Question about Maytag MDE2400A Electric Dryer
Error code 3E on Maytag MDE2400AYW 3.7 cu. ft. Electric Dryer
rogrrabbit
  • 986 Answers
SOURCE: maytag dryer electric mde2400ayw doesn't seem to
Sometimes blower wheels will get loose in dryers. Sometimes they will get a whole lump of lint in them or you can hear a rattling noise in the dryer, this is the blower wheel, its worn out and it can cause the fuse to blow too,or it can half *** work and take fifty forever's to dry the clothes.Or it could be just that the dryer needs a good blowing out .I use a lawn blower to get all the lint out of the dryer as well as the vent pipe and vent to outside. I take the filter HOUSING out and wash it also. That is, I remove the housing and clean is good! Making sure that the dryer is properly flowing air is a good thing!
Posted on Sep 12, 2009
SOURCE: ''AF'' error on Maytag Bravos dryer
"AF" means "Air Flow". Your vents are cloged with lint. I have had to vaccum out my vents several times, both inside and out. It's been a bit of a pain.
Posted on Dec 27, 2009
  • 207 Answers
SOURCE: Dryers I have a Maytag electric Dryer, that...
you may have one of ur overheat sensors going out that wont let the elements heat uplike they should they are behind the back cover they are round and very inexpensive u can take the wires off put new one in or u may have a bad element ake the wires off and check continuity thru the element itsself if all that is good take dryer vent off and run with it off 1 load and seee if this cures the problem if it does u had the hose kinked or u have a restriction of lint in the dryer vent going outside hope this helps
Posted on Feb 25, 2010
SOURCE: AF Error Code
If thats not it, then you nay have a faulty sensor.
AF Restricted Airflow Condition
"AF" flashes if a restricted airflow condition exists. Check to make sure the lint screen is clean, the door seal is in place and the vent is not
obstructed.
Posted on Mar 18, 2010
Testimonial: "Thanks so much!"
KevinWhite
  • 1902 Answers
SOURCE: Maytag Electric Washer/Dryer - error
Hello
Error code 7E is a temperature control error and is caused due to overheating. Start with cleaning the vent and then please check the Thermal fuse located on the blower wheel housing inside the duct for continuity with an ohm meter. The fuse cannot be reset if it is bad then it needs replacement, if the fuse if fine then check the cycling thermostat. Please get back to me if you have any other questions.
Kevin
Posted on Nov 17, 2010
How do i remove the front panel of mde2400ayw dryer?
Go to www.repairclinic.com and enter mde2400ayw. You will be presented with a list of common repair parts and perhaps a video showing how to disassemble a typical Maytag dryer.
Jul 12, 2016 | Maytag MDE2400AYW 24 High-Efficiency...
Howh do i replace the gasket pad
Nancy,Could not find instruction for seal removal on your particular model, did post links to models, hoping they will be close/same as yours. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Dryer Door Seal part WP3405245 How To Replace
How To Replace Torn Or Worn Out Dryer Door Seal
Dryer Door Seal part 33002094 How To Replace
Jul 10, 2016 | Maytag MDE2400AYW 24 High-Efficiency...
I have a maytag bravos quiet series 300 dryer with the error message f73. What does that mean?
Maytag Bravos 7.0 Cu. Ft. Electric Dryer F73 - Questions ...
www.fixya.com/search/p688923-maytag_bravos_7_0_cu_ft.../f73
have a bravo dryer , wont start shows error code f73 ? lights come on but dryer ... I think there was an F73 or F93 error message but we did not write it down.
Sep 22, 2015 | Maytag Dryers
My dryer gives a 3Ecode
3E == overcurrent detected at the motor.
Open the control panel, there should be a tech sheet in there that explains how to put the machine into service mode (presschimeandextra rinsekeys for three seconds) and what to do while in service mode to track this down. Once on service mode, you can cycle through and retrieve all diagnostic codes... and lots of other stuff that'll help you track this down.
You can also go ahead and check out the windings on the motor. Unplug harness connector and test from wire insertion side.
Pin #1 and Pin #2 of CN9 == 11.6 ohms
Pin #1 and Pin #3 of CN9 == 11.6 ohms
Pin #2 and Pin #3 of CN9 == 11.6 ohms
Nov 26, 2010 | Maytag MDE2400AYW Neptune Electric Dryer
Maytag neptune dryer
could be the heater element, check for circuit with a test meter if it does not heat up in the minute it runs this is almost certainly your problem
Oct 06, 2007 | Maytag MDE2400AYW Neptune Electric Dryer
Maytag Neptune dryer error
To find out what the code means,
contact Maytag ServicesSM, Maytag Customer Assistance: U.S.A. 1-800-688-9900 or
Canada 1-800-688-2002.
Maytag MDE2400A Electric Dryer Logo
194 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
