Question about Dyson Vacuums
Clicking on power switch does not turn on motor.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 183 Answers
Check the plug fuse
Posted on Aug 02, 2010
Why want beater bar turn on Dyson DC17?
There are a few things it could be. Pull the handle back into the vacuuming position and turn the brush bar switch on and off while listening to see if you can hear the brush bar motor turn off and on. If you can hear the brush bar motor running it may need a new belt and/or the brush bar may be seized up.
There is a switch by the main power switch that provides power to run the brush bar motor. There is a micro switch down in the motor area that closes the circuit to the brush bar motor when you pull the handle back. Check electrical connections and all of the above parts to determine which one or one's may be defective.
Jul 09, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
Why want the beater bar turn?
Jul 09, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
Vacuum cleaner won't turn on
Check the cord first to make sure you are getting power to the switch. If not replace the cord, if so test the switch to make sure you are getting power through the switch. If still not solved follow the power down to the motor and make sure you're getting power to the motor. If so and still wont' run test the motor.
Nov 05, 2013 | Dyson DC07 Animal Bagless Upright Cyclonic...
It will not turn on.... is there a reset button
Check the cord to make sure you are getting power to the switch, if so check the switch to make sure you are getting power through the switch. If so, follow the power to the motor to see if you are getting power to the motor. If you are getting power to the motor and it still will not run it may need a new motor.
Sep 19, 2013 | Dyson DC27 Bagless Upright Vacuum
Hoover spirit 900 canister wont turn on?
see this causes and fix it. God bless you
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced
If the vacuum cleaner motor doesn't run the on - off switch might be turned off or defective. Test the switch with an Ohm meter or continuity checker.
Sep 27, 2012 | Hoover Vacuums
Beater bar motor quit, now the main motor quit. Replaced the on/off switch. still nothing
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced.
Sep 27, 2012 | Vacuums
Power is not coming on
Sep 27, 2012 | Wagner Spray Tech Wagner 915 1,500-Watt...
Has no power
Does the switch feel like it "clicks" when you turn it on? might be a bad switch. If the motor went bad then it's lights out for that vac.
Jun 09, 2012 | Eureka 3276AZ Pet Lover Bagless Upright...
The motor on my carpet tool (beater brush) stopped running yesterday. The main vacuum still works, but the switch for the carpet tool just clicks and doesn't turn it on.
Knowing the model would help.
Possible problems:
Broken or disconnected wire in hose, connections, power nozzle.
Hose needs replaced. Check all connections for discoloration and cracked supports. Have power nozzle checked at a vacuum shop. Depending on the model, take it to an authorized Aerus Electrolux store for this.
Bad power nozzle motor Needs replaced.
Bad switch. Take the whole machine in for thorough check and repair..
Jan 25, 2011 | Electrolux Vacuums
No power
There is a safety switch in the motor area that, if not engaged correctly, can result in your vacuum not running. The most common thing that's wrong is that at the bottom part of the motor, where the cord plugs in, the cord is in between the motor and the plastic holder for the bag and it's not letting the bag click on all the way and so it's not pushing in the safety switch enough for it to turn on. Also, you may want to remove the head and reattch it and make sure it's lined up properly. If none of this works, then you could have a cord problem or your safety switch might be out. These are very fixable problems. Find your nearest vacuum repair shop. A cord should cost no more than 30 dollars and a switch with labor will cost around 80 dollars. If you can't find anyone, contact us at 1-866-509-1952 and we can help.
Apr 19, 2007 | Kirby G5 Bagged Upright Vacuum
Vacuums Logo
52 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
