Question about Dometic RM2652 Refrigerator
Dometic refrig not cooling but found yellow oil at service panel
  • 24 Answers
Well first of all there is NO freon in RV refridgerators only ammonia and hydrogen gas, Remove your unit and get aqualified repair person that works on RV fridges. Its ammonia that is leaking.
Posted on Aug 10, 2010
  • 50 Answers
If you find an oily substance its most likely freon. this looks pretty new so i would say you have a bad soldered joint on a copper to steel line. theses usually ar fot the high side. where the condensor coil or loop runs either to underref or up in the ref walls
Posted on Aug 01, 2010
Dometic RM2652 check light
possible bad 12 volt heater element
Apr 11, 2018 | Dometic Heating & Cooling
Dometic RM2611, Freezes fine, Refrig OK on AC, but warms up when on LP gas. Can I safely increase the orifice size from #53 to #58? Thinking that will increase the flame and produce more heat.
Check the gas regulator and the lines for particles of dirt. You have modified the refrigerator it is going to take some work to find what is wrong. Don't modify the orifice from what it calls for.
APPLIANCE 911
Aug 27, 2016 | Dometic Refrigerators
Dometic RM2652 was working fine then stopped - no lights at the control panel above the doors.
Usually there is a short in the system when fuse is blown. Check the cord as sometimes mouse can damage the cord. It is a posibility.
Check power to the electronic board.
Jan 28, 2015 | Dometic RM2652 Refrigerator
My Dometic RM2652 fridge suddenly quit cooling. No amonia smell, no yellow residue around cooling unit. Gas ignites, lites work.
what is the yellow residue around heating element? my fridge just isnt working right and sometimes stops all together, the freezer worked until lastnight but fridge hasnt cooled right for a week or so.
Aug 03, 2012 | Dometic RM2652 Refrigerator
Refrig isnt cooling enough. freezer working good
If the freezer is working like it should, then the cooling system is also working like it should as well. Nothing wrong with control panel or thermistor.
If the fridge compartment doesn't cool down, you may have too much in it hindering air circulation, or perhaps the door gasket is leaking.
Jun 30, 2010 | Dometic NDR 1292 Refrigerator
Our rv has a dometic rm2600 fridge that smells of ammonia inside and has a little bit of yellow residue in behind service panel. is the fridge wrecked or is it worth repairing. the rv is 27 years old.
Sorry to give you the bad news. The ammonia smell is the the refrigerant
leaking out. Dometic uses ammonia that is heated and then condensed to cool. It will all leak out and quit cooling.
The fridge is wrecked. There are shops that rebuild the units. Beings as ammonia is corrosive one must assume there may be other leaks ready to appear. There are RV salvage yards that sell good used units.
Again Sorry for your loss.
Apr 27, 2010 | Dometic RM2620 Refrigerator
My Dometic works but is not cooling properly. I set it at the highest setting and barely keeps food cold.
You either have a blockage or a small leak in the system. Need a refrig. tech. to evaluate then do the repair. No way out sorry.
Sep 14, 2009 | Dometic Refrigerators
Refrig cooling
Sounds like the evaporator fan is not working. Check to see if you can hear the fan running in the freezer. If not running, try removing the panel in the back of the inside freezer and manually spin the fan blade . This sometimes works.
Jul 03, 2009 | Refrigerators
Dometic RM2652 will not cool on A/C or propane, I've checked fuses, and AC to refer. I opened the access panel on outside of Travel Trailer, and there is yellow powder on bottom, and some on heating tube....
Ammonia is just what you a re smelling as the coolant is ammonia based Your cooling unit has leaked and is done for- Sorry I had to be the one to tell you
2 choices Replace the refer or Replace the coiling unit, I would suggest replacing the refer and having a new warranty
Jun 07, 2009 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
445 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
