Question about Sony PlayStation Portable (PSP) Console
My psp won't connect to the internet.
I have wifi at my home but when i click on test connection it tells me " a connection error has occured. a connection to the acces point could not be established. check the availibility settings for the network and try again." help me. please.
  • 864 Answers
First try this step by step guide. If this doesnt work let me know at what step you get an error and what the error code is. Then from there i can specifically diagnose your problem and give you a fix for the error code. step 1 Your PSP will detect any wireless wireless network within its range as long as the wireless
adapter is switched on. The switch for this is on the left end of the PSP, near the analogue
thumbstick. If the switch is in the down position, the wireless network adapter is off; push the
switch into the up position and it'll turn it on. If you're not going to be using wireless
networking it's a good idea to keep it turned off as it'll make your batteries last longer.
step 2 When you turn on your PSP's wireless adapter it'll look for any wireless networks nearby. If
there's another PSP within range it'll automatically set up what's called an 'ad-hoc' network
between the two. This will enable you to play multiplayer games between the two PSPs with one
hosting the game and the other joining it. When you want to join an existing wireless network,
such as when you want to browse the internet, you'll be using an 'infrastructure' wireless
networking mode.
step 3 To connect to a wireless network, go to the home screen of your PSP and look under Settings. If
you scroll all the way to the bottom you'll find Network Settings, so enter this and on the next
screen you'll be asked to choose between Ad-Hoc and Infrastructure, so pick the latter by
selecting it and pressing X. Press O to return to the previous screen. You'll need to set up a
Connection. You can save the settings for 10 different Connections and you can choose between the
Connections you've set up whenever you need to use the Infrastructure network mode.
step 4 Pick New Connection and press X. You can give the new Connection a name by pressing X and using
the text-entry screen. Give it a descriptive name like 'Home Network' or 'University Network' so
you know when and where you can use it. When you've entered the name for your new Connection
you'll be asked whether you want to scan for WLAN settings or to enter them manually; select the
Scan option and press right on the directional-pad. Your PSP will then scan the area for any
available networks and collect the settings needed.
step 5 A list of available networks (called Access Points) will be displayed, giving its name (called an
SSID), whether it's encrypted or not and the signal strength. If there is more than one network,
use the D-pad to scroll down to the one you want to join and press X. You'll be asked to confirm
the settings so press right on the D-pad to scroll through each. When you get to the security
settings, choose the appropriate setting from the list, which is WEP in most cases, and press
right on the D-pad again. If you need to enter the WEP key, speak to whoever runs the wireless
network and they'll provide it for you. Press X and enter the WEP using the text-entry screen.
step 6 Once you've done that you can check the settings you've entered on the final screen and save
them. Now you'll be able to connect to the wireless network. If you return to the main home
screen you can now update your PSP's software by going to Settings and selecting Network Update.
Alternatively you can go to the Network section on the far right of the home screen to browse the
internet using the PSP's in-built internet browser. Or you can fire up that multi-player game
you've been itching to try out and get going!
Now you're online, if you need further assistance or get an error code please let me know and i
will be glad to assist you further. Thanks-Midwest-tek
Posted on Aug 27, 2010
What i need to do to connect my psp for internet
You will need a wireless router in order to connect the PSP to the internet
  • With your Psp turned on go to the "Settings" in the menu (scroll to the left)
  • Scroll all the way down until you have reached "Network Settings" and click the "X" button to enter
  • Select "Infrastructure Mode" and hit "X"
  • Select "New Connection" and hit the X button again
  • Now you will have a number of options for connecting to a wireless connection. Choose "Scan" and press the control pad to the left, the PSP will now scan for wifi signals around your area
  • When the PSP finishes scanning you will probably have a few different wifi connections. SSID is the name of the connection, the Security column tells you whether or not the connection is password protected, and the last one is the signal strength the higher the better
  • If you want to borrow your neighbors unprotected wifi select a connection with "None" in the security column and a strong signal. If you want to use a secure wifi than you will need to know the password. Select one and press the X button
  • Now the Psp will confirm your settings proceed by pressing left on the d-pad and save your settings
  • Now test your connection if you are able to connect, awesome. If you were not able to connect try doing the settings again
  • With the connection settings in place we can now connect the PSP to the internet. In the home menu scroll all the to the left until you have reached "Network" and go down to "Internet Browser" and hit "X"
  • Your browser will appear, select the little square box to enter the web address, play around with the different options. Have fun with your PSP online
Dec 16, 2010 | Sony PlayStation Portable (PSP) Console
I tried to connect to internet from my psp2, but always connection erroe occured. Please advise how to set up wifi connection. Thanks
Hello
To connect your PSP to the Internet, you must manually configure the WiFi settings for your device. The PSP will not automatically search for and connect to available wireless
Turn on your PSP by moving the power button on the right-hand side of the console in an upward motion. Under the console's main screen, go to the "Settings" icon. This is the first icon listed and is farthest to the left. From the drop-down menu, choose the "Network Settings" option at the end of the list.
