Question about TDK DED+840 DVD±RW Burner
Windows XP SP3 does not even recognize my TDK 840G DVD burner although Belarc 8.1m reports that it is there. Likewise with my NEC ND-3520A DVD burner in the same computer. When I insert a DVD disc into either drive absolutely nothing happens and Windows Explorer also does not see either DVD drive. What's up & how do I fix it? Larry
    President:
  • 567 Answers
Hi when put the burner into the computer there are two connections to be made, one is for power the other is for data,once you firmly connect these two you should start the computer and go to { my computer } and look for it. If you do not see the icon in { my computer }, turn off the computer and open the case and check the connection again,if the connections seem fine unplug the power connector and plug in another one if there is extra connector in the case.Close the case and start the computer when it boot up look for the icon in my computer.
Posted on Aug 01, 2010
  • larrylaw Aug 02, 2010
    I double checked the power connectors and even switched them around among other components and nothing changed. The 2 DVD drives still are not recognized by the OS even though Belarc 8.1 sees and reports them. Got any other ideas? Larry
  • Hilton Bristol Aug 02, 2010
    Hi Larry you should also use another ribbon cable "that the cable that connect the DVD drive to the motherboard" and you should also connect the DVD drives one at a time to see if any will work. If it work that would mean its power problem,and if you have access to another you can test the DVD drives in the other computer to see if the computer will recognize any of them.If the other computer does not recognize them this mean the DVD drive are faulty,DVD are call plug and play this mean they do not need any software to work if these options do not solve the problem you may have to replace them.
I have a NEC DVD RW ND-3530a and my windows xp service pack 3 stopped recognizing it. it no longer reads as a drive. The device manager has it listed with a yellow !. I have tried uninstalling and...
Remove the drive from your computer, and temporarily connect it to another desktop computer.
If it still does not work, then it's time to responsibly recycle it, and spend $40 to purchase a new CD/DVD reader/writer.
Dec 10, 2010 | NEC ND-3540A DVD RW Dual Layer Burner
I have nec dvd_rw nd-3520a on my computer it will not play dvd ram is there something i can download to facilitate this?
fraid not , these are the only dvd formats this drive supports
DVD-ROM • DVD-Video • Multi-Session • DVD-9 • DVD+R • DVD-R • DVD+RW • DVD-RW
dont try to flash the drive
Oct 07, 2009 | NEC ND-3550A DVD±RW Dual Layer Burner
Everytime I try to burn a dvd/audio slideshow, it tells me there is no disc in the drive and I know there is. I have used a dvd,dvd+r and a cd RW, and none of them worked?
More than likely, your DVD drive requires a firmware update. Check the support section on the NEC website for instructions and downloads. The process is pretty straightforward...
Aug 12, 2009 | NEC ND-3520A DVD±RW Dual Layer Burner
ND-6750a not recognized by WinXP SP3
Try the firmware fix and driver installation on this page: http://www.techspot.com/drivers/driver/file/information/9706/
It looks like the "windows updates" outdated your original driver.
Jul 03, 2009 | NEC ND-6750A DVD RW Dual Layer Burner
Have NEC 3550A DVD/rw. re-installed windows XP professional & all else.. DVD will not recognize most dvd discs.Got drivers from NEC.. still problem
Go to:
1. start > run > devmgmt.msc
2. Under DVD/CD Rom drives make sure it's installed (Uninstalled = Yellow icon)
If all drivers are applied correctly this could be a problem with the DVD Region Settings.
Go to:
2. expand
3. find the device
4. right click > properties
5. go to dvd region tab
6. select the desired region
Warning: some drives only allow you to change it up to 5 or 4 times so be careful!
Jun 23, 2009 | NEC ND-3550A DVD RW Dual Layer Burner
DVD Writer problems
I used the drivers provided by windows XP. What do you mean when you ask about the configuration of my computer?
Jan 14, 2008 | NEC ND-2500A DVD±RW Burner
Nec nd-3520a
try downloading www.slysoft.com you burn read and rewrite almost everything you can test drive it for 20 days or so and if you want to buy it it is very cheap. lala linda
Oct 31, 2007 | NEC ND-3540A DVD RW Dual Layer Burner
NEC 6650A Drive is not recognizing CDs
My drive will not read anything. CD's or DVD's. But on a rare blue moon, it will work. please someone help!
Oct 16, 2007 | NEC ND-6650A DVD RW Dual Layer Burner
NEC nd 6500a
Hi, I think that it's a firmware issue. If the unit is till covered by warranty, you may have to bring it back for replacement. When doing so, it may be to your advantage to bring the PC while it is still attached and blank CDs and DVDs just to demonstrate the particular failure and likewise to be able to test if and when it would be replaced. If for some reason, you would want to try DIY, please look over these sites that you may have an idea. http://www.cdrinfo.com/forum/tm.asp?m=132275&mpage=1𠓝 http://liggydee.cdfreaks.com/page/6500/ Hope this be of some help and pls post again how things turn up. Good luck and kind regards.
Aug 04, 2007 | NEC ND-6500A DVD±RW Dual Layer Burner
NEC-3520A Suddenly stop to burn correctly, but reads OK
Have you tried lowering the burn/erase speed? To begin, simply do what you need to do on the lowest speed, and then keep increasing until it gives the error again. This will most likely work. I had this problem and I burn now CDs at 16x.
Jun 11, 2007 | NEC (ND-3520A-KIT-BLU) Burner
TDK DED+840 DVD±RW Burner Logo
37 people viewed this question
Top TDK Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a TDK Computer and Internet Expert? Answer questions, earn points and help others
