Question about Lanzar Vibe 235 Car Audio Amplifier
35 amp fuse
I accidentally blew a fuse because I pulled it out on a wierd angle when I was checking it...I need a 35 amp fuse and I cant find any anywhere....where can I get some..
  • Anonymous Dec 07, 2008
    same here man noone sells the frakin 35 amp fuses its so much bs iv tried go ho audio walmart and radioshak.everyone is like we dont know what your talkin about
    Novelist:
  • 100 Answers
What color is it? If it is Clear or white it is actually a 25 amp fuse. Otherwise, what kind of fuse is it? if it is a regular "little fuse" you should be able to find it anywhere they sell fuses like Walmart. Or you should go to an audio shop and they would have one. Hope you find one.
-Andrew Hawkins
Posted on May 01, 2008
Upgrading to Honeywell wifi thermostat and it won't power up...help!!! Old thermostat was a Honeywell rh7400
If you accidentally touched the red wire to any other wires when you were changing the T/stat it's possible you blew a fuse for the 24 volt transformer on the outside unit. If you cant find a fuse, then the transformer needs to be replaced.
Nov 16, 2017 | Honeywell Heating & Cooling
Would using a 80 amp fuse instead of a 60 amp fuse in a 1993 Geo Metro cause problems with the starter?
It shouldn't be. The starter is going to pull as many amps as it needs. The fuse is to protect the wiring and keep the car from catching fire in case the starter fails and tried to pull more current than it should. That being said you need to change it back. 80 amps is 33% more current than what that circuit is designed to carry. Being that it's a 1993 you should probably be on your 3rd starter by now
Aug 22, 2016 | 1993 Geo Metro
Why don't electric door handles and the trunk opener work?
possibly need to reboot the central control computer.
something only a maserati dealer will have the tool for ?
Apr 16, 2016 | 2010 Maserati GranTurismo S
I have a visonik 800watt amp and i got it from a friend for free and i hooked it up right and as soon as i turned it on the 2 fuses blew then i replaced them and tryed it again and it stoped again so i...
Its the amp, do not put any more fuses in it
you need to get it checked out by a technician.
Its probably a power supply fault or blown output devices.
Hope this helps
Thanks for using FixYa
Aug 02, 2010 | Visonik V2508 2-Channel Amplifier
Reversed cables and blew a fuse. how do i get it out???
I think the needle nose pliers may be best. insted of grabbing by the thin sides, grab it the wide way and gently rock it back and forth. I think this is like a 35 amp fuse, so the holder has to be very tight to keep a good connection. I have one of these, and for two days I thought it was bad untill I pressed the red on button.
Jul 26, 2010 | Black & Decker 750w Power Inverter
Amp not working
It sounds like you either blew a fuse, or you cooked your amp. The fuse on the P200.2 amp is a 30A fuse, and it sits right next to the power, ground, and remote wire connections on the end. Pull the fuse out and see if it's blown. You should also check any other fuses that you have in the car before the amp.
Mar 03, 2010 | Rockford Fosgate Punch P2002 Car Audio...
New amp
Something is def. wrong. did you check the fuses on the amp after the light went out? probly have a bad connection somewhere. check ground wire and power make sure they have a good connection and arent cut up and shorting out.
Oct 21, 2009 | Pioneer Car Amplifier GM-7100M - Mono Bass...
Car amp turned off in middle of play
make sure and check all the fuses including the one under hood also check all wires to see if they are well connected
May 13, 2009 | Alpine MRD-M1000 Car Audio Amplifier
Fuse blew on my Maytag washing machine. 1 amp only and others blow. Time to buy new or service?
yes.you can buy the switch assembly unit. it gets short and the fuse blows out.
May 04, 2009 | Washing Machines
Radio and all dome lights are not working.
interior fuse should be the culprit. Look for the Radio fuse inside (normally 10A red) sometimes labeled CABIN on the fuse layout
Dec 25, 2008 | 1999 Toyota RAV4
Lanzar Vibe 235 Car Audio Amplifier Logo
80 people viewed this question
Top Lanzar Car Audio & Video Experts
Joe Alexander
Joe Alexander
Chris Ward
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
