Aug 06, 2010
I Have A Jenn-Aie Model 720-0164 Natural Gas Grill. When I Grill, The Control Knobs Get So Hot Theyh Will Burn You. What Could Csuse This?
Can this grill be also used on propane? If so you might be running it too hot on natural gas, check to see if the control knobs have two different set of markings.
Sep 16, 2014 | Jenn-Air Outdoor Liquid Propane Lp...
I have Jenn-air gas grill, model no. 720-0336, the back burner that we use for the Rotisserie does not stay lit. Once started it will run for three minutes or so the you'll hear a pop...flame goes...
The tube to the third burner or the burner itself is clogged. Spiders are the usual suspects. Unhook them and clean out with circular brush or compressed air.
Please rate my answer 4 stars if it helps.
Good luck,
Oct 24, 2017 | Garden
Grill will not stay lit if using 4 th burner will only work on 3 burners and gas is low
Check that the fourth burner tube is set properly into the unit. Then turn all burners off, turn off the natural gas supply or remove the LP tank. turn all the burners on (don't try to light) wait a couple seconds turn all burners off. reconnect gas source. turn on gas, open burners fully and try to light.
Aug 08, 2010 | Jenn-Air Grilling
Grill will not light
If there is no gas check the tank, If the tank is fine look at the regulator. It has to be flat, because of a valve inside. This is a safety device incase of tipover.
Apr 14, 2010 | Jenn-Air JLG7130A
How do I adjust the flame to burn hotter or more.
There are adjustment screw at the end of the burner tubes that allow more or less air to enter the burners. try opening or closing these screws
Jun 01, 2009 | Jenn-Air JLG7130A
Jenn Air Grill - Gas flow from one valve
I have the same problem. The middle and the right burners will work, but if I light the left side (3rd burner) all 3 go out. pressure is reduced to zero.
Aug 30, 2008 | Grilling
Jenn-Air 30 in. JGD8130 Gas Cooktop
Yes. Buy a burner module. Sears sells them also most appliance part stores. (I am assuming you have the model with 2 knobs on the grill side) The electric version of burner modules is around $100 Gas should be similar price.
Jun 08, 2008 | Jenn-Air JGD8130 Gas Cooktop
Jenn-Air grill half burner issue
Re: only one side lighting, it is a problem with the cross over **** that carries the flame from one side of the burner to the other. It is located at the rear bottom of the burner and is probably clogged. Wire brush them to clean; failing that, replace with new ones and keep the new ones cleaned with a wire brush regularly.
May 31, 2008 | Grilling
Grilling Logo
167 people viewed this question
Top Jenn-Air Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Fred Harvey
Are you a Jenn-Air Grilling Expert? Answer questions, earn points and help others
