Question about Maytag PAV2300 Top Load Washer
Stagnant old soap smell. maytag performa 2003 model
  • 553 Answers
That's an easy one just add a 1/4 cup of baking soda to your last load each time you do laundry. If you add it to your whites they be much whiter.
Posted on Aug 02, 2010
  • 50 Answers
The inner drum needs to be taken out and the outer drum develops a thick gunk of softener and detergents. have to have a spanner nut tool to do it. they actually sell one that works for all washers. it has different inserts for different brands.
Posted on Aug 01, 2010
Water left in tub at end of load smells bad you don"t see water but can hear at a turn of the tub by hand.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hope your filter is clean. Don’t wait for the machine to jam to look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use very hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Put the Affresh pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
May 20, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have a residual mildew odor from my washing machine??
That's normally from undissolved soaps still in the system. Age old problem. Need to do a hot wash without clothe or soap at least once a day for about 4 days. Smell should lessen. Suggest you use a lot less soap during each wash as it is very concentrated.
Sep 28, 2009 | Maytag Performa PAV2200
Washer is making a loud noise when its trying to rinse
you will have to open up the panel to check where the smell comes from. It could be on the motor which may cause also a loud noise or from the electrical, loose connection or bad relay may cause a noise of a different kind.
Sep 21, 2009 | Maytag Performa PAV3200
Maytag Performa Electric Range (PER1510) tripped circuit breaker when immediately following turning the oven on. There was a mild electric burn smell from behind the range. I have left the circuit...
first, un-plug unit and remove rear access cover,it could be a wire with bad insulation that has shorted to the body of the unit,could be an oven/broiler element,could be one of your feed lines to the unit shorted to ground,does it trip brkr w/o anything turned on???you can also isolate the problem that way.good luck
Aug 20, 2009 | Maytag PER5710 Performa Electric Kitchen...
Soap dispenser doesn't open
My recommendation is to switch over to a tablet and merely put the tablet on the floor of the dishwasher bypassing the soap holder all together. It should work just fine that way. good luck.
Dec 29, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Maytag PAV2300 Top Load Washer Logo
138 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
