Question about D-Link Computers & Internet
I have dlink and all of my computers are working with it except one - it sees the router but wont connect. Any suggestions? I am using a laptop on windows XP
kap990
  • 28 Answers
SOURCE: Vista OS can't connect wireless to Dlink DI-614+ rounter
yes it does but what exactly is this it's your comp that's not connecting to your wireless network..so here try these steps...
first click start>click in start search>in that box type in services>it gives you an option of services on the same start menu at the top click on that...
it will take you to a new screen that says services at the top on that screen you need to scroll down at the bottom and look for wlan auto configuration rt click on it and click start if start is greyed out press restart....
close services down..
click start>click connect to form the start menu> and check it gives your network name in there .if it says anything like no network found in range. pls make sure that wireless switch on your laptop is turned on...
if still you're not able to connectr it's a concern with the drivers of wireless adapter on your comp genrally on new comps its quite common get the drivers reinstalled....
Posted on Feb 20, 2008
watz up
  • 6 Answers
SOURCE: Thomson TG 585 v7 Wireless Problem
HI
The following info. might help you fixing the above problem:
For WIRELESS CONNECTION follow these Steps:
(Note: Keep the Ethernet cable plugged in unless we set up
WIRELESS)
1: Click on Home Network
2: Wlan
Click on Configure which is the 3rd last icon on the Top
Make sure that the option-Interface Enabled is ticked.
Channel selection should be ob Manuall.
Wireless channel can be 11( thats what is in my case).
Encryption is again depending on what type of sercurity you wants. I would suggest go for WPA.
After editing the above info. do not fail to note the KEY before clicking Apply
Now just enable the WIRELESS CONNECTION on your PC /
Laptop,
Pull the SSID of your router and Click connect.
It will ask for the WEP/WPA key?
Enter the key and Click connect.
Posted on Sep 11, 2008
  • 19 Answers
SOURCE: DIR-625 Blocking DWL-G510 connection
1) First you need to check if the router is blocking mac address. Login to the DIR-625 by typing 192.168.0.1 on the address bar of IE.
Use admin for username and leave password blank or type in your password.
Go to Advance Tap, on the left click on Network Filter. Select Turn Off Mac filtering, click on save settings. wait for your to reboot. If that doesn work try option tow below.
2) What you need to do is Upgrade to the latest firmware on your router (Resolves 99% of all problems). Make sure you download the right firmware for there are two version of the DIR-625 ( Rev. A & Rev. C).
You'll also need to make sure you have the latest driver for the adapter since you have a newer computer.
Posted on Oct 03, 2008
kakee
  • 1269 Answers
SOURCE: I currently use a cable
No need to install the dlink on the imac. All you need to do is connect the modem first the dlink. (Modem connected to Internet or WAN port of the dlink). Now if they are connected, your imac should be plugged in to port 1 of dlink, and your PC to port 2. That should do it.
Posted on Dec 19, 2008
kakee
  • 1269 Answers
SOURCE: my laptop cannot connect to the internet through wireless connection using dlink dir615
This is an intermittent wireless connection problem. If you have a cordless phone there, that's the main problem. If none, you need to change the wireless channel of your router to 11. You can do that by opening the router's admin page. If that didn't help, you need to update the router's firmware. Contact Dlink support for more details on how to update the router's firmware.
Posted on Apr 13, 2009
Hi i Just bought dlink 600 i am using compaq and has iphone and internet tv all of them cant connect by wifi my compaq can only connect with a cable. on my tv it says internet connection failed. and btw cm...
ok first prep. we need to configure your router. to do that we need your compaq laptop directly connected to the dlink via ethernet cable. after securing the connection, try to open a browser, whether internet explorer or mozilla firefox. go to the address bar and type in, 192.168.1.1 it would ask you now for a username. username is " admin " password is " password " if it wont let you in, try "admin" for password. if it still cant, try to live it blank and just click on login. it would take you now to the dlink router page. there you can configure your wireless connection and set your network name. make sure to click apply settings after configuring it. then try to check your wireless connectivity again. this should work.
Sep 02, 2011 | D-Link DIR-600 Router
Globe symbol won't turn green.
I was banging my head for 2 days with about 35 different configurations and finally tried the following and it worked just fine. Also, tried connecting 3 computers and they all connected with "NO" issues. Even connected wireless with "NO" issues. Now I am at 20mb download speed...J compared to AT&T 1.5mb download speed.
