Question about Webroot Spy Sweeper (spysweeper) for PC
When loading the program, the main screen comes up but is a milky
The main screen never completely boots up. It is a milky white and it never loads.
    President:
  • 2,571 Answers
Try and run the program in compatability mode, sounds like it may not be compatable with your OS.
Try Malwarebytes if you have no luck with webroot
Posted on Aug 01, 2010
My go clever quantum 1010N does not get past the boot up loading screen. you turn the power on it goes to a white screen that says loading and goes no further, why?
Booting into safe mode usually indicates a problem with the machine. When powering it on, keep punching F8 for the "Safe Mode" boot option window and try choosing "Last good Configuration". You might try Restoring it back to before this started. Click Start, Programs, Accessories, System Tools and then System Restore.
May 03, 2015 | Computers & Internet
My gx60 isn't bootin up..it says loading project..how do I fix this
From your photo, it looks like windows XP has fully loaded. I would assume the "Loading Project" is from a program, not windows. I would boot up in safe mode and try to do a system restore to when your computer was working. Here's how to boot up in safe mode:
* Press F8 key repeatedly while booting up, right before windows begins to load up. Black screen with white letters usually.
* You should get a few options. Select boot in safe mode with networking.
* once XP loads, Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore.
Feb 09, 2015 | Computers & Internet
Dell dimension 3100 wont load to main screen
You may need to roll back system with System Restore. Under Safe Mode (press F8 during boot and choose Safe Mode). Win 7 - Start > Search type System Restore. XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates. Uninstall last program(s) that was installed, again in safe mode.
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Nov 29, 2012 | Computers & Internet
Satelitte toshiba u405-s2824 loaded new bios now wont load windows keeps restarting
Terrible sequence. You should load windows on the old bios the flash the new bios.
Did the windows installation complete? What keeps restarting the windows installation or the boot process?
If the boot process keeps restarting try running the check disk utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 02, 2012 | Toshiba Computers & Internet
Cmos checksum bad boots to the splash screen then goes black with a blinking white line tried reseting the jumper cmos no luck load default settings no luck removed psu and battery no luck
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
During the boot process you will see on the screen a certain key to press to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
You will also need to set the time and date
In the main or system setup screen you should be able to see the date and time Using your arrow keys navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date.
hope this helps you
Oct 08, 2011 | EliteGroup ECS Socket Micro ATX...
On start up the system boots and windows loads but wont finish. The message ''Insufficient system resources exist to complete API.'' it comes in a box headed Isass.exe- System Error Any help would be...
When windows tries to fire up, does it ask you whether to boot up in safe mode or normal (would be a black and white MS DOS screen with no mouse functions)? If not, you need to reboot your computer and go into boot options. There should be a little comment line in one corner of the screen before windows loads that says something like F2 Setup F12 Boot Menu. Do you get that once it has begun trying to execute windows?
97-KMAG
Dec 15, 2010 | Acer Aspire One PC Notebook
My logo comes up then the intel logo and a small white line then the screen goes black and nothing else will load. Is there something I can try?
Try loading in "SafeMode" when you cut on computer, tap F8, a screen will pop up with a bunch of ways to start the computer, arrow to "Safe Mode" and press enter, If it boots now you probably have a virus. If you have a antivirus program run it.
Feb 22, 2010 | Sony VAIO VGC-V617G PC Desktop
I want to set up a web cam to visit with friends over the internet
Noprob.
Setup disc. Follow instructions, should not need clicking, but then there all differant..
Once loaded, it may restart, once restarted and settled down, insert webcam usb, Poota should fined new hardware and load up your web cam.
After completing and tellking you your new appl is loaded and working.
fined icon on desktop or in your program list. Double click on icon.
Prog starts up, come up with 4inch white screen with a poss error screen? close error screen. you should be left with a white or dark empty square, with menu at the top.
Click on Devices/click your cam name, this will then start your webcam.
Rem, when clicking mirror in options your pic will be the other way round, just click back.
Hope this makes sense. Good Luck!
Nov 12, 2009 | HP Computers & Internet
My MacBook will not boot up
go to bios setup load optimal defaults.
then save.
Nov 12, 2008 | Apple MacBook Pro Laptop Computer with...
Webroot Spy Sweeper (spysweeper) for PC Logo
75 people viewed this question
Top Webroot Computers & Internet Experts
Mike
Jerry
Jerry
Are you a Webroot Computer and Internet Expert? Answer questions, earn points and help others
