Question about Magic Chef MCBR440 Compact Refrigerator
Magic Chef MCBR445W1 seems like it dosen,t stop
Magic Chef MCBR445W1 seems like it dosen,t stop cooling and freezes everything. Is this the thermostat?
    President:
  • 1,099 Answers
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Check on the cold control if faulty, replace the cold control, not having found any other problem, do check on plastic air deflector at the top rear of the frig had been knocked off. replaced it if faulty. As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control, which is now functioning properly.
Good luck.......
Posted on Aug 01, 2010
Magic Chef mini frig freezing everything.
The thermostat is part of the temperature control found on page 6 here=> MCBR445S1_Parts_List Parts can be found here=> MCBR445S Parts If you have questions please let me know, Thanks Sea Breeze
RF-7350-59 Temperature Control Thermostat
Dec 09, 2012 | Magic Chef MCBR445S1 Stainless Steel...
I have a 2 year old Magic Chef MCBR445W1 compact refrigerator. When I plug it in it starts and gets good and cold inside. When it reaches the required cold temperature setting it stops running as it s
  • fixdit4real 1 solutionsJun 15, 2011
Ok In the rear bottom where the wires plug into the compressor. There will be a plastic cover plate over the connecting wires. Remove it. Unplug the white wire. note the white wire was plugged into a small black box (3/4"x3/4") pull the black box out. It is connected by 2 prongs. If you open this up you will find a small metal disk that looks like a watch battery. pop it out and clean the contacts. put it all back together and it should work fine. I believe it is the thermostat and many times gets bad contacts and can even crack over time. The compressor will "click" on but the bad thermostat tells it "no"
Mar 23, 2012 | Magic Chef MCBR445W1 Compact Refrigerator
This was working fine, then stopped working. The motor gets hot, but nothing else happens. It used to click a bit when I plugged it in and started working, no sound now, it seems dead. Is this worth...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 09, 2011 | Magic Chef MCBR445W1 Compact Refrigerator
It is making a tic toc noise. It is not refrigerating. The model is : Magic Chef MCBR445W1 Thanks
the noise is from the ptc overload relay located in the lower rear on the compressor,its a safety component that aids in starting the compressor and shuts it down if the compressor overheats,unplug it off the compressor and get an exact replacement and the unit will again cool and stop tick-tocking
Mar 03, 2011 | Magic Chef MCBR445W1 Compact Refrigerator
My Magic Chef refrigerator has stopped cooling. When I unplug it for a few days, and then plug it in, it will work for about a week, and then quit cooling again. The freezer is perfect, and continues to...
The most likely cause is that the defrost system is not working. After about a week it builds up with enough frost to stop the cold air from getting to the refrigerator section. The most common problem is the defrost timer, defrost heater or defrost thermostat.
Aug 26, 2009 | Magic Chef CTB1502AR Top Freezer...
Fridge is not cooling or freezing
can you tell me the model # on the fridge please? the motor is running continuously because it's trying to cool the fridge. it may be a few things, the defrost thermostat, the fan motor itself or the compressor.
Sep 13, 2008 | Magic Chef Refrigerators
Refrigerator problem
I have a Magic Chef 3.6 cu. ft. Model#mcbr3605 thats 3 years old and has stopped working. When I plug it in you hear it start then you hear a "click" and it turns off. If you leave it plugged in the compressor gets hot. Can this be fixed or is it trash ? Thanks in advance.
Sep 01, 2008 | Magic Chef MCBR440 Compact Refrigerator
Magic Chef refrigerator stop cooling
check the fan relay and the compressor to make sure it is still working...if not there is a capasiter you can replace to get it to work again
Aug 27, 2008 | Magic Chef Refrigerators
The thermostat is only thing that controls temp. in your refrigerator...your right on the money!
Aug 12, 2007 | Magic Chef CTB1722 Top Freezer...
Magic Chef MCBR440 Compact Refrigerator Logo
496 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
