Question about ASUS K8V-SE Deluxe Motherboard
Speakers humming bad
What can cause the speaker output to hum really bad on this????
  • 487 Answers
Your fan can make it hum and or a bad ground connection
Posted on Apr 26, 2008
Stereo has no power it's not very loud It makes a humming noise in the speakers when the power is off
The most likely cause of any humming is caused by Electrolytic Capacitors, especially as these hold a charge when the power is off. They could be connected with the power supply of the audio power amp, or in the output stages, which would explain the low volume too.
Dec 15, 2015 | Audio Players & Recorders
Hi, I have a B&O beocenter 1800 with a really load hum on the right hand speaker. This occurs on both radio and turntable. I have swapped speakers and cables and hum stays with RHS speaker output
this old timer probably has an output amplifier fault.with a circuit diagram any competent engineer shoulb able to locate the problem with the turntable removed access is easy and so is replacing parts
Nov 19, 2013 | Bang and Olufsen Audio Players & Recorders
Esw-c10 subwoofer hums and dont work
if you short a sub it will hum try connecting it to a working speaker (no amplifier) if you have access to rear of sub check for wire only needs to be the size of a hair arcing out the speaker, i have a sub that does that on only one output (left rear) its actually the stereo causing it to hum..
Jun 20, 2012 | Energy ESWC10 Subwoofer Speaker
How do I GET THE HUMMING SOUND OUT
Hello
The audio output section of your tV has the fault. The main reason for HUM on output, is due to a shorted audio output IC. Never use the TV, until the fault has been rectified. Prologed use at this state will damge the speakers, and speakers may also be replaced. OK.
Feb 02, 2012 | Sansui Televison & Video
About a month ago my speakers started humming-does't matter if the cable/dvd are on, as long as the receiver is on it hums. Figured out it was the receiver since I plugged other speakers into my...
normally a Hum is caused by a bad ground,, if it only happens when the unit warms up it could be the output drives are failing. , check the grounds to the unit first, then the wires to the speakers themselves, if they all check out ok,, you need to take it to a repair shop dealing with receivers
May 27, 2011 | Yamaha RX-V1600 Receiver
Speakers started making a humming noise
HI:
Usually with audio humming, the cause is due to a bad capacitor on the amplifer portion of the unit. Bad filter capactor in the AC power suppy will cause whats known as AC ripple to enter the system causing motorboating sound or humming. Have the unit check by a technician for poor regulated DC voltage.
May 21, 2011 | Altec Lansing VS2421 Main / Stereo Speaker
Causes a hum on speakers
Hum on the speakers usually indicates that there is a DC voltage on the speaker line. DC voltage on the output lines would be caused by a shorted output transistor.
Jul 17, 2009 | Bravo OH-08F 8 in. Car Monitor
No sound coming from speakers
check the speaker connections for any short circuit and also for polarity.
check if mute is highlighted on the screen
check if the audio output of the player is properly connected (optical / coax or RCA
this should solve your problem
If not tell me your connection configuration with regard to input output.
Regards David
Jan 31, 2008 | RCA RT2600 System
Hum coming from speakers
Faulty wires/ connections are the usual cause of hums on speakers. Try checking if the wires are properly connected. If it still hums, try replacing the wires with a known good wire.
Nov 20, 2007 | Audio Players & Recorders
ASUS K8V-SE Deluxe Motherboard Logo
60 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
