Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Garden tractor engine shuts off
Tractor engine shuts down when i put it in gear and begin to release the clutch. It also shuts down when I engage the blades.
  • 760 Answers
Sounds like the operator present seat switch is not working. You can run the motor out of the seat, but not with the blades engaged. You didn't list what model, but usually hte seat switch is connected to the negative side of the battery, and grounds out the magneto, so you can't test it to ground. Put your tester on 12+ battery, and then to both sides of the seat switch. There is usually 4 terminals on seat switch. Some moodels have grey wires for the mageneto circuit, you can tell by whatever color also goes to the clutch switch too.
Posted on Aug 02, 2010
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
JD 110 tractor stalls when put in gear
Sound like a safety switch has gone bad. Either the clutch or seat switch are bad.
Mar 24, 2017 | Garden
I have just fitted a new transmission belt to my westwood 1012, it will go into gear when the motor is off but when the motor is running the gears will not engage when the clutch is pressed
You've probably put the belt on incorrectly or not put the clutch wheel or spring back correctly. When you press the clutch a jockey wheel on the drive belt should release the tension, allowing the belt to slip and the gears to be engaged.
Oct 28, 2013 | Craftsman 20 Hp 42" Deck Lawn Tractor
Engine shuts down when pedal is released, and when pto is ingaged
check your Reverse Gear engage switch and PTO (blades engaged switch), either a bad switch(es) or short in wiring indicating that you are in Reverse with the blades engaged. Is there an override function so that you can mow in reverse? Check that circuit vs. the PTO and reverse gear. good luck
Mar 17, 2010 | Garden
Brake and clutch are stuck down until you put it in gear.
Most mowers do this. That way when it's not in gear your brakes stay engaged. However you should be able to press hard on the brakes and it should release wether its in gear or not. But this particular manufacturer might not be able to do that.
Mar 15, 2010 | Garden
Craftsman 42 in. deck lawn tractor. Will start and idle fine but when you let out on the clutch the motor bogs down and dies
few reasons will try to narrow down first start it and put in neutral and deck disengaged release clutch if bogs then fuel problem the carb may need adjustment or repair or fuel filter needs replacement----if no bog step on clutch no put in gear release clutch if bogs check drive belt -upper belt on engine pulley and check for binding an idler pulley problem -debris -or rear unit binding -needs service-drive pulley damaged-rear locked--if not bogging in gear step on clutch engage deck release clutch if bogs need to check deck -belts-pulleys -mandrels -bearings and for bent or binding blades good luck
Mar 10, 2010 | Craftsman Garden
Tractor wont drive or engage electric clutch.
It thinks you aren't sitting on the seat.
There are 2 wires and a switch under the seat. The plug may have come off, the connections might be bad, or the switch might be bad.
Jun 02, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Engine stalls when clutch/brake pedal is released
Under the seat, there is a operator presence switch, if this switch fails, the mower will shut off when the brake is released, or put in any gear.
Apr 21, 2009 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
185 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
