Question about ViewSonic VA520 15" Flat Panel LCD Monitor
The screen says "out of range". i took it away from the computer it was on and am trying to use itwith another pc
    President:
  • 2,571 Answers
Out of range usually referes to the resolution/refresh rate your PC has been set to.
If your pc's resolution/refresh is to high for the monitor, you wont get a picture.
Try boot into safe mode (F8) this will start with a low resolution, you can then go into your display properties and change them to the screens default resolution, put the refresh rate to 60hz, flat panels dont need a high refresh rate
Posted on Aug 01, 2010
  • 6,826 Answers
Http://www.viewsonic.com/support/downloads/
Make sure you have the latest drivers for your monitor installed.
Is their a relay that controls the alarm and dome lights on a 1999 toyta solora
They so have a computer that woks with the other main computer
whats going on with itwith it
Sep 08, 2014 | 1999 Toyota Camry Solara
How to extend range
Difficult one to answer. You cannot adjust anything internal to the router to extend the wireless broadcast range. however, there are a few things you can try to make the most of the range it has. Internal walls and furnishings all play a part in reducing the effective range of the router. The model you specify has the 3x3 MIMO antenna array so should give you a decent range, at least 50 metres indoors. Keep the router as high and as far away from walls as you can, this will greatly improve the range. try to ensure the router is not screened by large near by metal objects such as steel PC cases, these will absorb wireless signals and reduce the range.
Oct 18, 2013 | Cisco Linksys Wireless Router EA4500...
How do I find Broken Switch on hp 1200
localize the switch and activate itwith something else
Nov 03, 2012 | HP LaserJet 1200 Printer
Analog out of range display on the screen
try the lcd monitor on another PC, if the same message pops out, your monitor needs reprogramming of its A/D board, bring it to a LG service center..
if it works fine on another PC, try to boot your PC on VGA mode..
May 10, 2010 | LG 22" FLATRON LCD Monitor
Inout signal out of range Answer Failed: retry
It shows out of range because the PC is sending out the video signal that is higher than the monitor can display, you need to set the PC video resolution to the native resolution: 1024 x 768 @60Hz. You can reboot the PC into save mode (hitting F8 key while booting up) then set the resolution to 640 x 480 (try 1024 x 768 if it allows you to do so), reboot and reset the resoltion to 1024 x 768 @60Hz.
Mar 06, 2010 | IBM ThinkVision L151 15" LCD Monitor
I had a bad virus on my dell 8200. My friend took
Since your 'friend' took everything out of your hard drive you'll need a Windows CD (XP, VISTA). Without installing Windows back onto your system you're out of luck.
I would hope your friend has a copy of Windows he can use to restore your computer to a working order. If not, keep him as far away from your computer as possible!!
If you can't find a copy of Windows to install you'll have to purchase a copy at a retail store or perhaps online at TigerDirect.com or NewEgg.com.
Dec 29, 2009 | Dell Computers & Internet
Signal out of range
If your PC is working with a different monitor then your monitor is going bad.
Mar 28, 2009 | Computers & Internet
Uniden 2645 out of range
The problem of phone not registering is sorted, I simply put that hand piece(2) into base station and it registered straight away, as for the "out of range" problem, we have not had a long enough call today to know yet , hopefully resetting to factory settings helped.
Jul 16, 2008 | Uniden Cordless Phone
Cannot remove "input signal out of range"
input signal out of range would normally indicate the the screen resoloution is either too high or too low for the monitor to display properly.
is this on just one game? which version of windows do you use?
Jun 21, 2008 | Hanns.G Corporation HW191D 19" LCD Monitor
Out of Range
Your computer has is set for a higher resolution than your tv can handle. Lower the resolution on your computer and problem should go away.
May 14, 2008 | LG 17LX1R 17 in. HD-Ready LCD Television
ViewSonic VA520 15" Flat Panel LCD Monitor Logo
118 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
