Question about Refrigerators
Dear Sirs, We have and Electrolux integrated fridge freezer. The upper part ( fridge) is not keeping things cold any more but the freezer is ok. Nothing wrong with door seals etc... We have turned the red switch both ways ( off and when lit up ) and no change. Before it packed up there was a large build up of ice at the back of the fridge. Appreciate your reply if you know if repareable or not. Derek
  • 50 Answers
Ice build up is usually a sign of lack of airflow(possible fan). or failure in defrost. if fan is running something related to defrost. there are bimetals that need to be ohmed out and the heater as well. if you can comfirm these parts are good change defrost control.
Posted on Aug 01, 2010
Fridge not cold enough and freezer too cold
check the fan to see if it is running.
Sep 20, 2012 | Whirlpool Refrigerators
Westinghouse RJ275M 194l fridge with top 81l freezer doesn't keep the fridge cold anymore. Freezer is fine. is it the thermostat?
If the upper compartment, the freezer part is open on the ends and the rest of the refrigerator is cold enough, that can't be fixed. If the the box is closed on the ends seperate, check the flow control of air if it has one, check the thermostat and set it till things nearly freeze in the lower non frozen section. If all this doesn't work and you can't keep the ice cream turning to milk, gotta get a new refrigerator.
Nov 25, 2010 | Westinghouse Refrigerators
The Fridge on Electrolux fridge freezer is not working, not cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 02, 2010 | Electrolux ER7926B Bottom Freezer...
The Electrolux refrigerator is not working it's not cold but the freezer is working I was told it may be the thermostat. Food and milk in fridge is getting spoiled. It's been out for 3 days already. Thank...
First thing to check is if (a) the evaporator fan is running in the freezer and (b) if there is a build up of ice on the freezer wall. If the fan is not running in the freezer the ref. side won't cool. If there is a build up of ice on the freezer wall, then you a defrost system problem and there won't be any circulation to the ref. side. If you have a defrost problem, the defrost system consist of 3 parts: timer, bi-metal thermostat, and heaters. With fridgidaire more than likely the adaptive defrost board(timer) located in the fridge on the upper left side behide some white pastic is bad. If you change it go ahead and change the bi-metal thermostat, located behind the freezer wall, as well because its a very cheap part and will save you from having to do it later.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Nov 01, 2010 | Electrolux Icon 22.6 cu. ft. Counter-Depth...
Fridge not keeping things cold enough
fridge coldest setting is 1
freezer warmest setting is 1
Dec 08, 2017 | Fisher and Paykel E522BLXEZ EZKleen...
Fridge not keeping cold..
Check the coils underneath the fridge. Carefully vacuum and brush the coils clean. Usually there is a condenser fan near the compressor and condenser and a evaporator fan in the freezer. Make sure they both are turning.
Jun 21, 2010 | Electrolux E23CS75DSS Stainless Steel
Electrolux ER 7626 Fridge not cooling
On these units there is a defrost heater which comes on after about 12/14 hours running time depending on usage.It would cut in for about 15 mins just to get rid of ice accumulated around the Evaporator.This heater or the timer has failed and ice has got between the duct. supplying cold air to the fridge unit.The best thing to do is to defrost unit for 24 hours and then try it and see if you can feel cold air coming up into the fridge.The repair for this is not that successful and you would be better off defrosting unit like a normal fridge/freezer.
Hope this was a help.
May 12, 2010 | Electrolux ER7626B Bottom Freezer...
Freezer working well fridge not working at all
there is a fan in the back of the freezer that pushes air into the fridge side of the fridge it sounds like this has gone out on you. this fan is usually right by the coils in the freezer the only thing that keeps the fridge cold is a little air being pushed over there constantly
Apr 27, 2009 | Refrigerators
Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Nov 10, 2008 | Frigidaire FRT15B3A Top Freezer...
Refrigerators Logo
70 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
