Question about Kenmore Dryers
TUMBLE AND HEAT IS O.K. SOMETIMES STOPS WAY BEFORE TIMER EXPIRES
  • 50 Answers
Motor over heat you may notice you have to hold the start switch long and motor has a hard time starting. often while running sounds like alot of vibration
Posted on Aug 01, 2010
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Timer stops at 6 minutes but continues to tumble.
You will need to replace the auto dry sensor on your dryer.
Mar 11, 2012 | LG DLE2516 Electric Dryer
The dryer stops after about 15+ seconds.
No, but mine started doing the same thing today. Did it once before and same- started working again. Any suggestions for last poster and myself?
May 31, 2010 | Frigidaire AGQ6000ES Gas Dryer
Dryer will not stop running
Your machine may have a feature called wrinkle guard or wrinkle shield, which basically keeps tumbling the clothes without heat to prevent wrinkles from setting in. Turn that feature off and see if that does the trick.
May 15, 2010 | Frigidaire Electric Dryer
Dryer not blowing hot air- timer not working
im assuming your on the automatic cycle. on this cycle the timer will not advance without heat. check you house circuit breaker/fuse. if one goes the unit will run but will not heat.
Feb 08, 2010 | Dryers
Model SDG305DAWW, gas unit...begins to dry and then stops...timer stops and unit continues to tumble but no heat...turn unit off and wait for about 2 hours then can dry again....replaced cycle timer,...
Sounds like you have the same problem I did. You need to replace the flame sensor. Takes about 15 - 30 minutes. You can order the part online here
Feb 06, 2010 | Maytag Dryers
Maytag dryer won't heat
Sounds like your heating element is burned out (acually burned threw) and you will also need to replace the cycle timer.
Feb 17, 2009 | Dryers
Auto stop problem.
ck to see if wrinkle guard or some such feature is activated ..most dryers have a cool down followed by intermittant tumble without heat to reduce wrinkles
Nov 17, 2008 | Frigidaire GLGQ2152ES Gas Dryer
Our TH8000 Series Programmable Thermostat keeps flashing "change filter" even after we changed it. The guide book does not show how to re-set so the flashing stops.
try holding the filter button in for three seconds, if that doesn't reset the timer try the filter button and the temp. up button at the same time for three seconds.
Mar 30, 2008 | Honeywell Electronic Programmable...
Zanussi tumble dryer model TC7103W ** heat, machine runns ok, changed compleate heater unit including thermostat.
it could be the timer what sometimes happens is a wire can burn out or have a break in it have had some dryers do this to me and have had to change part of the wiring to fix the customers dryer
Mar 10, 2008 | Dryers
Dryers Logo
13 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
