Question about GPS
Dont Know the Color codeing for Trailer wire on a Ford f150. Trying to hoke a 7 wire adpter for Trailer.
  • 2,005 Answers
Http://images.search.yahoo.com/images/view?back=http%3A%2F%2Fimages.search.yahoo.com%2Fsearch%2Fimages%3Fp%3Ddiagram%2Bof%2B7%2Bway%2Btrailer%2Bplug%2Bwiring%26ei%3DUTF-8%26fr%3Dmoz2-ytff-tyc%26fr2%3Dtab-web&w=558&h=283&imgurl=www.miss36dd.com%2F6_way_trailer_and_carJPG..jpg&rurl=http%3A%2F%2Fwww.miss36dd.com%2Fwiringdiagrams.html&size=46k&name=6+way+trailer+an...&p=diagram+of+7+way+trailer+plug+wiring&oid=bded9542db0ce36a&fr2=tab-web&no=4&tt=17&sigr=11bpc7ecr&sigi=11e7d1dve&sigb=13p7ioiib
Posted on Aug 01, 2010
What are the wire color codes for a 4 pin trailer connector on a 2010 ford f150
hi i have got a w reg ford fiesta what is the colour code for the wires from my trailer lead to my car lights please
Nov 07, 2010 | Ford F-150 Cars & Trucks
I need a wiring diagram for a 7 wire system
I am guessing you mean the 7 pin trailer tow adapter.
the 7 pin RV plug itself
The 2005 trailer tow adapter wire diagrams
Oct 23, 2010 | 2004 Ford F150
I need wiring diagram of trailer battery charging circuit for a 2002 ford f150 4x4
Try this site. http://www.etrailer.com/faq-wiring.aspx. They give color codes and detailed info.
Check your owners manual as there should be a fuse under the hood to feed the trailer 12V trailer feed. On certain vehicles, the feed is controlled by the ignition switch. It won't charge unless the switch is on.
Jul 25, 2010 | 2002 Ford F150 Regular Cab
I have a 1999 ford 150 and need the color code for rewiring the trailer lights
7 way trailer lights:
Black- 12 volt (power)
Brown- tail lights
Yellow- Left turn signal
Green- Right turn signal
Blue- Brakes
White- Ground
Orange- Auxiliary power (not always used, but example would be trailer back up lights, if equipped
Mar 14, 2010 | 1997 Ford F150 Regular Cab
Need to hook uo a flat four trailer conector ,dont know ford
The rear lights :
Brown is the parking lamps ( either side )
Driver's side Stop / Turn : Light green w/ White stripe wire
Pass Side Stop / Turn : White w/ Light blue stripe wire
Another option ( for use with the factory trailer circuits ) is to add / replace the factory tow adapter. eTrailer has them, if you are interested. This is the type adapter as Ford p/n: YL3Z-13A576-G. You would need to install the relay and the fuses for the trailer circuits if you do this.
Nov 03, 2009 | 2001 Ford F150 Styleside SuperCrew
I need a wiring diagram for a 2001 ford f150 trailer hitch plug in. i got a new heavy duty trailer connector and i need to know the color code of the wires
Hey Bryan
I've got them for Six and Four wire plugs
Six wire plugs:
Horse, stock or utility trailers:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Yellow = Not used -
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
Best regards
Mike
May 02, 2009 | 2001 Ford F150 Styleside SuperCrew
Installing a 7-pin trailer towing recptical on a 1991 Ford F150.
I believe you can look up the manufacturer of the trailer plug kit and find the wiring diagram there. On alot of the trailer plug kits, they have pics and diagrams in the package. The 7 pin plug (truck side) is available with the pig tail set up that plugs directly into the wiring harness for the lights. Then all you would have to worry about is the 2 wires for the electric brakes.
Nov 29, 2008 | 1991 Ford F150
Tow plug
I take it the blinkers and brake lights work ok when not hooked up to the trailer? If yes, then the wiring to the tow hitch is not hooked up correctly. How many wires to trailer pig tail connection? U can have up to 7 depending on what you tow. Check to make sure these wires are hooked up from the truck to tow plug correctly: 7 wired---
brown-Rt turn and brake light, yellow-backup, white-ground, blue-electric brake, green-tail running lights, black-battery charger, red-left turn signal and brake light. Let me know if u have something other than 7 wire, I'll get the wiring color and source info for u.
Nov 25, 2008 | 1998 Ford F150 Regular Cab
GPS Logo
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
