Question about Maytag MSD2656G Side by Side Refrigerator
Leaking Water Filter mount.
I looked at the online parts list, but didn't see my Water Filter. It is in the upper right corner of the fridge. I got it loose but don't know how to release the two hoses, short of cutting them off. Thank You Denny
  • 487 Answers
Check this link.(LINK) press the blue word (control or icemaker ) in location part and it should show you the picture of what you need. It looks like a fitting assy. This means the end of the fitting connected to the hose has a outer/inner ring. This means the ring ocer the hose shuffs into the assy to close. Take a screwdriver and pull the ring outward, (wont come off) just far enough out. Push the hose a little deeper now while holding the outer ring you should now be able to pull the hose out.
Posted on Apr 25, 2008
I have a GE refrigerator model TFX20JRBG AA and was trying to decide if it has a water filter. The PDF file owners manual indicates that some models do, so where it suggested to look to see if there is...
Your refrigerator does not have a water filter i looked at the parts breakdown and see no listing for a filter...if the breakdown is wrong and it does have a filter it would be in the upper right corner of the ceiling in the fresh food (ref) section above the upper most shelf
Sep 11, 2011 | Refrigerators
My Amana french door/bottom freezer is leaking water. Did the procedure with hot water the drain in back of the freezer, although it seemed clear of ice. That didn't help. The leaking stops when I...
Two possibilities:
1. A cracked plastic tube. These will leak whenever there's a call for water - either the chilled water dispenser, or re-filling the icemaker tray (two seperate tubes). Pay particular attention to anywhere the tubes are clamped to the chassis; anywhere they're routed near or under the refrigeration unit; and near the solenoid valve - especially if there's a tight loop in the tube there.
2. A bad (leaking) connection where one of the tubes exits the water valve. Again, these will leak whenever the valve is activated.
Those plastic tubes don't last forever. I've replaced many of them for the same symptoms. They're known to simply deteriorate with age.
Manuf's make good money selling replacement tubing kits.
Aug 15, 2011 | Amana AFB2534DE Bottom Freezer French Door...
I have an Amana side by side, model number SRD20S4E. I can not locate my water filter to change it. Any ideas where it is? The water and ice tastes off and really need to find the filter.
In searching a parts listing for your model i do not see a listing for the filter and believe your model doesnt have one.
If it did it would be in the fresh food compartment in the ceiling in the upper right corner above the upper most shelf.
A external filter could be added to the water supply line where it could be easily accessed and replaced. Filter kits are sold at Sears Lowe's HomeDepot or your local appliance parts store
Aug 13, 2011 | Refrigerators
I need to change the water filter in my samsung srs618dp fridge freezer. I have the filter but cannot locate the internal part in the fridge i need to change.
For Samsung side-by-side refrigerators, there are two possible locations. One is in the upper right hand corner of the refrigerator. The other is behind the veggie drawer.
To access the filter, either remove the top glass shelf or the vegetable bin. Turn off the water to the refrigerator. If no filter is currently in use, remove the cap. If a filter is in use, remove the old filter. Turn clockwise to remove the old filter. Save the cap to reinstall if the fridge is ever used without the filter. Note the date when you put in the new filter and place the sticker on the filter. Remove the red cap from the new filter and align the unlock mark with the filter mark on the filter housing in the refrigerator. (Looks like an unlocked padlock with the u part turned 180 degrees from the rest of the lock). Turn the new filter counter-clockwise 90 degrees until the lock symbol (closed padlock) lines up with the mark on the housing. Use steady firm pressure - it will be hard to turn. This ensures a tight seal. Turn on the water line and check for leaks. If the filter isn't leaking replace the shelf or the vegetable drawer.
Samsung support for the SRS618dp is here: http://www.samsung.com/au/support/detail/supportPrdDetail.do?menu=SP00&prd_ia_cd=2201&prd_mdl_cd=RS23DENS1%2FRAD&prd_mdl_name=SRS618DP&srchword=SRS618DP .
