Question about Jcb Bruder JCB Loader Backhoe
JCB 215 series 3 goes forward in 4th only,reverse has all 4 gears
I am trying to find why our Backhoe does moves forward in 4 th gear only.Revers has all 4 gears.
I do rebuild tranys for cars and light trucks,but I have no idea how backhoe works,my guess,it is electrical.I found a lot of manuals on line,but I am not sure which one I need.Could You advise me where I can find electrical diagrams and component locator,and would be very helpfull description how power train works.
Thank You in advance.And ,please,forgive my misspelings,English is my second language:)))
Michael Guris from Ottawa ,Canada
  • mikeguris Aug 01, 2010
    Thank You.I will try to do ,so.I think it will be something else.B-se,it has all 4 gears in reverse.Then I am trying forward it is staing in N till I swich to 4th.I would like to talk with You after I'll try your advise...
  • drfortinbras
    drfortinbras May 03, 2013
    Call the factory they have excellent tech staff and are very helpfully.
  • 857 Answers
If the transmission is defaulted to 4TH gear and reverse and goes into gear harder than normal,along with no speedometer signal.These are all signs of power or ground problem. The transmission TCM should be mounted to the drivers side radiator shroud. We need to check the following pins on the gray connector. Pin 3 must have full time 12 volt power. Pins 1 and 5 must have good continuity to battery ground. Pins 2 and 4 should have 12 volts with the ignition in the run position. By re flashing the Allison TCM you ruled out a bad TCM they would have had problems flashing it.
Posted on Aug 01, 2010
    Genius:
  • 1,478 Answers
I believe the information you need on this question is a detailed information, in this case, i will suggest you check the information on this link,
http://www.howstuffworks.com/skid-steer3.htm
Take care.
    Thanks for quik replay.I will try...
1972 jcb backhoe not moving backwards or forwards
Sorry no info on any model this old.
May 09, 2016 | Cars & Trucks
My 2006 ford f150 goes in revers my 2006 ford f150 goes in reverse but wont go into forward
could be the forward gear bands actuator , its part of the valve body in the lower part of trans , it has all sort of solinoids in there that make gears shift and select direction
of course if you dissasemble this that far it would only make sence to rebuild the entire thing
Feb 10, 2015 | Ford Cars & Trucks
I have a JCB 214 series 3 1995 it will not move it was working fine going forward and reverse then it just stopped and it was always kind of hard to switch into different gears but now it just slips very...
Needs a clutch. Not cheap your gonna have to pull the transmission the clutch pack is reasonable 150.00 to 225.00 its the labor that is expensive. Don't recommend doing it yourself unless you are up to the task and have the ability and the tools,some special alignment clutch tools. ASE master certified mechanic.
Jan 05, 2015 | Cars & Trucks
I have a jcb 214s will operate forward&reverse in any gear for approx. 20 minutes then seizes up and won't go either direction. Replaced layshaft-mainshaft valve and solenoids, replaced 4 wd valve and...
Old.
This forum states they are crap
http://www.heavyequipmentforums.com/showthread.php?540-jcb-214s-owners-opions
You should try asking there for more help.
Oct 28, 2013 | Jcb Bruder JCB Loader Backhoe
I need to know where the bleeding screw for brakes on jcb214e backhoe
most of those type of equipment have inboard brakes in the axle tubes of the rear gear assembly i.e. follow your brake lines from the master cylinder to the rear axle assembly,the lines usually go in and to a caliper and another line comes out to a bleeder tip nipple ,some models are actually inside the axle tubes them selves requiring disassembly of the wheels ,axle tubes etc. until you get to the inboard rotors and calipers ,major work for such a minute ordeal this is done to keep the system protected believe it or not,i would obtain yourself a model repair manual if i were you or you could also go to jcb and ask them for a photo copy of the entire brake hydraulic system
Feb 28, 2012 | Jcb Bruder JCB Loader Backhoe
Jcb Bruder JCB Loader Backhoe Logo
419 people viewed this question
Top Jcb Toys Experts
Gary Nitowski
Pushkar Singh
Pushkar Singh
Are you a Jcb Toy Expert? Answer questions, earn points and help others
