Question about LG Flatron F700P 17" CRT Monitor
The screen lamp flickers - in green and orange - the screen won't turn on, its totally black, no picture, I tried another screen - my old one, attached it to my computer and it works properly....
  • michal_czeis Aug 01, 2010
    hallow. my screen won't turn on - the lamp flicker withe green and orange but the screen wont turn on/ I attached another screen to my computer, and it worked just fine. I was told that it might be the cabel, but what else can it be?
    President:
  • 3,278 Answers
Hello.
Could be a problem with your VGA / USB monitor cable.
It could also be a logic board problem.
Depending on the age of your monitor, it may not be worth it to repair, unless someone you know is knowledgeable.
Check to see if the monitor may still be under warranty (3 year warranty ?)
Hope this helps.
Posted on Aug 02, 2010
  • NinaE Aug 02, 2010
    Just checked - your monitor does have a 3-year warranty.
    President:
  • 567 Answers
Hi you need to increase the refresh rate of the monitor if it flickers,check the monitors for several buttons at the front of bottom use those buttons th set the monitor. If the problem still exist check the monitor cable it may be faulty,you should try another cable.
Posted on Aug 01, 2010
    thanks, but it wont turn on at all!! no picture at all! tried the buttons, it didn't help, the cable? but why did it work till now? now only the lamp flickers but the screen doesn't react - so you think it is the cable? What other problems there might be? ( sorry about my broken English, its not my mother tounge)
  • Hilton Bristol Aug 01, 2010
    Hi usually when a monitor flickers that mean the refresh rate need to be increase,the other problems which can cause you not to see anything on the monitor is bad VGA cable that is the cable which connect the monitor to the computer, or the screen is bad
Samsung HLM507 FLICKERING PROBLEM
how extended is that warranty, and what does it cover? Sounds to me like a classic video controller board about to fail.
Mar 24, 2008 | Samsung DLP HL-P5663W 56" TV
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
I have a sanyoclt2054 picture flickers and then goes black and the sound is ok. what is wrong with this?
It is the lamp that is getting faulty, that is why you are having the flickers and the black screen.
when it is completely bad, you will be experiencing a total black screen but the sound will still be functioning.
Have the lamp replaced and the television will be okay once again.
Take care and good luck
Nov 06, 2010 | Televison & Video
Screen flickering when turning on laptop and sometimes the laptop turns on after flickering and sometimes doesn't turn on at all after flickering. Just stays black.
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Sep 01, 2009 | Acer Ferrari 5005WLMi (LXFR506119) PC...
Dell Inspirion Laptop Screen Randomly Flickers, Then Blacks Out
If this laptop is only a few monthe old, then it should be still under warranty. I suggest you return it to the supplier for repair or replacement under warranty. If you try to repair it, most likely you wil void your warranty.
If you don't have this choice then read the following info.
You most likely have a faulty CCFL lamp or inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Aug 06, 2009 | Dell Inspiron 1100 Notebook
Screen does not work
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Check out
www.lcdparts.net
Jul 04, 2009 | Toshiba Tecra 8100 Notebook
The screen on my Acer ASPIRE 9300 has turned orange -
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 16, 2009 | Acer Aspire 9300 Notebook
Laptop screen goes black, no backlite
You could have a defective screen - a defective inverter or a CCFL lamp.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
May 08, 2009 | IBM ThinkPad T23 2647 Notebook
Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
LG Flatron F700P 17" CRT Monitor Logo
73 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
