Question about Dell Inspiron 1521 Notebook
HOW TO ACCESS A COOLING FAN OF A DELL INSPIRON 1521
  • 3,940 Answers
Here ya go
Posted on Aug 01, 2010
I think faulty motherboard for Inspiron 1521
try to change your ram maybe it will work
Oct 20, 2011 | Dell Inspiron 1521 Notebook
This evening, my Dell Inspiron 1521 laptop started making noise from the cooling fan area. What does this mean? Does it need to be replaced?
It could. First thing you should do though is clean the fans out with some compressed air.
Make sure the laptop is off and you're outside. I usually use two cans at once for best results. If you still get weird noises especially screeching then the bearings are going out and you can either grease up the old fan (band-aid fix) or swap it out with a new one.
Hope this info helps and best of luck!
Jan 13, 2011 | Dell Inspiron 1521 Notebook
How to replace bad cooling fan on dell inspiron 1521 laptop
Replacing the fan is easy, once you remove the drives, the panels from the bottom, etc. Remove the keyboard and unscrew the frame. then the laptop clicks apart. The fan can be removed replaced.
While you can replace the fan fairly easily, they are expensive if you have to buy one from DELL. You might be able to substitute one from another laptop however.
The problem on the Dell Inspiron though is not the fan, but the design. It does not dissipate heat well, cycling heat poorly throughout the casing and ultimately over the drive before exiting from a primary vent on the side which needs to be higher to get good air flow. The air gets so hot and dirty that it eventually clogs up the fan and over heats the drive.
As a matter of fact, even when the fan is running normally the drive often fails anyway right around the two year mark. My last two companies have bought these and you can almost set your watch by the drive failures.
The solution, is a $5 cooling tray like cooks use for cookies. The metal grill will lift the laptop about 1.5 inches off the surface your working on and allow air to move freely in and out of the vent on the side.
Mar 08, 2010 | Dell Inspiron 1521 Notebook
Unlock dell inspiron 1521 unknown bios pswd
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-1521-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
Feb 12, 2010 | Dell Inspiron 1521-JB Notebook
Should I expect that Thermal-Cooling Assembly is always cold or warm? It's hot when I opened inspiron 1521 which is hanging sometimes so i'm wondering if thats the reason
thermal cooling is supposed to keep the laptop nice and cool but if there is a problem with the motherboard putting out to much heat then a cooling unit won't help cause that would mean either the cpu fan is not working or the motherboard is bad cause it can't regulate the voltage going thru it.
Dec 13, 2009 | Dell Inspiron 1521 Notebook
Inspiron 1521 vent
I have located an online manual for removing and replacing the fan for your Dell. Please follow the link I have provided for you below for assistance. This gives you a step by step procedure. Please ensure that you read the "Before you begin" section prior to proceeding with opening your laptop.
Hope this helps.
CK
http://support.dell.com/support/edocs/systems/ins1520/en/sm/fan.htm#wp1179839
Aug 02, 2009 | Dell Vostro 1500 1700 / Inspiron 1520 1521...
I have a inspiron 1521 and the microphone does not work. I had to reinstall windows????
Normally mic is default disabled and you should enabledit in the mixer by access the speaker symbol in taskbar.......
Jun 05, 2009 | Dell Inspiron 1521 Notebook
Loud Fan won't stop
Your fan is most likely dirty. You can try getting a can of air and cleaning it out but most likely you will need a new fan.
Apr 25, 2009 | Dell Inspiron 1521 Notebook
Dell inspiron 1521 cd key
u can get cd key on www.torrentreactor.net
by writing " key for dell inspiration 1521 "
or on google
write "key for dell inspiration 1521 for windows or vista"
or ucan go on www.freekey.com
Mar 04, 2009 | Dell Inspiron 1521-JB Notebook
Dell Inspiron 1521 Notebook Logo
209 people viewed this question
Alun Cox
