Question about Emerson Pool & Spa
The pump goes out on thermal overload all the time
The pump is under a deck in a cool spot and is 2hp .up from a 3/4 hp .this is the third pump and still goes out on thermal overload all the time. what could it be ?
  • 760 Answers
First be sure it is wired for the voltage that you have. eg if you have 110V circuit be sure pump is wired for 110V. If you have access to an amp meter, measure the current while pump is running and be sure that it doesn't exceed the full load amps on the motor name plate. If it does, decrease water flow by some method. For instance smaller return jets. The more water you pump (volume not pressure) the harder the motor works.
Posted on Aug 01, 2010
My aqua drive 1100 auto reset pool pump runs warm and stops after a few seconds after i switch it on then goes on after a few minutes And this continues. Why
Thermal Overload Switch: Something is creating an overload on the pump. Once it is overworked, the motor will overheat. This will be sensed by the T.O. switch. Once the switch senses that the motor has cooled, it will start again.
Reasons for overload:
  • Bearings no longer spinning freely & without restriction
  • Foreign debris in the volute, jamming against the impeller
  • Failing T.O. switch
Good Luck
Mar 11, 2015 | Aqua Pool & Spa
Have a Sta rite pump with AO Smith 2hp motor#77-177897-22. Extremely loud hard start, Change 30 MF capicitor...no change!! It will try and start 2 to 3 times tripping thermal overload and then on the 3rd...
Bearings are seizing and not spinning freely. That is common when a shaft seal starts to leak & goes uncorrected.
The sound you are hearing are the failing bearings. This will also create the symptoms you described.
Replace the bearings & you will have the problem corrected.
There are two of them: front and rear - both are different sizes. They will look similar to this:
Aug 12, 2012 | Hayward 1.5 Hp Northstar High Performance...
I have a inground pool and pentair 2HP pump. It was running fine for 5 hours and stopped working on it's on. I am switching the power on but there is no response. Is it a pump problem or some...
Thank you for posting your question here on Fixya.com.
It does not hum or buzz or anything? If not I'd start with looking for a tripped circuit breaker. If there is nothing tripped then the motor has either tripped is thermal overload and it needed to cool off or it is dead and needs to be repaired or replaced. If it is the overload it will start working again within an hour, maybe two. That is a sign of an internal problem that needs to be corrected soon or the motor will fail permanently.
If the breaker tripped it too is a sign there is a more severe problem that needs to be addressed before the motor fails beyond repair.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
May 16, 2011 | Pentair 2 hp WhisperFlo InGround Pool Pump...
Uneven cut, seems like it misses spots. new blades.
Sounds like the belts are slipping on the deck. Wheneve it gets overloaded it skips? Check under the deck and see if there is anything that the grass can be catching on and keep it from flying out the discharge shoot. And see if there is anything on the belts. Like oil from something leaking, Lots of grass built up under the shieldsl Or if there is lots of grass build up keeping the tensionor pulley from tightning up the belty all of the way.
May 28, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Pump stopped working while pumping
Yes, most motors are thermally protected. It is usually bi-metallic, and resets itself.
--W/D--
Aug 08, 2009 | Flotec Corrosion Resistant Shallow Well...
How to manually reset an AO Smith 2 hp motor?
If you did not press a reset ( and even if you did) the motor is damaged and that is causing the circuit breaker to trip. You need to have the motor inspected to see if the damage is repairable or if you need a new motor. A local electric motor repair shop should be able to take care of that for you. The thermal overload has reset itself if after cooling down the motor is trying to start but trips the breaker.
To be certain it is the motor, disconnect the line leads and be sure they are insulated from ground and one another. Turn the breaker back on. It should stay closed which confirms it is the motor tripping it when connected.
If for some reason the breaker still trips, there is a problem with the electrical circuit feeding the pump.
Jul 26, 2009 | AO Smith A O Smith Motors A O Smith 2hp...
What does SF mean on pool and spa pumps?
SF stands for Service Factor. It has to do with how much overload your motor can handle without damage. Here is some information about it:
http://www.engineeringtoolbox.com/service-factor-d_735.html
You should not be feeling any "trickle" of electricity. You are correct...it is NOT SAFE! I would definitely have another qualified electrician check your wiring out.
Thanks for using Fixya.
May 16, 2009 | Speck Pumps Impeller. 3/4 Hp, S.F. 1.0,...
Pump is clicking very 2 seconds and then overheats
I'd say you have a problem. The clicking sound is likely a thermal overload from too much current being drawn and the temp rising.
Once it cools off a little it tries again; draws too much currrent, heats up and the thermal overload kicks it off again.
It could blow the breaker as well, it just hasn't yet. Probably because there isn't a short circuit, just thermal overload from too much current for too long. It's a built in safety device internal to the pump motor.
My guess is the pump is bad -- and either the impellers are shot or a bearing is bad.
It would be nice if you could manually turn the pump shaft and see if it feels stiff or it makes unusual grinding noises, but you probably can't get to it.
I'd also guess that a pump repair is not cost effective, 'cause if the pump is that worn, fixing it will only keep it going 'till the next odd-ball thing goes wrong with it.
good luck
May 13, 2009 | Hayward Super Pump 1 1/2 - Hp for In...
Pool & Spa Logo
108 people viewed this question
Top Emerson Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Mike Squire
Are you an Emerson Pool and Spa Expert? Answer questions, earn points and help others
