Question about GE DBL333EBCC 5.7 cu. ft. Electric Dryer
The optimum dry is not working - dbl333eb
The optimum dry is not working, the dryer continues to run even though the clothes are bone dry.
  • 50 Answers
They have a sensor it will have a few metal strips inside the dryer. ge usually right by the lint filter. it most likely that or whatever feeds it. the auto dry sensing board or timer. sensor, sensor board or timer. most of time sensor is bad.
Posted on Aug 01, 2010
Samsung gas dryer will work but will not dry clothing
You have a clogged air vent, check that the air vent hose is not smashed, if it is not smashed, have your dryer vent cleaned professionally, and recheck the dryer operation, dryer vents should be cleaned every other year for optimum performance.
Oct 23, 2015 | Samsung Dryers
Dryer won't dry clothes
the heating unit must have been broken. go to near by mechanic shop.
Jan 31, 2013 | Dryers
Bosch WTL5200 silver edition not getting hot enough to dry clothes
Check ur venting inside and outside the machine. the lint basket? is the air blowing out the back without any restrictions? then check ur thermostats with a multi meter for continuity, may also want to check ur moister sensor, if its mis reading the dryness it will shut off heat early
Jul 16, 2012 | Bosch Dryers
Takes 4 ever to dry clothes. Will run & run when on auto dry.
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Jan 09, 2011 | Amana NDE5800AY Electric Dryer
Drier never stop even clothes are dried,what is the problem
There are several things that could cause your dryer to continue running even when the clothes are dry. The most common culprits are
- Faulty dryer timer
- Faulty thermostat
Mar 10, 2010 | Dryers
Have duet electric dryer model #9200Lw1 dries slowly
are you overloading the dryer, too many clothes would take longer to dry
Feb 03, 2018 | Whirlpool Dryers
Dryer keeps drying and getting too hot
Check the dryer vent .The vent is stopped up,in the vent,or in the inside of dryer,in the lint hopper.Clean it out and unstop the dryer,and the vent.
Oct 10, 2009 | Whirlpool LER5636P Electric Dryer
Dryer not dring clothes completely
need to check your vent duct. if clogged it won't let the air flow through the dryer needed to dry your clothes.
Jun 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore 11070702990 Gas Dryer - Timer does not work
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
May 09, 2009 | Kenmore 60172 Electric Commercial Dryer
Takes too long to dry or keeps running when clothes are dry
May 07, 2009 | Kenmore Elite Oasis 6809 Electric Dryer
GE DBL333EBCC 5.7 cu. ft. Electric Dryer Logo
133 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
