Question about GE JASRM24912 Remote Control
Need code for slyvania tv & instructuins on how to do it
Which buttons to you use to program remote and which codes to try for a slyvania tv
    President:
  • 1,932 Answers
GE
Manual code entry
1.Turn on your television or other electronic component that you want to program the remote control for.
2.Hold down the "Code Search" or "Setup" button until the LED indicator light turns on.
3.Hit the button for the component that you are programming (TV, DVD, VCR, etc.). The LED light should flicker and stay on.
4.Enter the 3-digit or 4-digit code that corresponds to the TV or device that you're operating.The LED light should go off if the code is valid, but will flash if it is not. Try other codes you have.
5.Try turning the television or other programmed component off to ensure that the remote works properly, once the light has gone off.
Auto configuration
4. Press and release the "Power" until the television or other component turns off while waiting at least 2 seconds between each press.
5.Press "Enter" or "Save" once the remote has effectively turned the power off. The LED light will shut off and the remote will now operate the device.
You can get your codes from below website
http://www.jascoproducts.com/support/universal-remote-codes.asp
Thanx
Posted on Aug 02, 2010
My mother in law just passed away and I inherited back the Sylvania LD320SSX I bought her last year. What is the 5 digit remote code for a Comcast remote? Tried all I could find to no avail.
Comcast uses at least 11 different remote controls. I referred to the manuals listed on their remote control page for instructions on programming the three Comcast-branded remote units:
Comcast Universal Remote (Red OK/Select button)
Sylvania LCD TV codes: 20000, 20035, 20043, 20081, 20593, 21593, 21781
Procedure:
  1. Turn on the TV.
  2. Press the TV button once.
  3. Press and hold the Setup button until the TV button blinks twice, then release Setup.
  4. Enter a five-digit code from the list. If this is done correctly, the TV button will blink twice. If you enter an invalid code, the TV button will produce one long flash and the remote control will exit the program mode.
  5. Aim the remote control at the TV and press the Power button. If you have the correct code, the TV will turn off. If not, repeat steps 2-6 with a different code.
If none of the codes work, you can try the code search procedure:
  1. Turn on the TV.
  2. Press and hold TV. Press and hold Setup until the TV button light blinks twice, then release Setup.
  3. Press 9-9-1. The TV light will blink twice.
  4. Press and release the digit 1. The TV key will blink twice. Press the Power key.
  5. Aim the remote control at the TV. Press CH+ until the TV turns off. You may have to press numerous times until the remote control finds the right code in its library. Stop when the TV turns off.
  6. When the TV turns off, press Setup once to lock in the code set. The TV light will blink twice.
Comcast Universal Remote (Grey OK/Select button)
Sylvania LCD TV codes: 0000, 0035, 0043, 0081, 1781
Procedure:
  1. Turn on the TV.
  4. Enter a four-digit code from the list. If this is done correctly, the TV button will blink twice. If you enter an invalid code, the TV button will produce one long flash and the remote control will exit the program mode.
  1. Turn on the TV.
  4. Aim the remote control at the TV. Slowly Press Power and TV alternately until the TV turns off. You may have to press numerous times until the remote control finds the right code in its library. Stop when the TV turns off.
  5. When the TV turns off, press Setup once to lock in the code set. The TV light will blink twice.
Comcast Digital Transport Adapter (DTA)
Jan 22, 2011 | Sylvania LD320SSX LCD TV
I need the code list for a slyvania tv i have a rcu404b remote..
Your remote is programmed with only ONE code for Sylvania TV . . . 4
http://rcaaccessories.com/remotefinder/?sku=RCU404&productType=TV
I think your remote is fairly old. If your TV is newer than your remote, this code probably wont work.
Please rate this solution if you find it helpful. Thank you.
Nov 03, 2010 | RCA Universal Remote Control
Need remote code for slyvania lc155sl8p
try these
Sylvania 0 0 5 4 ,0 0 3 0 ,0 0 9 6 ,0 0 2 0 ,0 3 8 1
Please apply a rating to my help[++++Thank for using FIXYA
May 21, 2010 | Sylvania Televison & Video
Jumbo remote codes and steps
I have found the iWave, Innovage, and generic "JUMBO" are the same remote.
Here is the link to the manual. It looks like it has a easy to do auto-search button, for TV's not on the list.
http://www.vat19.com/dvds/jumbo-universal-remote-manual.pdf
Good Luck
Dec 16, 2009 | Innovage Jumbo Remote Control
Philips universal remote slo34 code for slyvania tv?
0062 0004 0009 0135 0189 0183 1141 0227 0456 0458 0008 0068 0075 0141 0161
Feb 18, 2009 | Philips Magnavox Learning Universal Remote
Need code codes for universal remote
need codes for universal one for all remote on a slyvania tv
Sep 22, 2008 | Universal Remote Control Remote Control
Emerson EWD7004 DVD
Try the Sylvania codes. If none of those work you will need to resort to the trial and error method (code can range from 000 to 141).
Dec 20, 2007 | Emerson EWD7004 DVD Player
GE JASRM24912 Remote Control Logo
90 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
