Question about Microsoft Windows XP Professional for PC
How do i uninstall a driver that causes stability problems
  • 748 Answers
If you can boot normally, right-click MyComputer and choose Properties, or go to Start->ControlPanel->System.
Choose the Hardware tab, and click Device Manager.
There you will see all the device drivers installed in the system. If yours is not listed, you can choose Show Hidden Devices from the View menu.
Once you found the driver you want to remove, right-click it and choose Uninstall.
If you can't boot normally, you will have to boot to Safe Mode. This is done by pressing F8 key before Windows starts to load; you can press it several times when the initial tests & information screens are displayed. A menu will be shown, from which you need to choose Safe Mode. Once the system finishes loading you need to do the same sequence as described before.
Good luck and please come back with a rating/testimonial if helped.
Posted on Aug 01, 2010
My hp 3115m keeps rebooting. a blue screen pops up and says there was an error and my computer will restart. it keeps doing this over and over. what can I do?
chris, did you download an application or driver? If so try uninstalling it in safe mode. Blue screen is not a good sign. Re-start normally after the uninstall.
Nov 20, 2014 | HP Computers & Internet
Video card is not recognized by the motherboard
Use this software, and follow the steps:
Guru3D - Driver Sweeper
Guru3D - Driver Sweeper is a fast tool to remove driver leftovers from your system. It's very important to remove your drivers on a proper way, because driver leftovers can cause problems like stability and startup problems. You can use it if you want to update/remove drivers from your system.
How to use ?
There are two methods to use Driver Sweeper.
Both methods achieve the same results. This method is always able to clean all files.
This method will delete remaining files upon reboot (if deleting failed). You can clean your drivers this way:
  • Use the official uninstaller(s) of the driver(s) you want to uninstall.
  • Reboot your PC in Safe Mode.
  • Run Driver Sweeper and select what to clean.
  • Analyse lists all the entries possible to remove, cleaning removes the entries selected.
  • More drivers can be selected for the same cleaning process.
What can it be used for ?The current supported drivers are NVIDIA (Display and Chipset), ATI (Display), Creative (Sound) Realtek (Sound), Ageia (PhysX) and Microsoft (Mouse).
All the settings are saved in an ini file. Nothing is created in the registry, so it's possible to use it as a portable program. Log files can be saved to the harddisk and viewed as well. You can find the logs under the Tools menu.
Driver Sweeper has been replaced with Display Driver Uninstaller. Display Driver Uninstaller Download version 13 6 0 0
The AMD/NVIDIA video drivers can normally be uninstalled from the Windows Control panel, this driver uninstaller program was designed to be used in cases where the standard driver uninstall fails, or anyway when you need to thoroughly delete NVIDIA and ATI video card drivers. This software is backed by Guru3D.com
The current effect after you use this driver removal tool will be similar as if its the first time you install a new driver just like a fresh, clean install of Windows. As with any tool of this kind, we recommend creating a new system restore point before using it, so that you can revert your system at any time if you run into problems.
If you have problem installing older driver or newer one, give it a try as there are some reports that it fix thoses problems.
We have an extensive AMD support thread over here and an NVIDIA over here.
Recommended usage
  • The tool can be used in Normal mode but for absolute stability when using DDU, Safemode is always the best.
  • I would like to gather feedback from you guys. Tell me if it was success or not.
  • Make a backup or a system restore (but it should normally be pretty safe).
  • For people with driver problem, if this tool gave you any success into fixing some issues your are currently experiencing, please share your result.
Keep note that NVIDIA/AMD did not have anything to do with this, I do not work at or for NVIDIA/AMD and they should not be held responsible for anything that may go wrong with this application.
index.php?ct=content&action=file&id=221
NOTE: .NET framework 3.5 Required - Windows XP up to 8.1 is supported X86/X64 (not sure for WinXP x64)
Driver Sweeper has been replaced with Display Driver Uninstaller. Download here.
Feb 15, 2014 | MSI NX7600GT-T2D256E GeForce 7600GT, (256...
Key board some of the letters does not function
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
or if this does not fix the problem
control panel keyboard you can change your settings there
or you might have uninstall the keyboard then reinstall it and its drivers
control panel keyboard hardware then properties you hould see driver details,update driver,roll back driver,uninstall
make sure you have the driver for the keyboard before uninstalling the driver
diconnect the keyboard then reconnect it then reinstall the driver
hope this helps
Dec 13, 2010 | Computers & Internet
Right arrow key on toshiba laptop gets jammed. how do i fix it?
hope this helps
Dec 07, 2010 | Computers & Internet
Wont type or misses letters
if you mean that your keyboard is not typing
hope this helps
Keyboard not working
hope this helps
Dec 06, 2010 | Acer Aspire 5600 Series 5610-2013 Notebook
DirectCD driver update
use system restore...or uninstall roxio and than reinstall....better u should go with system restore
Jun 15, 2010 | Roxio Easy Media Creator 10 Suite
A driver was installed on my computer that will cause stability problems with my systom i need an updated symantec utility driver that is compatible with my windows XP can you tell me where i can get one
Delete all symantec drivers and utilities from your system, use the official "symantec uninstaller". You'll solve a lot of problems by using anything but symantec security products, they cause too much problems.
Jan 12, 2010 | Computers & Internet
ATI Radeon HD 3200 conflict with NVIDIA GeForce 9500 GT driver
To solve this problem, uninstall the old driver, the ATI Radeon, it will not cause a problem when you uninstall it. After the uninstall, restart the computer and then install the support cd for the NVIDIA Geforce 9500 GT.
Oct 28, 2009 | Computers & Internet
Microsoft Windows XP Professional for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
