Question about Bulova Watch
Origo stormshield - I have just put a new battery in how do I reset the time?
Tip
ORIGO watch instruction manuals.
Follow this link and download manuals for all ORIGO watches: http://nagear.com/downloads.php#
on Feb 28, 2010 | Watches
Replacement Band
Origo went out of business some years ago, so I'm afraid the chances of you picking up a replacement strap are very low. I can only suggest eBay, but at time of writing there were none there.
Aug 29, 2017 | The Watches
I bought this watch "origo guide pro" off the Internet in used condition, however the backlight does not work. Could this be a blown bulb?
it can be several things to cause this, from the looks I would immediately say that the batteries needs to be replaced, it takes power to turn on the light and when it tried the power is taken from other components like the lcd, and never actually light because there is not enough power,
next it could be the bulb, it could be dead, short circuited. The issue is they are usually hard to replace and or irreplaceable, it needs the be rated the same for voltage a multimeter would help you a lot, to see if voltages are coming from the wires that connect to the bulb.
next the watch could be malfunctioning and may no longer have proper working circuity to run the backlight, this will be extremely hard to repair it will be better to replace the inside or take to a jeweler to have it repaired, in any event if you choose to repair it then you look for damaged parts and replace them- in the event that fails take you digital multimeter and trace the circuit to see if you can find the faulty part this requires you to have adequate knowledge of electronics and it would surely help to have the schematics to the watch--Good Luck.
Jan 28, 2013 | Watches
Origo oc 038 is locked. how to unlock
On the main "time" screen hit the top right St/sp and then the bottom right "reset" button. This will lock and unlock the oc-038
Mar 14, 2012 | Watches
I need a replacement watch strap.
Most watches have a similar strap fixing method, so you might be able to get a replacement strap from any watch retailer.
The shop should be able to advise you if they cannot provide you with a replacement.
Mar 01, 2010 | Watches
Cannot set time on an origo oc-038
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all ORIGO watch manuals. Rate me, please.
I want to replace the battery in my wristwatch
Open watch caseback.
Unscrew (unclip) battery contact.
Read the details on battery and buy the same one.
Put the new battery in.
Put the contact back in place.
Reset your watch.
Set the time.
Smile.
...and do not forget to rate, please....
Jan 07, 2009 | Bulova Watch
Origo oc-038 watch manual
To unlock the "Key Locked" message on an Origo, press the upper right ST/SP button then the lower right Reset button.
Jun 15, 2008 | Watches
Bulova Watch Logo
164 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
