Question about Panasonic SA-HE200 Receiver
Stops working and reads Overload
Stops working and reads "Overload" in any mode after working for a while.
    Problem Solver:
  • 11 Answers
Hi there i have had this problem with technics amplifiers generally with them it was negative and positive mix up between input terminals for the speakers or in other case's running the amp with 2 many speakers.
eg. having 2 speakers Bi wired into 1 input making a 6.1 receiver into a 12.1 which makes the amp struggle causing overload or the worst case is a power unit problem.
Posted on Aug 02, 2010
Overload comes up on receiver when sound starts what causes this?
too many cables from outlet , use dedicated power source 12 amp
Aug 30, 2014 | Audio Players & Recorders
Samsung refrigerator error code 8E
8E = OVER CURRENT ERROR
IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
IPM: Integrated power module. The IPM controls the motor.
If the fault (low signal) happens to be sensed even once during the washing/rinsing stage, the motor stops immediately. However, during the dehydrating stage the signal is to be sensed, when the number of signals reads more than 6 per 500ms during the Washing or Rinsing cycle action.
If the motor stops working, in one direction ten times, "8E" Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error "8E" is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power Switch OFF can clear the overload error.
Nov 23, 2012 | Samsung RS265TDRS Side by Side...
E8 front loader washing machines
OVER CURRENT ERROR - Display shows 8E.IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
HOWEVER, the UK White goods website says:
E8
Temp too high on low temp washesNormally this will be the wash temperature thermistor or NTC that's faulty, please contact us if you need the thermistor with the model and serial number.
You can find more about your Samsung Washing Machine error codes at:
http://www.keepingupappliances.com/repair-help/appliance-repair/washing-machine-help/samsung-washing-machine-error-codes/
or
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3069-samsung-washing-machine-fault-codes.html
Jun 21, 2011 | Samsung Washing Machines
Hi, the machine only works for like 5 seconds before it stops and the beeping sound comes on. Its the same for any mode (wash, rinse, soak, spin). The water works fine, only that the machine stops and...
MAybe the motorr is on an overload, check to see if the motor is heated and running slow, check the capacitor, replace and test. Check if there is friction on the spindle. Finally the programm controller by itself can be a suspect if all the above seems OK.
Sep 16, 2010 | Washing Machines
1996 honda accord a/c blows for a while then stops
like the fan just quits? you could have a worn fan (blower motor) causing the unit to heat up and go into some kind of thermal overload protection mode.
Nov 17, 2009 | 1996 Honda Accord
My samsung washing machine model WA13513 13.5kg load had 8E error message popping out from the screen. Is the computer board damaged?
OVER CURRENT ERROR – Display shows 8E. IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
If the motor stops working, in one direction ten times, “8E” Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error “8E” is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power SIW OFF can clear the overload error.
would advise calling a tech... hope this helps.
Oct 25, 2009 | Washing Machines
E8 error code
8E - OVER CURRENT ERROR
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 02, 2009 | Washing Machines
Message on screen 8E, Motor won't start on spin cycle. Model no Q1435(C/S/V)
This is what I found:
11. OVER CURRENT ERROR - Display shows 8E .
- IPM fault signal (that is caused by the overload of MICOM INT0 during motor action) is sensed.
IPM : Integrated power module. , IPM controls motor.
- If the fault signal (low signal) happens to be sensed even one time during cleansing/rinsing stage,
the motor stops immediately. However, during dehydrating stage the signal is to be sensed
when the number of signal is more than 6 for 500ms.
- During Cleansing or Rinsing
When the overload is sensed, the motor stops immediately and then proceeds to the next water-flow action.
If the stopping of the motor working is happens in one direction ten times,
- During dehydrating
When the overload is sensed, the motor stops to work at once and then feeds back to the initial
When the feed back is continuously happened 2 times, "8E" Error is displayed
During the dehydrating unbalance sensing, No error happens by overload sensing.
-Power S/W Off can clear the overload error.
in short: imbalance problem
In a german forum one guy solved the problem by replacing the motor electronics. I am currently experiencing the same problem. I keep you posted.
May 08, 2008 | Washing Machines
It just starts and stops after few seconds ...
It sounds like either the compressor is bad, or the overload and relay assembly mounted to the compressor is bad. The easiest way to determine which is to put an amp meter on the power wire to the compressor assembly. It should only read a few amps while running. If it reads excessive amperage, you have a bad compressor. If you do not have an amp meter, then you could just go get a start relay and overload from a parts store and try changing those parts, as they are much cheaper and eaiser than changing the compressor....just unplug it before messinfg around inside the overload cover on the side of the compressor! Good Luck!
Oct 10, 2006 | Bosch Exxcel KSR34423 Refrigerator
Panasonic SA-HE200 Receiver Logo
270 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