Select "Infrastructure Mode" and press the "X" button. Select the "New Connection" option to add a wireless connection to your PSP. Choose the "Scan" option to instruct your PSP to search for accessible wireless connections in your area.
Select a wireless connection from the connections your PSP is able to access. Confirm the name of the network and press the right arrow button. Confirm the security encryption settings for the connection. In most cases, the PSP will determine the network's encryption automatically. Enter the wireless connection's password if the network is secured.
Name your new wireless connection so that you will be able to identify it in the future and save your settings. Run a test connection to ensure you are able to connect to the Internet through the wireless network.
Press your PSP's "Home" button at the bottom left-hand side of the console. Move your cursor to the right to find the "Network" icon. Select the "Internet Browser" option from the drop-down menu. Press the up directional arrow and press "X" to enter a web address into the browser. Once you enter a web address, your PSP will automatically connect to the Internet using the WiFi connection you set up previously.
Nov 14, 2010 | Sony PlayStation Portable (PSP) Slim...
I need help connecting to the internet with my psp
Connecting the PSP to the internet is pretty easy once you get all your settings in place. Here’s how to connect the psp to the Internet. You will need a wireless router in order to connect the PSP to the internet or you could “borrow” your neighbours wireless access although it’s better to have your own. Wireless routers are very cheap nowadays you could find a good one for about 30 for 50 bucks.
  • With your Psp turned on go to the “Settings” in the menu (scroll to the left)
  • Scroll all the way down until you have reached “Network Settings” and click the “X” button to enter
  • Select “Infrastructure Mode” and hit “X”
  • Select “New Connection” and hit the X button again
  • Now you will have a number of options for connecting to a wireless connection. Choose “Scan” and press the control pad to the left, the PSP will now scan for wifi signals around your area
  • If you want to borrow your neighbors unprotected wifi select a connection with “None” in the Security column and a strong signal. If you want to use a secure wifi than you will need to know the password. Select one and press the X button
  • With the connection settings in place we can now connect the PSP to the internet. In the home menu scroll all the to the left until you have reached “Network” and go down to “Internet Browser” and hit “X”
Mar 08, 2010 | Sony PSP-3000 Silver Console
Cant connect the internet
Oct 22, 2009 | Sony PlayStation Portable (PSP) Console
Dont no how to connect the internet to a psp go
Oct 22, 2009 | Sony PlayStation Portable (PSP) Slim...
PSP
Well it look like you might not have a WiFi network connection set up yet on your PSP. So This is what you want to do if you have DSL at home and a WiFi router. When you search for a new network connection and you find the one from your home, you will still need the WEP key wich is the most inportant in order to allow you PSP to use that WiFi connection. That must be why you are getting this error messege
Aug 30, 2008 | Sony PlayStation Portable (PSP) Console
Connection error for sony psp
Hi this is definately a Wifi Fault code. if your doing everything right on connection and the PSP throw the 80410A0B code, you may need a new Wifi card. it is the same card as the memory stick. When connecting wifi, the PSP will tell you if the connection has security turned on or not. If it is WEP or WPA or something like that, you need a passcode the access the internet.
Jan 28, 2008 | Sony PlayStation Portable (PSP) Console
DNS error while connecting my psp
i got solution
dont solved problem!
ok solution:
click inafacture mode in network settings.
new connection > scan > now look for internet wchich has no security > choose it > then click left arrow > then choose easy and go to the save settings, save,test connection. IT WILL SAY YOUR INFO AT THE END AND THEN YOU CLICK CIRCLE GO TO INTERNET BROWSER AND ENJOY
IF SOMETHING GOES WRONG TRY AGAIN IN DIFFERENT PLACES.
it should work.
enjoy internet
Jan 13, 2008 | Sony PlayStation Portable (PSP) Console
Psp wifi internal error 80410a0b
You got problems with your dns settings, try to delete all the old connection profiles, or restore default settings, and see if it works.
Dec 20, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
185 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
