Question about Samsung LE40R73BD 40 in. HD-Ready LCD Television
Got a samsung le40r7bd tele after a minute picture goes black but got sound
  • 11,361 Answers
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there are some troubleshoot you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Please post back what you find.
Posted on Aug 02, 2010
  • Samsung Master
  • 8,457 Answers
The tele have 2 long boards call the LCD inverter board.These 2 long LCD inverter boards are dead.These 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long refurbishes LCD inverter boards for the replacement.
Posted on Aug 01, 2010
Samsung lcd tv has sound but no picture. Samsung TV works for about 10 minutes then screen go black but sound continues
Use a flashlight on the screen when it goes black. If you can see a faint picture then the board that controls the back light has gone bad. If you see no picture then the T-Con board is bad. You can get replacement parts here: TV Parts Universal TV Stands DLP Chips ShopJimmy and fix the TV yourself. It's not that difficult.
Mar 13, 2016 | Samsung LN40B610 LCD TV
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Samsung 27" lcd tv picture goes black, still have
0ne of 3 has failed:
(in order of probability):
1. Backlight inverter
2. Power Supply
3. Backlight
Please seek the expertise of an experienced TV repair technician - as they contain potentially lethal voltages that must be properly discharged before work can begin.
Thanks!(*&^%
Mar 19, 2011 | Samsung LN-S2738D 27 in. HDTV LCD...
SAMSUNG SP56K3HD my tele cums on with picture and sound for about 20 secs and then goes off the light on the front that says standby/temp flashes red.
Check solder connections on the inverter board. Common problem. Also could be capacitors in the power supply circuit.
Jan 17, 2011 | Televison & Video
Hi. I have an ALBA LCD32880HDF television which I purchased in August 2009 so just outside warrenty. I have been on holiday for a week and had switched the television off at the wall and returned home...
hi all the black screen solution for me was this (this is assuming you have alba brand tvs and have the black screen BUT can still hear the sound) i after much fekkin around with it eventually found the solution in it (its the bloody backlight brightness in the settings you need to turn it from high TO LOW) ....... now this can be a bit tricky because usually when you have the black screen problem if u unplug the tv for a few hours and plug it back in you only get or should get probably like 30-1min of picture time before the picture goes black so u have to be reallllly fast with the menu button to get into settings before the picture dies (i learned the sequence for my alba lcd32880hdf) it was the following (for this part use the remotes arrows the one with the ok button usually in the centre of them) turn the tv on then click menu then press the up key 2 times then press ok then use the right arrow/button twice (although u cant see what ur doing ur navigating the menu hehe) then press the down arrow/button seven times before finally pressing the left arrow/button (once) <-- (now this bit may need to be done twice if you can remember setting ur backlight to max use it twice it will put it on minimum if in doubt only press it the once remember to totally power the tv off before repeating the steps to reset menus default posistions) remember thats the solution i found for my tv stands to reason (since i did infact buy another tv same brand different model which got the same problem) that this could be a solution for all alba tv users try it worked for me 2 times if ur not sure of the menu look up you tv models menu navigation online to find out the buttons you press gl hopefully it works for you too
Oct 24, 2010 | Televison & Video
47in Phillips-tv picture goes black still has
Could be the signal board has a bad cap, in this case it sounds like you are getting intermitten power to the inverters....when the tv goes down and of course you have audio....Shine a flashlight on to screen and see if you have a picture...look carefully. If this is the case..you have the above problem!
Nov 23, 2009 | Televison & Video
No picture
change ur backlight inverter
May 01, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Samsung LE40R73BD 40 in. HD-Ready LCD Television Logo
226 people viewed this question
Jerry Greenberg
Jerry Greenberg
