Question about Brown Stove Works TTM721-DK Gas Single Oven
Oven only works when house is cold
Brown TTM721-DK
Igniter lights up but gas does not start when house temp is warm
When house is cool, it lights right up. When it works temp works properly turning gas on and off.
  • 49years Aug 15, 2010
    Thank you, that is the problem. now if i can just find a part number.
    Again thanks for your help.
  • 50 Answers
All gas range ignitors have to be just hot enough. i would say put an amp clamp meter on it. if it draws over 2.8 amps its probably good. if under that its bad and replace it.
Posted on Aug 01, 2010
Oven wouldn't light so I replaced the igniter. It now lights fine at start up, but won't light when oven needs to reheat.
Certain igniters work together with the oven gas valve that senses current, once they get hot, may not function properly. Was the igniter lighting up at all before? Could also be the temp sensor.
Oct 27, 2013 | Whirlpool Ovens
Propane oven will not get up to tempature
change the igniter
had the same problem I was told the oven cools off
because igniter isnt allowing gas to flow
it will lite but temp isnt there
Sep 16, 2012 | Frigidare FGB24S5DC Gas Single Oven
Oven will not heat up, orig oven 1967, glow light comes on & the gas is on.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 01, 2011 | Brown Stove Works TM721-KW Gas Single Oven
I have an older Brown gas Range (Frolic) 20" Model F100 and I need a thermocouple for the oven burner control valve. How& where can I get one
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 23, 2010 | Brown Stove Works TTM721-DK Gas Single...
My kenmore gas oven won't heat. I turn to dial to temp i want can smell gas building up in oven and can see a glow in bottom of oven but will not ignite. Sometimes if I turn on a cooking eye I can then...
When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat
-- defective selector switch
-- defective gas safety valve
-- defective gas valve coils
Oct 22, 2009 | Whirlpool SB160PEE Gas Single Oven
Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
Feb 25, 2009 | Ovens
Oven not working properly
I just solved this problem with my GE gas range. I waited forever for the oven to warm up. The igniter would glow, light the burner and burn for a minute or so and go out. It would repeat this process till oven reached operating temp, which took forever. Problem is in the igniter. It may be glowing, but it is not letting the gas valve stay open, because it is not hot enough to create resistance in it to keep gas valve open. I had replaced the thermostat thinking it was the problem. The good part about it was I could take it back because my buddy works at supply house. Once the igniter was replaced, the oven fired up and stayed lit till operating temp was reached. It will also hold the oven temp much better. Oh yea, the igniter will stay glowing while the burner is on. Hope this helps.
Nov 29, 2008 | GE JGRP20 Gas Single Oven
Oven not cooking evenly, outside is getting brown but inside is undercooked
Sounds like the igniter is not operating at full capacity. What happens is that the oven does not light when it should. Instead, the oven is cooling down much too far so when the oven does light it has too heat more rapidly. This causes the outside to brown/burn long before it should.
Jan 24, 2008 | Whirlpool SB160PEE Gas Single Oven
Oven will not light
If your husband is handy and it is Igniter.. this is a job he can do. remove the burner cover and them the burner baffle and unscrew the igniter cover and pull the igniter out remove the wire nuts and replace with igniter part number WB02X9154 let me know how it works out for you.
Nov 18, 2007 | GE JGRP17 Gas Single Oven
Brown Stove Works TTM721-DK Gas Single Oven Logo
113 people viewed this question
Top Brown Stove Works Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you a Brown Stove Works Oven Expert? Answer questions, earn points and help others
