Question about Kenmore 53092 / 53094 Side by Side Refrigerator
I have a kenmore elite side by side with icemaker in the door. when i dispense ice the flap doesn't want to close to keep cold air in. can close flap manually.
  • 50 Answers
There is a solenoid in the door assbly. it may just be corroded but may require replacement.
Posted on Aug 01, 2010
Walk in freezer solenoid not opening
Many Kenmore side-by-side refrigerators have an ice and water dispenser installed on the outside of the freezer door. The ice dispenser has a flap that opens to allow ice to be released, and closes after dispensing to keep the cold air inside of the freezer. The dispenser flap is opened and closed by a solenoid, that when energized pulls the plunger attached to the flap, opening the door. If the flap stops opening and closing, it is likely due to a faulty solenoid.
Jul 29, 2012 | Freezers
Tip
Unthawing the water dispenser in the freezer door
If the icemaker is loaded with ice or certain areas of the freezer are perhaps overloaded redirecting cold air toward the water output it can freeze. Also if the ICE shoot has ice cubes obscuring it's closure that area gets cold enough to freeze the water. Check after dispensing ice that the round flap is closed.
I open the freezer door and place three regular sized bed pillows placed into white trash bags into the opening being sure to DEPRESS the light latch with one of the pillow placements so it won't constantly sound a door ajar warning.
I then close the door as much as the pillows will allow and place a chair in front to keep the pillows in place for about 25 minutes. Usually this will do it and the water will begin to flow . I draw off enough to run it completely through the entire line . Sometimes a small piece of ice will come out. I had tried hair dryers and all manner of things and just gave this a shot one day and it works when it freezes for whatever reason it will use.
on Apr 26, 2015 | Frigidaire Gallery GHSC39ETJB 22.6 Cu. Ft....
I have a Knmore side by side fridge, model 106.55606400. The ice dispenser have stopped dispensing ice. The icemaker working fine,the dispenser motor makes a sound when lever depressed for ice.Where do I...
One is the icemaker will leak on the auger motor and freeze it up as you describe. If this is the problem the ice will be very solid (hard ice). If this is the case check to see if the tube that feeds the icemaker water is clogged with ice and if so remove the ice and replace the water valve. If not the icemaker may be overflowing, which is still most likely due to a bad water valve.
The other thing that will cause this is an air leak. If it is an air leak the ice will be frosty more like snow than hard ice. But even so it will still cause the auger not to work. If this is the case check the little flap that opens and closes to let ice through the door to see if it is closing properly. Then check the door gasket to see if it is sealing properly.
Turning the temp. down shouldn't help nor hurt your problem.
Jun 08, 2011 | Kenmore Refrigerators
I have a Kenmore Elite side-by-side refrigerator with ice and water in the door, Model No. 106.58963701. The ice flap is staying open and letting warm air into the freezer and freezing up the ice maker...
Here is a large diagram and a PDF of the parts. Most likely you have a broken door flap spring broken or the hinge. Click Here=> 8201649 Dispenser Door Flap Kit
Click Here=> W10224328 Spring Here s a PDF of all parts related to your models dispenser=>
KENMORE_106.58963701_REFRIGERATOR_SIDE_x_SIDE_Dispenser_Components
Click here for=> 106.58963701 Dispenser Components
If you need instructions on how to take the dispenser apart please let me know. You really will not see the true problem until you have the dispenser disassembled. Hope this has helped answer your questions, Thanks, Sea Breeze
May 04, 2011 | Refrigerators
Ice forming where ice comes out to refrigerator
I am not sure if this is the same issue or not.  the flap that closes after you have dispensed ice does not close or seal all the way.  The gasket is worn down. the result is warm air get up into icemaker and warms ice and refreezes in one block so now the dispenser gets blocked.  We had to replace the flap in the door.  bought the part at an appliance part  store (not sears) they were helpfull and looked up the part needed.  Also a sheet of ice forms on the  bottom of the freezer.  When water is dispensed a small bit drips inside freezer in back and runs down to botom of freezer slowly forming a sheet of ice.  Use a hair dryer to defrost and then you must unclog the drain in the back at the bottom of ffreezer to allow it to drian.  Once we finally unclogged the drain we have not had any problems for about 2 years.
Nov 17, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice dispenser flap/door will not close properly
I have a similar problem. The repair guy took a look at it and stated everything is working and did not order any solenoid or any other parts. After he left the problem returned where ice comes down the chute it tends to lodge and keep the door open. I am disagreement with the repair guy and am leaning toward the idea that the spring has lost tension and is just too weak to close with any authority. There is a video on how to replace the spring on youtube. This is what I will be doing next weekend and will try to return to post results.
Jun 10, 2008 | GE Monogram® ZISS420DMSS Side by Side...
New Kenmore Elite ice dispenser not working but water is
Should be no longer than 24hrs. Is the freezer good and cold.. has to reach a certain temp before icemaker activates. Might take little longer if you put a lot of warm things in freezer or refrig. when you made the change. Is there any water or ice in the icemaker itself? Water may not be getting to icemaker call them back out if it dont work soon thats what warrantys for :0)
Sep 02, 2007 | Whirlpool ED2FHEXN Side by Side...
Kenmore 53092 / 53094 Side by Side Refrigerator Logo
141 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
