I have a 80G samsung 2.5" drive in an external case. One night it worked fine the next day no computer even registers that it is present. I have changed cases - hooked it to different computers and still no luck. The green light comes on and then turns red. It will blink once - pause- and then blink 6 times. It continues to repeat that sequence. I would really like to recover the files on it. Any suggestions?
  • granpably Apr 25, 2008
    The light is on the case circuit board -the actual drive has no lights. Same light sequence no matter what case or adapter it is plugged into.
    Master:
  • 555 Answers
Is this light on the bare HDD, or one one of the external enclosures?
Posted on Apr 25, 2008
  • Matt Jurach
    Matt Jurach Apr 25, 2008
    Can you give me a model # or part # for the Samsung drive?
Keyboard mouse touch pad does not work cant type ect
Try a full reboot. Power out and remove battery. If the cable from the trackpad is intact and connected there is not much else you can do economically as the fault could be the motherboard or the trackpad. In the meanwhile you can use an external mouse
May 13, 2014 | Samsung Notebook Np-n150 Plus Laptop Hard...
Tip
How to back up HP quality Center
<p>Back up important files and programs a valuable need, even for novice users. Use the Backup utility and Restore Center in Windows to support it in the backup software programs, such as HP Quality Center. HP Quality Center is software for use by quality professionals. Microsoft recommends that you use an external hard drive to use the backup program to save, but you can also backup to DVD, CD or USB stick. <br /> <p><br /> <p>1. Connect the external hard drive on your computer. <br /> <p><br /> <p>2. Click "Start" and "Backup and Restore" in the search box. Click "Save and Restore" result. <br /> <p><br /> <p>3. Click the "Create Backup". Select the external hard drive in the selection and click Next. Click the "Let me choose" option to a file select window. <br /> <p><br /> <p>4. Select the "HP Quality Center" on the list, and then click Next. Click "Save Settings and Run Backup" to start backing up files from the software. <br />
on Jun 22, 2011 | Computers & Internet
Help! XP stopped recognizing my external hard drive. It has worked fine for two years and then suddenly: My Laptop no longer "dings" when I plug in the external hard drive. There are no unknown...
No question is silly dear, problems are there and we are in this site to help.
Yes, you mentioned that the said device works fine with your desktop, then it is probably not the problem with your device. You have also said that your tried formatting the os. Good.
Hope your pc, laptop and the memory device are disinfected with a good, licensed and updated antivirus.
Check, if Universal Serial Bus Controllers (corresponding to the nos. of total usb port present in the machine) are present and enabled both in the device manager and the bios as well and set to Hi-Speed if it is Full-Speed.
Well, have you tried formatting the memory stick/device? Format it and see if it works.
Next, please change the usb connectivity cable using/attached to the device and see.
Another thing while connecting an external storage device like ext-hdd. The external usb storage devices that gets connected with a usb cable, in some rare cases needs to be connected as a usb-master or usb-slave [you can see many external usb drives comes with a splitted or dual usb port connector cable, this is either for connecting two usb device or to connect as master when used as a single drive], therefore use such cable to connect and use alternated ports, and see which works.
Now, if all above fails, it then might be the problem with your external drive, i guess.
Best to seek help of your system admin/vendor.
Oct 16, 2011 | Microsoft Windows XP Professional
My computer crashed last night. It has the colored lines across screen. What do I need to do. I was able to click the repair button on the screen when it told me the computer crashed. What can I do? My...
Hi Friend, In this case I would like you to try connecting any external monitor to teh systen and check if you have the same issue with the external one as well
If yes then you have to download the latest video drivers for the system
If the external display is fine, in that case you have to get the LCD replaced for the laptop
Dec 08, 2010 | Acer Aspire 6930-6771 Laptop
WD Notebook Essential 80G just quit working
if you are not getting any broken noise from the hard disk its not ded so ushut down the computer first then connect the hard disk to the power and then connect the hard disk to your system in the usb 2 port then connect the start the system if still dosent detect go to manage by right clicking on the my computer icon the go to disk management check your hard disk shows ther if shows forign just right click on the forigen and say import forigen hard disk if shows the drive helthy and dosent show up on my computer then just right click on the helthy place and say change drive letters and choose one of the letters and should show up on the my computer if still dosent see at all then change the usb cable....
if still dosent work remove hard drive from the external case and put it directly to your computer for this u need a sata cable and a sata power if it detects and work this way your data is safe but you casing of the external hard drive has probs ...
thanks
Nov 12, 2008 | Western Digital 320GB MyBook External USB...
Computer not reading free agent pro
I suspect an IRQ conflict in this case. where one day things are workig fine and the next day they are not because the IRQ conflict has made it's self known.
if no IRQ conflict is present , I would suspect a dead drive , time to replace the ole girl. these things happen , touchy equipment , buggy driver sets , you name it , things will however improve.
and remember if it's not hebrew , it's a lie :-> shalom
Sep 08, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Maxtor OneTouch III Not Recognized by XP
sounds like the USb Port is burned out, might as well chuck it
Jan 09, 2008 | Maxtor OneTouch II external hard drive...
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
