Question about Panasonic PT-D5700U Projector
I'm trying to switch to a 16:9 aspect ratio, but when I go to the Position menu, the only thing it allows me to change is the Keystone, it's as if all the other keys are locked on that menu. The only thing different is that i'm using a a 1.3-1.8 lens on this particular projector whereas the other two projectors I have are using a 1.8-2.5 lens and can do it just fine. I tried switching the lens to one of these projectors and I had the same problem.
  • 57 Answers
Default the projector back to factory setup. This should give you back full menu function
Posted on Aug 15, 2010
I'm trying to change aspect ratio from 16-9 to 4-3 on dxc-d30ws
get the onscreen menu up and alter aspect ratio settings
as the ratios are changed you will see the screen change to suit the new ration
it it is a late led type you may have to select the pixel sizes to get the screen size to change
Jan 13, 2017 | Televison & Video
Black bars show up when not in HD
Sounds like you've changed the aspect ratio to a 4:3 and you need to put it back to a 16:9. Go into your menu and find the sub menu that allows you to change "format" or "aspect ratio". Adjust that until you have it at 16:9 and see if that corrects your problem. Good Luck Bill
Jun 06, 2007 | TruTech PLV1615T 15 in. LCD Television
DOES NOT FILL SCREEN HORIZONTALLY
You can change how your tv displays in the video setting menu under display. You will have a choice between 4:3, 16:9, 16:10, cinema or automatic. I think to fill your screen the best you should choose 16:10 but this is not going to guarantee that all channels will fill the screen. It still has to do with how it is being broadcast to you.
Jan 25, 2016 | Televison & Video
How do you change the stills function from 4.3 to 16.9 its really not very clear?
Hi
Having looked at the full manual - downloaded from here and savable:
http://tda.panasonic-europe-service.com/docs/2z54662404z3z38916z656ez706466z22zdf06e277f71e6367f9e09db70241478cb0ad23ae/tsn3/data/ALL/HXWA30EG/OI/902781/vqt4x32.pdf
I think you will find that you cannot actually change from 4:3 to 16:9 aspect ratio for a particular pixel sized picture. When you set the pixels for the picture you want, the aspect ratio is set automatically.
For example:
16Megapixels 4608x3456 4:3
12Megapixels 4608x2592 16:9
See page 96 of the manual mentioned above for a full table of Megapixels, size, ratio etc
Therefore changing the picture size from the simple menu changes the aspect ratio but you do not have control of the aspect ratio for each size, in other words you cannot take a 16Megapixel picture at 16:9, it has to be 4:3.
Hope this has been helpful
Cheers
Nov 14, 2014 | Panasonic HX-WA30EB-K Hx-wa30 Upright...
Need step by step instructions to set-up memory lens function for PT AE3000 projector so as to be able to switch between 16.9 and 2.35:1 formats
LENS MEMORY means that
You can save and name the adjusted ZOOM/FOCUS,
H-AREA POSITION and V-AREA POSITION there is just 4 adjustment settings in
memory excluding ASPECT RATIO the aspect ratio depend on signal but you can change manually when needed.
possible ASPECT RATIO and SIGNALS
If VIDEO or S-VIDEO then
ASPECT RATIO
4:3 \ 16:9 \ 14:9 \ ZOOM1 \
ZOOM2 \ JUST
AUTO
\ 4:3 \ 16:9 \ JUST \ ZOOM
you can switch in between
If COMPUTER then
4:3 \ 16:9
4:3 \ 16:9
VGA or SVGA signals
Not switchable with
WIDE480/600/720/768/768-2/800/900 signals
If HDMI then
4:3 \ 16:9
16:9 \ H - FIT \ V - FIT \ ZOOM
1 125 (1 080)/50i, 1 125 (1 080)/60i,
1 125 (1 080)/50p, 1 125 (1 080)/60p,
1 125 (1 080)/24p, 750 (720)/50p and
750 (720)/60p signals
525p (480p) and 625p (576p) signals
If COMPONENT(YPBPR) then
4:3 \ 16:9 \ 14:9 \ JUST \ ZOOM1
\ ZOOM2
625i (576i), 625p (576p)
AUTO \ 4:3 \ 16:9 \ JUST \ ZOOM
525i (480i), 525p (480p)
1 125 (1 080)/24p, 750 (720)/50p,
these are all type of signals and there possible aspect ratios
Feb 06, 2011 | Panasonic PT-AE3000U LCD Projector
LG 47'' LCD HDTV 120Hz - Incorrect Picture Width
I just had this problem and got it solved. The issue is that your cable box is likely set to the wrong aspect ratio, so your tv will not be able to display the picture properly without this setting changed. On my cable box(Pace), you need to turn the power off to the cable box using the remote. Then hit the menu button on the remote and a new menu will appear on the screen. Change the aspect ratio to 16:9 and you should be all set. Hope this works for you too.
Feb 22, 2010 | LG 47LC7DF 47 in. LCD HDTV
Aspect ratio won't change to 16:9 for my nintendo wii. it stays as 4:3 even when i change the output setting on my wii to 16:9. the nintendo wii support said that you have to change the aspect ratio on the...
Go into menu on the tv and look for start up setting and look for tv ratio and change it. The cables should be right. The wii will not change aspect if the tv is not compatable
Oct 21, 2017 | Sony BRAVIA KDL-52W3000 52 in. LCD...
TV has 16:10 Aspect Ratio - looks squeezed. Can I adjust?
there should either be a menu button on your TV or on your REMOTE after its pressed ...go to picture and there you can adjust the screen to your preferences.
Apr 06, 2009 | ViewSonic NX1932W LCD Monitor
Philips LCD TV wont change aspect ratio
In your philips menu there is an option to turn of your auto aspec ratio to OFF then using your sky remote go to services, 4 then picture and ensure that this is set to 16:9
Job done
Cheers
Little Dish Fitter
Dec 24, 2008 | Philips 32PF7321 32 in. HDTV-Ready LCD...
Open Questions:
See all Panasonic PT-D5700U Projector Questions
Panasonic PT-D5700U Projector Logo
76 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
