Question about Enlight Combo (5601908) (Beige) (5601908) CD-RW/DVD-ROM Combo Drive
How do you fit a new engine cooling fan to a combo van
    President:
  • 2,571 Answers
Try look for your CAR manual in google, or in the Motor/car section of fixit.
This is the PC/dvd burner section
Posted on Aug 01, 2010
Even with a fully charged battery i need to use a battery pack to start the van when it does start the cooling van comes on for a minute then goes off and that continues
Check rear AC in van and turn it off. Most vans have dual AC. Even if the front AC is off, the rear is still usually on and some vehicles have the cooling fan and condenser fan run together to help with cooling. Check relay and fuse also.
Jun 10, 2017 | Cars & Trucks
2002 Lincoln Continental - overheats
have a compression test done to check for head gaskets/cracks. check thermostat fitted correctly. If there is a viscous fan hub then replace it. if the bottom hose stays cool that indicates a blockage and that if the radiator is off the shelf new points to a thermostat fitted the wrong way . over haeting at lights goin slow or working at high rpms while loaded points to the fan hub. If electric fans then it points to the fact that they are not coming on. check ignition timing as a spark after TDC will cause overheating.. If at speed it over heats then check over drive operation as over reving the engine will also over heat the engine.
Dec 27, 2014 | 2002 Lincoln Continental
98 Olds van, how does the high/low cooling fan work?
I'm showing three fan relays in the wiring diagram.
The fans are powered by two 30amp maxi fuses. The relays and fan motors are grounded thru the engine computer. The computer takes input from the coolant sensor and the ac control to decide when fans are needed. You would need to know if the computer is grounding the relays, and if not, why not. You may need a scanner to monitor computer output.
Jun 28, 2013 | 1998 Oldsmobile Silhouette
1999 dodge caravan gauges are all mest up
Could be different problems.
The cluster issue could be a problem in the printed circuit board inside the cluster.
The cooling fan problem could be low coolant, a blown fuse, a faulty temp sensor, fan motor, or relay.
Jul 07, 2012 | 1999 Dodge Caravan
It starts fine, runs good until the engine heats u...
Check to see if the radiator fan is coming on when the van gets hot.If it does not then on a 2.6 liter engine.look on the bottom part of the radiator on drivers side for a fan switch that could be bad and not letting the radiator fan to come on. On a 3.0 liter engine the coolant temperature sensor is screwed into the thermostat housing. And on a 3.3 liter and on a 3.8 liter engine the coolant temperature sensor is screwed into the front cylinder head. Anyone of these can cause the van to run hot and eventually die with no restart until the temperature has cooled down. Check the fan first with two jumper wires from the positive/negative post to the fan connector on a 2.6 liter engine (positive wire to open pin on plug,negative wire to insulated plug side. On all v6 engines hook jumper wires to motor. To the left side will be positive and negative to the right. Do not let both wires touch together while testing. If motor does not respond to direct wiring then replace it. Another thing to look at is the catalytic converter on van. Check the exhaust flow when the van is running cold and again when it gets hot. If the flow starts to slow down when the van gets hot then remove the converter(plugging up). After doing that run the van again to see if the van runs ok. Hope this will help you.
May 20, 2010 | 1984 Dodge Caravan
Engine cooling fan
you will need an electric fan fitted to the radiator and bear in mind that you will need the appropriate voltage reading etc,so you need the right power source.Also you need to consider a thermostat fitted in the cooling system unless you want to run it on direct power.For any questions,please ask.
Aug 25, 2009 | 1991 Toyota Previa
Overheating
Your overheating problems can have several possible causes.
1) Airlock in heating system - solution - bleed air from cooling system.
2) Radiator blocked - solution - drain and flush radiator
3) Failed waterpump - solution - fit new waterpump
4) Engine thermostat stuck in closed position - solution - fit new thermostat
5) Electric cooling fan (if fitted) failing to operate - solution - check fan, fan operating switch, all wiring and connectors
6) Not enough coolant in system - solution - check and top up to required level. Also check all hoses for sign of leakage.
7) Faulty temperature gauge giving incorrect reading.
Jun 21, 2009 | 2001 Jaguar XJ8
Astravan cooling fan problems
When cold, remove plug of the temperature sensor usually found at the top of the radiator (but may be on thermostat area)
Check sensor with a meter - should be normally open (non conducting)
If faulty, fit a replacement. (undo cap of coolant system, then retighten, undo and replace sensor quickly to avoid too much coolant loss, then top up system.) You can drain the system, but sometimes causes airlocks and more problems.
May 18, 2008 | 1998 Volkswagen Beetle
Enlight Combo (5601908) (Beige) (5601908) CD-RW/DVD-ROM Combo Drive Logo
53 people viewed this question
Top Enlight Computers & Internet Experts
gaucherre
Raymond Solomon
Level 1 Expert
Martin Clarke
Martin Clarke
Are you an Enlight Computer and Internet Expert? Answer questions, earn points and help others