I hope this helps.
Jun 12, 2011 | Microwave Ovens
Where is the water filter on an LG fridge model # LFX21960ST
Your filter is in the upper left corner of the fresh food compartment.
(See manual link page 7 for picture)
Actual filter change out steps are on page 28 of the first link below.
Your 2.60 MB manual can be found here:
http://www.managemylife.com/mmh/owner_manuals/16317/LG-Bottom-Mount-Refrigerator-L0611001?brand_name_search=LFX21960ST+LG
Your filter original part number is 5231JA2006A but has been replaced by PN 9990 and is item 624A here:
http://www.searspartsdirect.com/partsdirect/part-model/LG-Parts/Refrigerator-Parts/Model-LFX21960ST/3204/0161000/50030277/00001?componentDescription=&brandDescription=&searchTerm=Filter#Partslist
Thanks for choosing FixYa,
Kelly
Oct 03, 2010 | LG Refrigerators
I CANNOT REMOVE THE WATER FILTER LOCATED IN THE UPPER RIGHT INSIDE THE REFRIGERATOR. I TRIED TO TURN IT COUNTER CLOCKWISE BUT IT WILL NOT COME OUT. THE PART NUMBER ON THE FILTER IS UKF8001. ANY...
  1. 1. Look for the water filter cartridge. On some refrigerators it is located in the back, upper right corner of the refrigerator compartment. Some refrigerators have it in a tubular-like slot under the door and accessible from outside.
    2. Remove the old cartridge. On the cartridges that are located inside the refrigerator, the cartridge should be slowly turned to the left. Don't pull down on the cartridge. A small amount of water may drip. On the type that are under the door, follow the arrow labeling for the direction to unscrew it. Slide it outside.
    3. To replace a filter, fill the replacement cartridge with water from the tap. This will speed up water flow after installation. Run water from the dispenser for three minutes after replacing a filter to clear the line. Refrigerators with a filter warning light require you to reset the light. Press and hold the Reset Water Filter button to do that.
Jan 18, 2010 | Refrigerators
Location of water filter on lg fridge freezer
OPEN DOORS LOOK IN UPPER RIGHT AND UPPER LEFT
Jul 22, 2009 | Refrigerators
I cannot locate the water filter
as far as I can tell from the diagrams there is not a filter that is changeagble by customers. ie a twist in or snap out type there is a water valve under the right rear corner behind the rear cover panel. If there is a filter( some may call a screen that is why i said look at the water valve because it has a screen that can clog up) it should be in the refrigerator section upper left corner rear
May 31, 2009 | Refrigerators
Leaking water from the ice maker
It is very unlikely that you have a leaking water line inside the fridge/freezer, as they are protected from damage. If you have water dripping from the ice maker inside the freezer and/or the dispenser in the door, the most likely problem is the valve that supplies water to the ice maker.
You'll need to replace the water inlet valve that supplies water to the ice maker. This is not the same valve that supplies water to the fridge (I believe the yellow colored valve) but rather, it is the blue valve, mounted just above the main water inlet valve.
At the bottom back right side of the fridge, you can remove the covering and see both the yellow and blue valves. The yellow one (on the bottom) is the incoming water control valve, while the blue (upper one) supplies water to the ice maker.
The part runs about $45-50 if you get it yourself, or around $185.00 for a repair person to come out and do the job for you. It should only take about 20-30 minutes to do it yourself with a small 1/4" nutdriver. Part available from Searspartsdirect.com or several other online and local stores. Just call around and give them your fridge model number and serial number, located on the inside of the fresh food section of the fridge - on the "ceiling" just inside the door.
Hope that helps.
Apr 08, 2009 | Maytag MZD2766GES Side by Side...
Frigidaire Gallery fridge, 1999. where is the water filter?
What is the model number of the refrigerator. looks like it is in the upper right corner of the fresh food section. If you go to frigidaire.com you can get the owners manual.
Jan 09, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Maytag MSD2656G Side by Side Refrigerator Logo
57 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
