Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
Detergent Dispenser Will Not Open During Cycles
Detergent Dispenser Does Not Open Even Though The Dishwahser Has Completed All Cycles.
Please Help
  • 50 Answers
Most whirlpool built dishwashers with an electronic display will have a control board. off the control will feed the wires that run the dispenser. it uses 120v to operate a wax motor. a little orangish/red colored motor. two wires conect to it. since you cant really select a dispense cycle. the way i check them is to jump a cord to a surge protected power strip. energizing the wax motor with a jumper cord. see if dispensor opens. this may require more than an average amount of knowlege of electrical saftey when doing this. i always wire it up turn off surge protector then plug in and check. once done checking turn surge protector off and unplug.
Posted on Aug 01, 2010
The detergent dispenser will not open during the wash. We have even tried washing with no detergent and it still will not open. How can we fix it?
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem
Detergent Cup does not Open
heatman101
Dec 16, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
The soap dish opened, but the dishes were not cleaned. The soap remains on the door even after two or three wah cycles. Checked all of the buttons.
Since you mention that your dishwasher has a dispenser has a flap that opens but detergent does not come out, the problem could be the wash water is not getting to it.
Can you confirm if during wash cycle the water is circulating especially through the top wash arm.
Keep a small container on the top rack and see if there is water collected in it at the end of cycle. Alternatively run the dishwasher with door open (you will have to find a way to enable the door switch inside the latch).
Please post a comment to confirm what you observe.
Sep 07, 2010 | Maytag Dishwashers
Bosch diswasher detergent dispenser doesn't open during wash cycl
I've been told we can replace the dispenser. See AppliancePartsPro.com. Part AP2834000
Dec 24, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Rinsing detergent from dispenser
Use gel run a few cycles and help clear and then don't overfill w gel soap
Nov 13, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Detergent dispenser drawer stuck
You may have to remove the washer top (three phillips screws at the back, then push top back about two inches and lift it off) then drill a hole in the top of the plastic dispenser to allow you to use an object like a screwdriver to maneuver the offending part around so it will drop down and allow you to open the dispenser drawer. Use foil tape to seal hole if you don't want to buy a new dispenser. Clean out blue plastic dispenser parts so detergent will siphon out completely. Pushing down on the center tab at the back of the dispenser should allow you to take the dispenser drawer the remainder of the way out. In the future, make sure you do not use over 1 tablespoon of HE soap (and 1 teaspoon of fabric softner) max per load. Even less if you have 2x or more detergent.
Oct 11, 2008 | LG WM-2277HW Front Load Washer
Detergent Dispenser does not open
I had this problem - the dispenser only opens if there are small items in the rack in front which don't come up to the same height.
Jan 08, 2008 | AEG 23 in. Favorit 86070Vi Built-In...
Bosch Aquasensor Detergent Dispenser door wont open during cycle
Behind the dispensor door there is a small selanoid you will need to replace this, test to see if its open circuit, alternatively you can just place the detergent in side the machine before you put it on a wash cycle is this would have the same effect. the only cycle you can not do this on is the one with the prewash, I think its number 1.
Nov 17, 2007 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Detergent lid won't latch shut
The whole dispenser will need to be replaced, they only come complete
Sep 07, 2007 | Asko D1796FI Built-in Dishwasher
DETERGENT DISPENSER
Hi the plates and bowels should face into the center of the dishwasher, the spray arm spins at the top and bottom from and sprays outward, check that you are using the soap dispenser and not the rince agent cups, also check to make sure it will spring open , ifall that is good then you may have a bad wax motor or a loose conection. at the wax motor. let me know
Aug 30, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
249 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