This is my DLINK model -> (DIR-601 Wireless N 150 Home Router Wireless router)
1. Reset your Comcast Surfboard Cable Modem by unplugging it for 5 minutes.
2. Then reset your DLINK Router to the manufactures default settings. Then Unplug DLINK Router for 1 minute then plug it back in (Just plug your cat5 cable into port 1 and connect it to your computer) there should not be anything else plugged into the DLINK Router at the time you make the changes. Just 1 computer can be connected.
3. Went into the DLINK configuration 192.168.0.1 and changed the PPPOE setting that I was using for my AT&T Modem to Dynamic IP (DHCP). Once you make the changes save them and then unplug your DLINK Router it's off.
4. Turn on Comcast Surfboard Cable Modem and wait until all lights are on. Now plug in a cat5 cable from the Surfboard Comcast modem (NOT A CROSSOVER CABLE LIKE THE CD INDICATES) to the INTERNET port of your DLINK Router. Now turn on your DLINK router.
5. Then turn on your computers or restart them and it will pick up IP Addresses from your DLINK Router
Jun 08, 2010 | D-Link Wireless N 150 Home Router 4Port...
Have a dlink router model 615. new toshiba laptop wont connect??have tried my passcode...didnt work. pc that is connected too router is xp...new laptop is vista.
Make sure that on your Vista laptop the wireless is turned on (look for the LED indicators on the laptop) and see on the system tray the computer with the red X click the icon once and click on Networking and Sharing Center and click on Connect to a network, click the refresh button on the right and if it sees your wireless network highlight it and click on connect... if it not sees it and you are sure that the wireless is ON on your laptop, just restart the computer
Mar 06, 2010 | Computers & Internet
It says it is connected but my laptop wont work i have a dlink dir-300 router
It says connected. Check the Ip address on the computer.
Is there any other computer online ?
If not then check the settings of the router .
If other computer is online then try to ping the DNS server
Click Here for more info about networking
Nov 29, 2009 | D-Link Computers & Internet
Dlink router wont connect to enternet
so that means you are not able to go online using the router.
If you connect the computer directly to the modem, does it work ?
If that works then the modem is working properly.
You can try to reset the router for 30 seconds , then unplug the power to the router and plug it back in. Wait for 1 minutes and then try to set up the router manually.
Click Here for more info about how to set up the router manually
Nov 12, 2009 | D-Link (DI-711) Router
Can ping but cant connect to the internet
you may have to go to your routers ip address and see if you cant configure it to work or maybe your router can only support a certain number of wireless devices.
May 06, 2009 | ASUS Eee Pc 1000Ha 160G Netbook
Communicating my laptop with my Dlink 624 router
first, you need to make access by cable (rj45), may be has the router adreses 192.168.1.254 0r 192.168.1.1, & make configurations for the wi fi from the router
Jul 20, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Router
Does your computer connect to the Internet okay at other wireless locations? Make sure you have the latest drivers in your laptop for the wireless network adapter. You should also verify that you have the latest Windows updates installed.
Is your computer sometimes used in a business network?? If so, make sure the "use proxy" setting has been disabled in your browser when using the dlink router.
Check the D-link website at http://www.dlink.com/products/support.asp?pid=565&sec=0#firmware to verify that you are using the latest version of firmware on your router. If it has any known problems, a firmware upgrade could fix it.
Let me know if you need more details on any of these points. Hope this helps!
Jan 11, 2008 | Computers & Internet
Wireless router
Yes, you can use wireless router with the modem. I guess the actiontech DSl router that you have is also Wireless one. If so, you can use just the DSL router for wireless connection. If you really want to use Dlink router with it, Connect the ( WAN port ) of the Dlink router to the ( LAN Port ) of the Action tech modem [ modem(LAN)-->Dlink(WAN) ]. Once you do this connection, better to do power cycle ( unplug the pwr to the dlink first, then, disconnect the pwr to action tech - wait 1min and plug the pwr to modem, wait for DSL light to be solid , then put the pwr back to dlink ). Make sure DSL light on the modem solid, internet light & WLAN light on the link glowing.
- Make Hardwire connection between the computer to Dlink and check the ip address on the computer whether it acquires the ip address from Dlink and then check the internet connection on the computer, it has to work. if computer not getting ip from dlink, try restarting computer.
- If hardwire connection on the dlink works fine and check the wireless connection.
For wireless configuration or assistance you may check this link:
http://www.portforward.com/help/wirelessxp.htm
please feel free to ask, if you have any more assistance.
- Laxman
Nov 22, 2007 | Actiontec (GS204AD9-02) Router...
Computers & Internet Logo
26 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
