Question about Nokia 2680 Slide Cell Phone
When I switch it on it is telling me test mode
    Sergeant:
  • 129 Answers
Hi :) have your phone has been water damage ?? if not, TEST MODE mostly the phone software corrupted. please send to nearby mobile shop,ask technician help for reload the software.
Good luck.
please voted me if my solution useful,thank..
Posted on Aug 02, 2010
How do you turn error code light off on a kubota l3901
Mode "A" (Test Mode)
1. While holding down both DPF INHIBIT switch and the parked regeneration switch, turn the key switch to "ON" or "START" position.
2. Mode selection display is indicated on the LCD.
3. Press the parked regeneration switch and the mode indicated on the LCD is changed.
4. If "A" is indicated on the LCD, press the parked regeneration switch for more than 2 seconds.
5. Test mode is selected.
6. If parked regeneration switch is pressed, the display item is changed.
7. Turn off the key switch to finish test mode.
Mode "b" (Error Information Clear Mode)
1. While holding down both DPF INHIBT switch and parked regeneration switch, turn key switch "ON" or "START" position.
3. Press the parked regeneration switch and the mode indication on the LCD is changed.
4. If "b" is indicated on the LCD, press the parked regeneration switch for more than 2 seconds.
5. Error information Clear mode is selected and the expression "PUSH" is displayed.
6. Press the parked regeneration switch for more than 2 seconds.
7. The expression "OFF" is displayed.
8. Turn off the key switch.
Be sure to clear error information by performing this procedure after servicing is finished.
Jun 13, 2015 | Kubota Garden
Why does my Optimus Model 163 MovieCorder 8 show "tape" blinking continuously and I cannot record or rewind or fast forward the tape.
This sounds like a fault caused by a mode switch problem. The mode switch tells the electronic section what position the VCR mechanical section is in. The mode switch itself can go faulty, or it can be sent to the wrong position if the VCR mechanism is damaged. For example the mode switch might be in eject mode, when the mechanism is in play mode.
It's unlikely that a reset would cure the problem. But you could try powering down the video by pulling the plug and leaving for some time. Maybe even a day.
Mode switch replacement is only possible if you have either done this before or have the service manual. Since most mode switches are never ever set up in the eject mode position. The VCR mechanism will also need to be checked to make certain it hasn't been damaged before resetting or replacement of the mode switch.
Mar 20, 2015 | Televison & Video
Can't get my Iiyama Prolite E2407HDS out of test mode
from iiyama tech support (UK):
  1. Switch off the monitor.
  2. Connect all 3 input types with live connections (VGA + DVI + HDMI)
  3. Turn the monitor on.
It will select an input and display as normal.
I have tested this and it does work!
Good luck
May 25, 2012 | iiyama E2407HDS-1 24 inch LCD Monitor
Replaced the cap,rotor,fuel filter,even sparkplugs..car stalls when u hit the throttle..and puffs black smoke until the idle catches up
You need to test the TPI. and see if it is in sync. The throttle position sensor determines (based on a voltage scale like a dimmer switch) how much fuel the injectors will provide the motor.
if that tests ok, Then try the coolant temp.sensor switch that tell the ecu how warm or cold it is, if it failed in the "cold" mode, then it is tell the ECU to give a lot of fuel, acting like a choke
Sep 28, 2010 | 1989 Toyota Camry
No spinning action on my MW511 Fisher and Paykell Wash Machine. Drains water ok. Then shows small beginning of back/ forth agitation - but not progressing to full spin mode. Warning lights showing...
Hi just read your posting.Now with the error code you have shown it tells me you have an out of balance fault.To find out if the fault is with the out of balance switch or the motor controller you will need an electrical test meter. the reason for this is to test the switch for conductivity,not to test for power or anything dangerous.Have you or can you borrow an electrical test meter to test the switch?please reply and I can guide you throe the repair of this fault.
Jun 14, 2010 | Fisher and Paykel GWL11 Top Load Washer
My motion detector switch stays on, lights won't turn off. How do I reset the switch?
Hi MBE,
Most motion detectors have sensitivity and duration adjustments. Others have test modes.
Since the model is not specified, I can't tell you where to look.
You will know it when you see it though.
Best regards
Mike
Dec 05, 2009 | Pass & Seymour Electrical Supplies
Low battery puts nokia 1200 into test mode
1200 low battery solution. Solve It! Solve It! .
Jul 10, 2009 | Nokia 8600 Cell Phone
Maytag top load neptune washer
Have no idea why you would only get 20V at the pump when you get the full 120V in test mode. However, if you do get 120V, not 20V, then the chances are that the water level pressure switch is giving a faulty reading which tells the board that the basket is already empty.
Apr 29, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Show test mode
my handset model1600 shows test mode , how do i turn on phone ?
thanks
Feb 29, 2008 | Nokia 1600 Cellular Phone
Nokia 2680 Slide Cell Phone Logo
194 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
