Question about Baumatic B905SS Stainless Steel Electric Double Oven
Loud noise from Baumatic B905 oven whilst cooking and after.
Loud noise from the oven whilst cooking and after. Control panel hot to touch even if the oven has not been on
  • sweetness_li Aug 01, 2010
    Thanks for your help, as far as I can tell it doesn't have a self-clean feature :( do you think it is more likely to be the sensor then?
  • 50 Answers
Not that familiar with the brand but in other case have fourn the board to be engaging the self clean. not a good sign. and for this model i would think very costly. wishful thinking says the oven temp sensor but i think you have a fauly board. get the same thing with alot of frigidaire ranges.
Posted on Aug 01, 2010
My Baumatic BS65MS oven is cooking too hot, it burns everything. I have turned down the temperature, this doesn't help. What would be the problem?
You may have a stuck thermostat and that should be replaced because he's probably telling the other keep eating even though the temperature the temperature would be correct
think your new oven is too hot or too hot or too cold, you can adjust the temperature yourself to meet your specific cooking preference. You can also adjust your thermostat if your oven is not new, since thermostats may "drift" from the factory setting over time. See the "Adjust the Oven Thermostat"
Mar 18, 2018 | Baumatic Ovens
Why is there a loud noise coming from control panel when I turn on the oven?
How often does it happen? Sounds like your control board is starting to fail. The Repair Shack can fix the oven control board if it needs repaired.
Nov 29, 2015 | GE Profile PT916SRSS 30" Single Electric...
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
I have just purchased a Double Oven model D.O.D 788x5 very happy with it except it is very noisy whilst cooking it sounds like a fan is this normal I purchased this from John Lewis M.K. I feel that the...
This is quite normal.
Most ovens are fan assisted these days it gives more even temperature distribution and faster cooking times.
You will probably get used to the noise fairly quickly.
Dec 15, 2010 | De Dietrich Ovens
Oven does not heat up in fan oven mode but fan runs. works fine in convection mode. Baumatic B723SS-A
whilst the fan is running the heating element which is usually in parallel with it should heat.. This usually means a faulty element..
Dec 17, 2009 | Baumatic Ovens
Baumatic oven not heating up
I have the same model steel finish was looking for parts mysel and came across yr dilema... I had that problem before . I always turn left knob to fan.. turn heat to whatever say 200 then click the button with the hand signal and i never touch any other button it alays does the job for me.. i cant cook so never need to touch ant other button ,,,, its a timer issue that stops it heating up swtch it all off at spur or mains start it up again
DamienPJennings@aol.com hope this helps
Jan 13, 2008 | Ovens
Odd loud fan type noise
what you are describing is the cooling fan. That fan will come on to keep the electronic control panel cool. It is normal for tat to come on even if your done with the oven. I dont think is should be as loud as you describe. I would try the oven again and if it is still loud I would call for service because it is new. That fan will also come on when you use the self clean cycle.
Jul 25, 2007 | Frigidaire PLEB30T9DC Electric Double Oven
Baumatic B905SS Stainless Steel Electric Double Oven Logo
198 people viewed this question
Top Baumatic Ovens Experts
Starnley Johnwells
Starnley Johnwells
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
