Question about Minn Kota Maxxum 80 Freshwater Bow Mount Trolling Motor With Hand Contols And Maximizer
My foot pedal is stiff hard to turn - Minn Kota Maxxum 80 Freshwater Bow Mount Trolling Motor With Hand Contols And Maximizer
The clutch pedal action has become stiff suddenly. the clutch takes in the middle. what can I do to fix it?
Is it hydraulic if not the slave cylinder may be going this is caused by constantly leaving your foot rested on the clutch pedal dont do that so it may go at any time
Jul 02, 2018 | Cars & Trucks
Every time I start the car the brakes are super stiff and pedal is hard to push with very slow stopping but after I brake several times it gets better but is still pretty scary at first.
With the engine off, put your foot on the brake pedal and press down. The pedal should go nowhere. With foot still pressing on pedal, start the car. The pedal should move down. If not, could be an issue with the servo such as a cracked / leaking air hose or an issue with the master cylinder seals.
Jun 17, 2018 | Volvo Cars & Trucks
Brake pedal is stiff when off and goes tt floor when running is it booster or master cylinder
Well stiff or a hard pedal when the engine is off is normal.
Pedal going to floor is a faulty master cylinder or low on fluid, or air in the lines.
May 26, 2016 | Cars & Trucks
The handwheel will turn manually but it will not move using the foot pedal. The sound it makes when I press on the foot pedal *sounds* like I am filling the bobbin.
foot pedal not moving needle - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Sewing
Nov 8, 2013 - We have a Brother Limited Edition Project Runway Sewing MachineRefurbished LS2250PRW. I was trying to sew on a button and was turning the hand wheel to do ... front near the needle where you can run the machine with foot pedal ...just what I would experience when my Bernina was running, or not, ...
Sewing Machine Repair ' ThriftyFun
www.thriftyfun.com/tf/Home.../Machines/Sewing_Machines/index.html
The thread is being picked up from underneath, but will not form a stitch at all. ... Butwhen I push my pedal down my needle won't move, the motor runs, but nothing happens. ... I have a Bernina machine which is sewing OK with the normal foot. ....The hand wheel, the wheel at the end that manually turns to make the needle ...
Help me diagnose and fix a problem with my sewing machine - Sewing ...
artisanssquare.com > ... > Sewing Machines
Jan 11, 2016 | Bernina Sewing Machines
Power failure when braking problem
sounds like your power assist vacuum unit is dead. i.e. your power brakes. pump your brake pedal 3 times and hold it. turn on engine-if the pedal sinks to floor its the brake master cylinder, if it pulses and comes up with your foot on it its its neither but if it stays right where it is>? BINGO-power assist! good luck.
Oct 17, 2013 | Pontiac Firebird Cars & Trucks
2007 gmc canyon sputters like it is going to cut off when applying brakes sometimes hard to start. just changed plugs and air filter . could it be brake booster or something else
if I say possible servo booster is faulty,surely you will feel it on the brake pedal ( stiff ),or the engine running would be erratic.the other alternative situation is the pipe( hose ) which is connected with inlet manifold and servo booster and inside has the check valve probably is faulty. Test : off engine,pump brake pedal several times till gets stiff. Keeping your foot on brake pedal start the engine and if your servo works fine then the pedal goes a bit down,if not will not move at all. If the engine is running erraticly then with engine off, remove the pipe connecting manifold and servo block the pipe you remove from servo side,block it and start the engine,If engine run fine,then you must confirm whether is the servo or the check valve hose. For the check valve hose how to check,just put in your mouth the servo side pipe and blow into,if the air goes in the engine means that the check valve is broken and you must renew the pipe with check valve,if on blowing into will not allow air to get through,means is ok and the servo is the fault. Good luck.
Jan 03, 2013 | 2007 GMC Canyon Crew
2005 dogde ram 5.9 fuel not cutting off after pulling foot off pailer stay the same or 2 sec. then drop off
That sounds dangerous.. Find where the cable from the pedal come to the throttle body, undr the hood.. You should see the cable where it wraps over a grooved wheel which operates the throttle opening.
With the engine off, use your fingers operate the wheel to see if it is stiff. You will see the cable slack and loop a little, make sure it sits back in the groove when you are done.
You are looking to see if the wheel hesitates in returning to normal position by spring pressure. Possibly the sping is broken? If the wheel moves and returns without stiffness or hesitation, then the problem is in the cable.. Dry cable and guide. This is hard to lube, likey needs to be replaced.
If the wheel is stiff and sticky, then the throttle body linkage is the issue. Try cleaning the linkage librally with carb cleaner. Avoid getting much in the intake.
Hope this helps.
Dec 12, 2010 | 1999 Dodge Ram 2500 4WD
What do i do about a stiff gas pedal?
Disconnect the cable from the pedal and see it goes down free, if so its not the pedal. probably the cable.
Apr 20, 2010 | 1993 Ford F250
1992 SUZUKI SIDEKICK AUTOMATIC HAS BRAKES LOCKING UP ON RANDOM WHEELS WHEN TURNED OFF AFTER SHORT DRIVE. REPLACED CALIPERS, MASTER CYLINDER, BRAKE LINES, FRONT PADS, BACK ONES FINE. PEDAL IS VERY HARD...
Try the following to confirm if is the servo unit .( engine off,pump few times the brake pedal to become stiff.Keeping pressed the pedal start the engine and if servo is working you will feel the pedal slightly goes down.If not will not move at all-remain stiff.) Also if you do have the check valve close to servo not working you can realize it by the engine idle ( erratic ) and the servo not working.The other possibility if the vehicle is fitted,the ABS unit itself.
Dec 27, 2017 | 1992 Suzuki Sidekick
Minn Kota Maxxum 80 Freshwater Bow Mount Trolling Motor With Hand Contols And Maximizer Logo
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
