Question about Liebherr KGK 2233 Comfort
I have a new Liebherr refrigerator. It says to bleed the water line to the ice maker. How?
  • 50 Answers
Not familiar with brand but you will pop a cover off the icemakerfront and either push dial to start or jumper it some how. some models cant be jump started but i assume if you must bleed it then it has to have a way to start the icemaker.
Posted on Aug 01, 2010
Liebherr ice maker not making ice. Switched on but nothing happening
Hello Irene Booth,
There are several things you can do to check the suitability of your freezer settings ... (eg: if you put a small container of water in the freezer...
Is it mostly frozen in about 45 minutes??
Things that would aid in trouble shooting...
Liebherr nomenclature: model number...???
New... or new to you?
Had previously worked... Never worked.
General observations... Frost forming in back of freezer area
Doors square and fitting properly...
Gasket in full contact (visibly) all the way around the freezer door/drawer... and is in good condition
- (can physically check by pulling a dollar around the gasket).
If the Ice Maker has EVER worked ... We can skip the basics of checking the water supply is hooked up and TURNED ON.
If you can fit your fingers in the ice tray to feel for water or ice in
the tray ... that would also be helpful.
Finally... for new models... check that all packing tape & materials around the ice-maker have been remove.
Although your model appears to be a TWIST TRAY type of ice-maker... there is still a sweep or fill bar that is supposed to check the fill level of your ice bin.
A single chip of ice can hold that from moving freely... your ice maker will not work ... !!
Hope this helps
Carnac the Magnificent
Jan 04, 2017 | Liebherr Refrigerators
Where is the water filter for Liebherr CI1650 located?
There isn't a water filter. You should install an inline filter to the water line that comes in to feed the ice maker.
Jun 18, 2014 | Liebherr CI1650 30" Built-in...
After changing the filter the ice maker would not work.
It needs to get the air out of the line before the water will fill the tray. When the line is opened up air will get inside and needs to bleed out first. On units with a water dispenser it is good to run it after a filter change to make the ice maker usable faster. An ice maker times the water for a fill not the amount of water since it uses a pressure regulator, so it does not know there is air in the line.
Sep 29, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice maker doesn't work
check to see if ice maker timer is working by running a piece of scotch tape from the arm to the case of the ice maker (make sure tape is just barely attached) then wait to see if tape is dislodged. if the ice maker is working, the arm will raise every 45 minutes or so, dislodging the tape. in this case the problem is most likely the water valve.(unless you can still get water from the door, then it's probably just that the line is frozen where it enters the freezer.) if the tape is not dislodged then you can either get a new timer for your ice maker(not always available) or just buy a new ice maker. either way you can get the parts you need here: http://www.appliancepartspros.com/partsearch/
Aug 14, 2009 | Liebherr Refrigerators
Flushing water hook up to Ice maker
I would go through 2 trays of ice to flush. Also if you have a door water dispenser go through 2 gallons that way to clean line.
Apr 12, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Air in water line how to bleed out
the frig ha a plastic resivor that has air in it
you can bleed the line by continuing to use the water dispenser and diverting it into a pitcher
you can make a transfer funnel etc out of tin foil should not take more than 2 containers ( 1 /2 gal each)
Dec 11, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Icemaker in Admiral side by side refrigerator/freezer stopped working
see if you can bleed the air trapped in the water line to the ice maker. if air is trapped, water would not be flowing and it would take only a few seconds for the solenoid to be open to let water flow.
see if you can hot wire the solenoid to let water and air out of the tube long enough to bleed the air and hopefully, the ice maker would work continuously.
tnx 4 using fixya,
drcool
Oct 08, 2008 | Admiral 26 cu. ft. Side-By-Side...
Liebherr KGK 2233 Comfort Logo
469 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
