Question about Yamaha AX-496 2-Channel Amplifier
My amp keeps cutting out - Yamaha AX-496 2-Channel Amplifier
  • Yamaha Master
  • 17,130 Answers
If your ampliffier is cutting off even when it is not playing music or without load, it is possible that some errors are on in the protect circuit. Look for possible fault in capacitorrs in this circuit. If not the powering of the outputs can cause the intermittent failure due to overloading. So check you speakers, your speaker connections and also your main power inlets. Check for any spark marks on the plug top, if so use an emery paper to clean. Still if the fault is persisting then you will need som help to probe into the main board . Tap into the board for the fault to come up , in this case there could be dry points in the board. Look carefully into the boarrd and solder all suspect joints. Otherwwise you will need a good check on the cut off error amp, disconnect power amp and check. isolate and confirm the section in fault. Hope you try. Good day
Posted on Aug 03, 2010
Why does my 1990 Daihatsu charade want to cut out and stall when giving throttle unless it's in high rpms it doesn't want to go we've replaced the fuel pump and filter could it be the injectors?
Daihatsu Charade low idle problems Questions & Answers ...
www.fixya.com > ... > low idle problems > Cars & Trucks > Daihatsu
Daihatsu Charade cars & trucks low idle problems questions and answers. ... but idles unevenly with foot on accelerator. does not want to accelerate. please . ... problem daihatsu cherade 1991. when the airconditioner is on the car stalls when changing down to a lower . ... 1990 daihatsu applause 101a 1.6lt 5spd manual.
Daihatsu Charade car keeps cutting out when stop ... - Fixya
www.fixya.com > ... > Cars & Trucks > Daihatsu
Daihatsu Charade cars & trucks car keeps cutting out when stop questions and answers. ... 1997 Daihatsu Charade CS G203 1.5i manual stalling when warm ... gear) while accelerating or when coming to a stop and you take it out of gear and ... 1990daihatsu applause 101a 1.6lt 5spd manual car starts normaly. when auto ...
Nov 17, 2015 | Daihatsu Cars & Trucks
Fusion amp keeps cutting out
hi loose wires id check for first, but if it keeps playing up its an internal prob
Apr 08, 2012 | Car Audio & Video
My subwoofers cut out after 30 seconds of use but work fine during the 30 seconds...my fuses are all fine and i'm running thick wire with an 80 amp fuse connected off battery...I have a lanzar vibe286...
If it's only your subwoofers cutting out and your speakers are still playing and all, try turning gain down on sub amp and see if that fixes it. I know if I crank my amp too high it kicks itself off to try to keep itself from blowing.
Aug 21, 2011 | Car Audio & Video
My ne kenwood amp keeps cutting in and out and i would like to know why
I suggest that the load, in ohms, may be incorrect, thereby overheating your amp, which cuts out, and back on when cooled. Measure the load with am ohm meter and I bet you will be off of spec.
Jun 03, 2011 | Kenwood KAC8105D Car Amp
Amp keeps cutting on and off
Do you own a capaciter if not get one. If that dont help check all your wiring make sure it is the proper thickness and lengths.
Jul 30, 2009 | Alpine MRV-F540 Car Audio Amplifier
The air keeps cutting on & off by itself
Sounds like th climate control bix is faulty.
Jul 08, 2009 | 2000 BMW 3 Series
System Cuts Off
your amp is tripping out because the subs a drawing to much power get a better amp alpine subs demand a lot of power try a high current amp
Jun 30, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Amp keeps cutting off
Do you have heavy enough gauge wire supplying B+ to amp.Big amps draw a lot of current and require very heavy gauge wire. The longer the run the heavier the gauge needed.
Apr 20, 2009 | AudioBahn A8000T Car Audio Amplifier
My Boss Amp keeps cuts off when I play the music from my stereo when i play music and turn it up the amp keeps cutting in and out and i have to tap it and it will turn on
someting is busted in the amp! needs to be repaired or replaced !
make sure all wires are tight tied to the terminals first!
thanks
erik
Feb 24, 2009 | Car Audio & Video
Yamaha AX-496 2-Channel Amplifier Logo
359 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
