Question about GPX MW3837 MP3 Player
ERROR AND 0'S ABOVE AND I T S SHOWS UP
IVE BEEN HAVING THIS PROBLEM REPEATEDLY WITH MY mp3 Player
The GPX MW3837 1GB
  • godchild5 Apr 29, 2008
    my mp3 will play songs and when it gets to the twenty fiftth one it reads error and jumps back and forward between the number of songs it won't play and i've only had it for 2 weeks now
  • 8,596 Answers
Make sure the songs are in the correct format, and that they were not downloaded from Limewire
Posted on Jun 20, 2008
Playing by album
To change the play mode on the GPX ML648B you need to play a song, hit the MODE button on the side of the player and select Play Mode.
The options are INTRO (this will play about 10 seconds of a song and then go on to play the next 10 seconds of every song.) NORMAL which will just continually play through everything on your device, Repeat One, which will repeat one song, FOLDER which I'm not sure of, FOLDER REPEAT which I assume repeates a folder, REPEAT ALL and RANDOM.
May 19, 2010 | GPX ML648B MP3 Player
Is there a manual on line for this media player? GPX ML759
www.manualsonline.com/ex/thread/view/idThread/2630903 -
this should get you right were you want to be
happy hunting
May 15, 2010 | GPX ML759 Digital Media Player
Screen shows flash error to format
you should reinstall the firmware in the mp3 player
to do that you can go on the mp3 manufacture's website click on support and look for the appropriate firmware that fit your model number
once it's download
plug your mp3 to your pc and then run the firmware updater
you should be able to use your mp3
good luck
Jun 19, 2009 | GPX MW8847DT MP3 Player
Have GPX MP3 player MW3847. Plays out of sequence, eg. plays track 1,3,5,6,4,2 instead of 1,2,3,4,5,6. How can I correct this? Thanks.
Press the 'R' button on the right side (above 'EQ') to cycle through the Repeat modes. Now it is set to 'shuffle' (or random mode).
Jun 07, 2009 | GPX MW-3847 MP3 Player
Window xp
strange. i went to their site and shows drivers for 98 and me not xp.. must be a upper and lower filter issue that wont let the device to be recognized properly
www.gpx.com/store/p/185-MW3847.aspx
Oct 10, 2008 | GPX MW-3847 MP3 Player
ANSWER QUICKLY PLEASE!!!
There could be more than one reason - the most likely is that the HOLD button has been engaged. Your USB port may not be 2.0 - try a different usb port on your computer. You could be running Windows Vista or some other incompatible OS. You may have forgotten to download the install CD. The following information is straight from GPX themselves:
"What if I cannot troubleshoot an error message?" You will need to format your player. Connect the player to your computer using your USB cable. Make sure the HOLD switch is in the unlocked position.
Formatting can be done in two ways:
  1. Within the Start menu, select My Computer. In the My Computer folder, right-click on the icon representing your GPX player. You will be given a list of options. One of them will be to Format your drive. Click on this to erase everything on your GPX player. A warning will pop up to make certain that this is the choice that you want to select. Once your player is formatted, reload your music files onto your GPX player.
  2. Open Windows Media Player. In version 10, open the Sync tab. On the right-hand side, there will be a listing for GPX audio player. Just above this and to the right are a set of four icons. The icon furthest to the right represents, “Format storage media.” This icon resembles a pencil. After formatting, synchronize music to the player. In version 11, open the Sync tab. On the far left column, there should be a listing for GPX Audio Player. Right-clicking on this listing will result in a menu containing Format. Select this to erase everything on your mp3 player.
Here is a useful link:
http://www.gpx.com/store/p/187-MW238B.aspx
Jun 23, 2008 | GPX MW3837 MP3 Player
Gpx mp3 player 2 giga bytes
the download was no good
Apr 25, 2008 | GPX MW3837 MP3 Player
GPX player just showing a blue screen
IM NOT SURE WITH THE ERROR THATS WHAT IM TRYING TO FIX ON MINE!
BUT JUST HIT THE RESET BUTTON ON BACK IT SHOULD TURN OFF
Apr 23, 2008 | GPX MW3837 MP3 Player
Startup with ERROR with counter
Without more information I can give you the problems I found when my mp3 does that and it is the same one you have. You have one of 2 problems either write protected songs you have downloaded onto the mp3 or and this has happened to me a lot of times you have downloaded some wma's that the mp3 cam not read. I know ower owners paper said it does wma's but if you read it, it sais most wma's. Well I fould if I can help it I use real play and make it download in mp3 where I have found I have not had any problems. Let me know what happens. I would reformat the mp3 download in mp3
Sep 18, 2007 | GPX MW3836 MP3 Player
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
