Question about PfaFF Tiptronic 2030
The memory board went out on my 2000 tiptronic 6270 a couple years ago. now the machine won't sew at all. the sewing light comes on, but not the lighted digital readout area. so , no sew. how do i fix this?
  • 8 Answers
There is a fuse in the the base plate
that has probably blown. It is soldered in and needs to be fixed by a Pfaff dealer on someone with access to the fuse. If you have the work done, make sure they replace a certain reisitor on the base plate at the same time to prevent this from happening again (per Paff). Sorry for the inconvenience, hope you are back to enjoying your Pfaff machine real soon.
Posted on Dec 17, 2010
SOURCE:
My Pfaff Tiptronic 6270 does not sew.
Try unplugging the power cord from the machine, let it set for a few minutes and try plugging in again. Sometimes this will reset the machine.
Here are other postings on Fixya that sound similar to your problem:
Pfaff Tiptronic 6270 just stopped working
The memory board went out on my 2000 tiptronic 6270 couple years ago now...
Sep 05, 2015 | Sewing Machines
2040 tiptronic board replaced
I would take the machine to someone else and see what they say.
Mar 16, 2014 | PfaFF Tiptronic 2030
Husqvarna 500 sewing machine won't power on
I'd put a surge suppressor and voltage regulator ahead of your machine from now on... because I think you've probably got another fried board. With luck, though, it just needs reseating.
Jan 24, 2014 | Husqvarna Sewing Machines
I started sewing and my machine just went black and stopped. It won't come back on. There is no sound, no lights, nothing. What can I do?
it's possible that either the computer motherboard went out on it.
since it's a janome computerized sewing machine I would suggest
having it serviced to see what's wrong.
Apr 17, 2012 | Janome Memory Craft 9000 Computerized...
Pfaff squeaks
spray linkage with wd40
Mar 22, 2012 | PfaFF Tiptronic 2040
I think I need a power board because my machine keeps stopping. Have to wait to start again. Also my light is broke. I have a 1171 and wondered if parts are still available for that machine. It was my moms...
Hi, ..go for the simple first. It could be motor brushes..the next time the machine stops try turning the handwheel and see if it starts to run again. If it does, the motor brushes are worn down. It would probably be less than a 100.00 to repair it.
Good Luck!
May 07, 2010 | PfaFF Tiptronic 2030
Pfaff Tiptronic 6270 just stopped working!
There is a fuse in the the base plate that has blown. It is soldered in and is special fuse you won't find at Radio Shack. Unfortunatly it needs to be fixed by a Pfaff dealer on someone with access to the fuse. If you have the work done, make sure they replace a certain reisitor on the base plate at the same time to prevent this from happening again (per Paff).
Sorry for the bad news and best of luck.
Jan 15, 2009 | PfaFF Tiptronic 2040
Frozen Sewing Machine Arm/Pfaff Tiptronic 6270
Good morning,
A question to help determine what's happening with your machine(s).
Open the bobbin case so you can see the bobbin area. Begin by trying to turn the handwheel towards you and watch as the needle attempts to go up/down. If you cannot turn the handwheel towards you, turn it slightly backwards then forwards. Does the needle hit the bobbin case as it comes down?
If yes, your machine is out of time and will require a professional technician to repair.
If the above is not the case, there may be thread jammed behind the bobbin case or wrapped around the inner parts of the take-up lever.
Either case - a Pfaff authorized technician would be your best bet for a proper repair.
Best of luck with your machines - it's just awful to not have the at the ready for all our projects!
Happy sewing,
Kim & Linnette
Jul 30, 2008 | PfaFF Tiptronic 2040
Sewing Machines Logo
339 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
MissFixIt828
Level 1 Expert
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
