Question about Frigidaire GLTF2940ES Front Load Washer
Washer won't completely drain - Frigidaire GLTF2940ES Front Load Washer
  • 50 Answers
Check to see if it gets a lot of water out of hose while it is draining. most likely something in the drain pump or sump(black boot that connects to back of pump). have a wet vac and some towels. you will most likely find some change and maybee some barrets or bobby pins in there.
Posted on Aug 01, 2010
  • Frigidaire Master
  • 8,220 Answers
Their is a little basket inside the tub to pump hose.
I bet it has something in it. Your MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Ariston A1637 delay wash and key lock flashing won't complete a cycle
Most likely the problem is a clogged or jammed drain pump impeller. First shut off power to the washer by unplugging it or turning off the breaker. Then remove the screen in the bottom of the washer,clean it out reinstall then run washer
Jul 28, 2013 | Washing Machines
GE Washing Machine won't drain or complete cycle model # WBCH6240F0GG
The power line might flick. That's why not complete cycle.
Before do any repair, samply plug a alarm clock to the outlet that
the washer plug to. Leave there for a while about 1 day. If it blink that mean there a flicker on that line or may be some other line as well.
If power line is flickering. Fix the line (Do not fix the Washer!)
Mai Lor
Feb 25, 2013 | Washing Machines
Maytag Neptune MAH8700A tha detergent drawer is filling up with water and running out of the drawer onto the floor not going into the tub.
see this causes and fix it. God bless you
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
Oct 11, 2012 | Maytag Neptune MAH7500WH Front Load Washer
My indesit iwc6105 washing machine is not draining at all.
see this causes: and fix it. God bless you
Oct 11, 2012 | Washing Machines
CHANGE DRAIN PUMP WASHER
Oct 02, 2012 | Whirlpool GHW9300 Duet Washer
The washer broke filled with water and won't drain
Sep 28, 2012 | Kenmore Washing Machines
Whirlpool top loading washer won't fill completely
did you shorten the stand pipe for the outlet drain ?if not try putting a short extension on the top .
Nov 18, 2017 | Whirlpool Washing Machines
Kenmore elite washer won't drain
What is the model number of your washer? This condition is caused by a bad lid switch.
Aug 13, 2012 | Kenmore Washing Machines
Washer won't drain.
It is possible that your lid switch is defective. Bypass the switch and try again-Please unplug your machine while you bypass switch. If it still does not drain the I would suspect your timer.
Lid switch Part# 3949247
Timer Part# 3955651
http://www.on-timeappliance.com/washingmachinerepair.html
Mar 28, 2012 | Whirlpool Washing Machines
Flashing F2
“F02” (Drain Problem)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Is the drain hose kinked?
Is the drain hose frozen?
Is the drain hose clogged?
Is the drain hose more than 96" (2.4 m) above the floor?
After running this check list, plug back up and try a complete cycle using cold water and no detergent. Sudding can mimic a drainage issue as well. make sure you are using the correct HE detergent to prevent over sudding.
Feb 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
128 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
