Question about Whirlpool Dryers
WED5321SQ0 dryer doesn't heat or shut off once it's running
We woke up yesterday with our dryer still running from the night before. The dryer is blowing cold air, all the vents were clean, no build up anywhere. From what I can tell from other posts it may be the fuse, the thermostat or the cut out timer. Does that sound about right and is there anyway to ''see'' this as we don't have voltometer to check?
  • loriology101 Aug 01, 2010
    We checked all the timed drying cycle and it didn't advance
  • 50 Answers
Well if ran all night you maybe be running a even heat or auto dry cycle. i would first try on a timed dry see if heat then. if does heat (which probably wont) you will be need to replace either the sensor or board that controls the auto dry. or a very small chance that the timers bad. most likely you have a bad heating element. if the machine doesnt heat on the timed dry, then you need to check continuity on the heat fuse(located on heat element housing). if good then check continuity on heat element. i would say you have a bad element or heat fuse.
Posted on Aug 01, 2010
    President:
  • 3,773 Answers
Check the timer to see if it is advancing if not then you have to replace the timer
Turn it on and place the timer to exactly on some number and watch it for advancement
  • Leo Ponder
    Leo Ponder Aug 01, 2010
    Have the timer checked with a prom before purchasing this high ticket part.
    imufo2
How do I make my Frigidaire Affinity dryer stop beeping and run?
Have you checked the lint has been cleaned off filter and water reservoir emptied.?
Dec 09, 2014 | Frigidaire Dryers
Does Not Shut Off
1st go the the house breaker (dbl breaker) for the dryer and shut it off and turn it back on, your dryer runs on 220 volts of power but if the breaker is partially tripped it may be only running on 110 volts which is only enough power to turn the lights on and to turn the drum the element needs 220 volts to turn on. If it still doesn't heat after resetting the breaker then you may need a heating element or thermostat. The dryer isn't shutting off because it isn't detecting the clothes are getting dry so once you fix your heating problem the dryer should start shutting off on its own again.
Apr 21, 2012 | Roper Dryers
Two nights ago I left my Acer Aspire 1410 running all night last night. It was on a cushion. When I woke up yesterday morning the screen was black, the on/off switch was lit as was the battery indicator,...
you have over heated your machine as there was no ventilation possible damage to your cpu and bios chips these are all onboard mounted on the motherboard and as such the mother board will possibly have to be replaced would suggest you have professionally checked out
Nov 23, 2010 | Acer Aspire 1410-8414 Netbook
Kenmore Dryer doesn't shut off and doesnt' get hot
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Apr 14, 2010 | Kenmore 73952 Gas Dryer
Dryer ran all night now no heat
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Jul 13, 2009 | Estate TGDX640JQ Gas Dryer
Whirlpool LEN100PQO electric dryer wont shut off/no heat
if your thermal fuse is blown you will not recieve heat. if you put your dryer on sense load it will keep running because it is not sensing that the clothes are getting dry which in return your timer does not
advance
Jun 20, 2009 | Whirlpool LER5636P Electric Dryer
My dryer never shut off for 7 hours now it runs but dsnt heat up
Your timer has gone bad. if you get me the model # i can get you a part number and you can order the part from sears. (this is a very common issue)
Nov 19, 2008 | Dryers
Dryers Logo
132 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
