Question about Maytag Dishwashers
Maytag eq plus dishwasher- how to disassemble bottom spray arm?
I have a maytag eq plus dishwasher and want to clean the inside components as we have hard water and dishes are not getting completely clean. Can anyone advise on how to take apart bottom spray arm (propeller shape)? Thanks. Paul
  • 50 Answers
Its probably leaving water in it and is clogged in the elecric pum or drain hose. somethins the pump has a rubber flap that will become lodged in the outlet port. this will cause dirty water to be left in the machine because of a slow drain. start by looking at the volume of water coming into garbage disposal where drain hose hooks up.
Posted on Aug 01, 2010
Maytag jetclean dependable quiet plus doesn't clean dishes
It sounds like you have a faulty float switch. It's cutting off the water inlet before the tub is full.
May 26, 2012 | Maytag Dishwashers
Maytag Jetclean Dishwasher EQ Plus, Model MD87100AWW making grinding noises 20 minutes into wash cycle.
You have debris down in the pump area. To get to the problem you will work from inside the dish washer and start by removing the spray arm and then using torx driver you will need to remove upper components of the pump/motro assembly to get to the debris. good luck
Feb 28, 2010 | Maytag Dishwashers
Maytag eq plus, not cleaning properly, seems the
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
h
Feb 28, 2010 | Maytag MDB7100AWB Dishwasher
Dishes on the top rack not cleaning properly
Had similar problem with our Maytag dishwasher--we removed all spray and screen components to the inner case, cleaned the intake screen below the lower spray arm, repaired a split upper spray arm, and inspected everything for cracks or other distortion. All of this helped some, but finally improved things by changing from liquid detergent to a "packet" type. Our water is somewhat hard and builds deposits on the screen at the bottom. Run a no-dish cycle with a cup of white vinegar in the bottom.
Aug 07, 2009 | Maytag MDB9600A Jetclean II Built-in...
I have a mdbd880aww model and it seems that the
The pump and impeller needs cleaning or replacing.
Remove the spray arm and base to access the impeller and pump inlet for cleaning and inspection..
Mar 26, 2009 | Dishwashers
Maytag jetclean eq plus dishwasher: soap problem
This could be due to 2 problems: not enough water or water is not being pumped hard enough through the system. The 'not enough water' is easy to check - open the door in the middle of a wash cycle. If you have enough water (about 1" or more) then that is probably ok. The 'not pumping hard enough' could be as simple as plugged up filters and holes in the spray arms. Remove the racks and disassemble the lower spray arm and the filter assembly all the way down past the screen. Clean the arm holes, throughly clean the screen, clean everything. Pull the top spray arm and throughly clean the spray holes there. Put it all together and run a cycle. You should see a pronounced increase in the sound of the water spraying around. This should fix your problem - it did for me.
Mar 11, 2008 | Dishwashers
Maytag jet clean dishwasher model# dwc7400aaw
Normally when you have low water pressure and/or cleaning issues, this an indication of a clog in your main wash pump. You will need to remove the lower spray arm and the coarse screen to get to the main wash pump sump. Inspect the impeller area of the pump. This area is usually where accumulations of debris collect and keep the pump from pulling enough water. Things like orange seeds, lemon seeds, bottle cap liners, chicken bones, and jar labels are just a few of the items I have personally found. Although, dishwashers do a good job at removing most food particles, they are not garbage disposals. I bet you will find a clog in the sump somewhere. Let me know if this helps.
Jul 31, 2007 | Jet Tech Systems STEALTH Dishwasher
Maytag Jetclean Super Quite Plus II Dishwasher
open the door when working and check the spray arms are rotating. if not, the jets in the spray arms may be blocked. very fiddly to clear but doable
Apr 07, 2007 | Maytag 24 in. MDB5600A Jetclean II...
Dishwashers Logo
491 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
