Question about Kenmore 65212 Bottom Freezer Refrigerator
Water from defrosting leaks into the bottom of the freezer and freezes into a solid sheet of ice, which I chip out every 1 to 2 weeks. Kenmore bottom freezer refrigerator Model 795.65002400.
    President:
  • 1,099 Answers
If water leaks inside your refrigerator
(and it WILL, at some point) you can fix
it yourself.
In the good old models, one had to defrost the
fridge every few months manually.
In the recent models, the fridge defrosts automatically,
once or twice a day, and the water is supposed to drain
down a long drain tube into a pan located at the bottom of
the fridge. This collected water in the pan evaporates
by the heat under the fridge.
Now the drain tube can get clogged, by food debris and/or
ice. Thus when the water cannot drip through the drain tube
the water drips inside the fridge.
The drain tube is located behind the fridge, which is pretty
easy to take it out and clean. However usually the clog is
not in the long tube but in the connector assembly located
in the backside of the fridge that leads to the long drain tube.
To get to the connector assemble, you need to unscrew and
take out the back panel of the freezer compartment. You would
see the evaporator coil and a tray under the coil where the water
is supposed to drip through. If you find the tray completely frozen
with ice, let it melt off. To speed up melting, you may blow
hot air via a hair dryer. Once the ice is clear, you should see
a drain hole in the middle of the tray. This could be clogged,
which needs to be unclogged.
Next unscrew and open the thermostat control assembly located
in the inside of the back of the refrigerator compartment just above
the light bulb fixture. Once you take the take the cover off (you will
also have to take the knobs out) you will see a small tray cup about
2" x 2" x 1/2" into which water from the top freezer compartment
drain hole is supposed to drain. Pull out the tray cup, and if clogged,
unclog it, clean it and put it back.
To check if the drain works ok, pour some water on the tray
under the evaporator coil (top freezer compartment) and see if it
immediately drains into the tray located at the bottom of the fridge
at the floor level. If it does, you got it; and you can assemble things
back in the reverse order you took the pieces apart.
Needless to say, use a vacuum cleaner with a long suction tube to clean
out all the collected mess under the fridge. No matter how good
your housekeeping is, the bottom of the fridge will be full of dust.
Good luck and hope this helps
Posted on Aug 01, 2010
There is a solid sheet of ice on the bottom of freezer, what is causing that ?
You freezer is going through the defrost process but the excess water is not being eliminated from the unit. My freezer does this and I usually have to manually defrost it at least once a year otherwise the water backs up and freezes internally.
Jun 27, 2018 | Refrigerators
Whirlpool GX2SHBXVY05 refrigerator leaking from bottom freezer onto floor.
if it has an ice maker check the water feed hose for leaks.
also I have a freezer that ices up twice a year. poor design. have to defrost every now and then.
Jun 09, 2015 | Refrigerators
Bottom of the freezer keeps filling up with water and freezing solid. eventually leaks thru the door onto the floor. It takes 3 to 4 weeks for it to form thick enough to eventually leak thru the door on to...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? it overflows into the ref.
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Jul 27, 2011 | GE GSS25JF Side by Side Refrigerator
There is at least 3 to 4 inches of solid ice at the bottom of fre
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jul 12, 2010 | Kenmore 53552 / 53554 / 53559
REFRIGERATOR LEAKING WATER INSIDE THERE IS NO
Remove the food and remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you
see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Nov 07, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice at bottom of freezer
Make sure defrost drain is completely cleared of ice and anything else obstructing it. Pouring hot water in it is correct, but make sure it is going all the way through to defrost pan under unit.
Oct 11, 2017 | Kenmore 52632 / 52634 / 52639 Side by Side...
Freezer has 1/4" ice on bottom, everyhing in freezer solid rock.
Your freezer should have a drain located in the bottom rear, usually behind an access panel that allows water to drain into the pan under the unit during the defrost cycle. If this drain becomes plugged, the defrost water has no place else to go but into the bottom of the freezer and turn into a block of ice. Clear the ice and poor hot water down the drain. You may also want to fish something (I use 1/4" water line) down the drain until the end gets to the pan underneath just in case there was something more solid stuck in the drain.
Mar 21, 2009 | Refrigerators
Leaking water from kenmore freezer to refrig below
its possible that the drain pan behind the back freezer wall is clogged or coverd with ice, sounds like when unit goes into defrost melt water leaks under sides of drain pan and into fridge. unplug and remove back freezer wall if drain is covered with ice defrost the ice, can be prevented by loosely coiling a piece of solid copper wire around element and into drain slightly radiant heat during defrost should keep drain fromicing over. if drain is just clogged wth debris clean drain and you should be good to go, hope this helps you.
Mar 14, 2009 | Kenmore Refrigerators
Kenmore, bottom freezer, ice bldup in frzr til leaks on floor
The freezer will defrost itself periodically depending on the run times of the compressor. This is determined by the defrost timer and will shut the unit off and turn on a heater to thaw the frost buildup. The resulting water is then channeled to the defrost pan which rests on top of the condensor coil under the freezer section or on top of the compressor, (depending on manufacturer design). The tubing to the defrost pan could be plugged or kinked off. You may also need a modification kit installed to keep the defrost drain trough from freezing over. I would suggest you consult a local technician for advice in this area. Also, make sure all doors are sealing properly as an air leak will cause excessive frost build up and will have a tendency to freeze before it can all drain out, then any successive defrost cycles will overflow the trough and run out the front.
Nov 14, 2008 | Kenmore 63222 / 63224 Bottom Freezer...
Kenmore 25.8 side by side with water freezing in the bottom of th
It sounds like the freezer drain is plugged up. When the frig goes into the defrost stage it melts the frost biuldup on the evaporator and the melted frost goes down a drain that is behind the evaopator cover. When this dran is plugged the water has no place to go and over several defrost cyles will actually run into the bottom of the freezer section. When the defrost cycle is over and the frig starts cooling again, the water freezes in the bottom of the freezer.
Nov 11, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore 65212 Bottom Freezer Refrigerator Logo
416 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
