Question about Canon DR-9080C Path-Through Scanner
I have canon 9080, has error codec01 - Canon DR-9080C Path-Through Scanner
  • 490 Answers
C01 is top cover open. Close it properly.
S. Mohan
Posted on Aug 09, 2010
Why doesn't the feed tray lift on my Canon DR-9080?
Check the inadequate Cable harness (normally purple loom) under the metal lifter . You will need to remove the plastic entry tray to see the metal lifter mechanism which is quite difficult.
Aug 12, 2014 | Canon DR-9080C Path-Through Scanner
Can't change dpi or mode in scanner settings on capture perfect 3.0
Remove & re-install 9080 driver & Capture Perfect if the driver doesn't fix the issue. Verify you have Administrative rights to the computer as well
May 21, 2014 | Canon DR-9080C Path-Through Scanner
Set up disk for canon DR 9080 path through scanner
Hi Joseph, you should be able to find the driver for your OS on the Canon website here. imageFORMULA DR 9080C Color Production Scanner
Apr 10, 2014 | Canon DR-9080C Path-Through Scanner
Where is the QUMA tool for the dr 9080 scanner
Quma service tool is on the original driver CD that came w/ the scanner. password is the name.
Apr 08, 2014 | Canon DR-9080C Path-Through Scanner
HOW TO GET INTO THE QUMA MENU
When double clicking on the Quma tool, type in "quma" as the password.
How do you clear count on a 9080c?
Depressing the red STOP button for approximately 5 seconds should clear the counter displayed on the control panel. The Total scan count for the machine (located under "Control-Panel, Scanners & Cameras, Canon 9080, right click & select properties) can only be reset via the service diagnostic utility.
Apr 21, 2012 | Canon DR-9080C Path-Through Scanner
The DR-9080c scanner will take a whole stack of papers (20 or so) and shove it thru the paper path, not just the top sheet. On old laser printers there was a paper pick that got slippery. Is there one in...
Ensure that the "BYPASS" button on the control panel is not illuminated. Make sure the "Standard Feeding " is selected in the driver. Try cleaning the lower separation roller. Make sure the separation roller is pressing up against the feed rollers. If the roller set is worn, order a replacement set of rollers (Google: Canon 9080 Exchange roller kit)
Apr 04, 2012 | Canon DR-9080C Path-Through Scanner
I have a canon dr-9080 scanner that does not recogniize slip sheets. the rollers have been replaced and the scanner is clean.
There is a minimum size required for a page to be scanned. Please ensure that your sheets exceed that. (2.2: x 2.8")
S. Mohan
Apr 03, 2012 | Canon DR-9080C Path-Through Scanner
Canon DR-9080C Path-Through Scanner Logo
166 people viewed this question
old marine
old marine
