Question about Dell E228WFP LCD Monitor
The monitor goes black and then comes back on if you turn it off and back on. E228WFPc monitor by dell Can I repair it myself?
  • 225 Answers
Open the monitor and look for blown capacitors on the power PCB. Replace with the same capacity and voltage. Usually they are 1000uF/35V or 470uF/35V
The luminiscent tube(s) may be worn out, broken or disconnected; or the solders on both ends on the tube may produce electric arc to the ground.
Replacing the tubes is hard to do at home. It requires very clean place because the LCD have to be disassembled and it's very likely to get dirty, leading to image defects.
Posted on Aug 01, 2010
Please take the monitor in a beg. then just go to the nearable water source like sea. pull the monitor form the beg.& then just through it into the sea.
Auto detect analog
Hi Jessica,
Dell E228WFPC/E228WFP does support displays with 1920x1080 set resolution via DVI connection while it is restricted to validated Dell brand displays:
  • The restriction applies to resolution higher than 1680x1050 via DVI connection.
  • No restriction with VGA connection, which supports up to 1920x1200.
If you use a DVI connection set your computer's resolution to 1680x1050.
http://downloads.dell.com/Manuals/all-products/esuprt_electronics/esuprt_Display/dell-e228wfp_User's%20Guide_en-us.pdf
Feb 19, 2014 | Dell Computers & Internet
Screen goes black
More likely to be in the power supply/inverter baord: http://www.lcdrepair.us/E228WFPc-inverter-power.html
Look for bad caps first, but it can also be in the lamp assembly, you will need lamp tester and inverter tester to verify that.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
May 16, 2010 | Dell E228WFP LCD Monitor
My monitor goes black after a while. I can see
That is just a backlight lamp problem. It is necessary to service it. take it to a service center or give me more information to say to you how to do it on your own.
Apr 19, 2010 | Dell E228WFP LCD Monitor
Dell monitor e228wfpC, perfect for 15 seconds after computer boots up. Then goes black. Thinking a back light issue. Never have repaired a back light. thanks Trippy
I will assume that you already try this monitor with other PC and still get the same problem. Most failure in monitors are due to bad caps in the power supply, it can also be transformers, transistors, lamps. See example of failed monitors as guide: http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you further.
Mar 25, 2010 | Dell E228WFP LCD Monitor
DEll monitor E228WFPc turns blank after being on for an hour, then turns blank ever few minutes after that. Monitor Power light stays on contiously
this sounds like an inverter problem. its pretty common with these monitors. If it is still under warranty i would contact dell. if not then you can replace the inverter pretty easily yourself, or have a repair shop do it for you.
the inverter board is available from
hope this helps
Feb 16, 2010 | Dell E228WFP LCD Monitor
BSOD on DELL E228WFPc - goes black in a few seconds
You could have a faulty inverter board. The inverter supplies high voltage to the CCFL lamp/s, these lamps are mini fluro tubes approx 1,5mm dia. and the length of the screen.
Check the inverter output and you maybe able to get parts from
www.lcdparts.net
or from DELL
Dec 13, 2009 | Dell E228WFP LCD Monitor
Dell d520 monitor goes blank while booting up(goes blank when starting windows). Everything boots up(I can hear the audio in the background)except its a black screen. I tried all safemode possibilities but...
just had this experience myself on a smasung monitor. I originally thought of power management but Samsung assure me it is a monitor sync problem and have yaken it away. Theyhave replaced the monitor. So conclusion is that your monitor is also in need of repair
Aug 19, 2009 | CMS PRODUCTS 80GB 7200RPM NB HD SATA-DELL...
Dell E173FPc 17" TFT when turned on goes black
Hi Gaz,
First, verify the monitor is functional.
Monitor STFC (Self Test Feature Check)
Turn off the monitor
Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
Unplug the monitor video cable from the back of the computer
Turn on the monitor
The floating dialog box should appear on screen against a black background.
If the issue appears during the STFC, the monitor is defective. What are the results please?
Jan 22, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Black Screen
No, this is typical problem for defective inverter. Mostly screen appears for some seconds and then turn to black. If you are technician, you can use this link :-).
http://www.lcdrepair.us/1702inverter1900x.html
Oct 01, 2007 | Dell 1703FPs 17" TFT LCD Flat Panel...
Dell E228WFP LCD Monitor Logo
807 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
